I don’t know if this is directly relevant, but …
I am just trying out a new emonTx4, with one 50A CT on input 2, no emonVs, no temperature sensors.
From the serial port:
emonTx V4 CM Continuous Monitoring V1.5.7
OpenEnergyMonitor.org
No EEPROM config
Settings:
Band 433 MHz, Group 210, Node 17, 7 dBm
Calibration:
vCal = 807.86
assumedV = 240.00
i1Cal = 300.30
i1Lead = 3.20
i2Cal = 150.15
i2Lead = 3.20
i3Cal = 150.15
i3Lead = 3.20
i4Cal = 60.06
i4Lead = 3.20
i5Cal = 60.06
i5Lead = 3.20
i6Cal = 60.06
i6Lead = 3.20
datalog = 9.80
pulses = 1
pulse period = 100
RF on
temp_enable = 1
JSON Format Off
RFM69CW Freq: 433MHz Group: 210 Node: 17
RadioFormat: LowPowerLabs
Reference voltage calibration: 1.0256
Temperature Sensors found = 0 of 3
Temperature measurement is enabled.
No temperature sensors detected, disabling temperature
AC missing - Apparent Power calc enabled, assuming 240.00 V
MSG:1,Vrms:240.00,P1:432,P2:216,P3:217,P4:86,P5:87,P6:87,E1:0,E2:0,E3:0,E4:0,E5:0,E6:0,pulse:0
MSG:2,Vrms:240.00,P1:11,P2:5,P3:5,P4:2,P5:3,P6:2,E1:0,E2:0,E3:0,E4:0,E5:0,E6:0,pulse:0
MSG:3,Vrms:240.00,P1:11,P2:5,P3:5,P4:2,P5:2,P6:2,E1:0,E2:0,E3:0,E4:0,E5:0,E6:0,pulse:0
I am receiving the data on a home built emonBase (old RFM69Pi version), emonCMS Version
low-write 11.4.1. I am getting odd results for temperature. As I don’t have any temperature sensors attached, I believe that I should get the error value of 300 for T1, T2 and T3. Instead I get 300, 30000, 30000, even though I have the 0.01 multiplier in emonHub for all three temperatures.
emonHub config (taken from emonTx4.ino V1.5.7) is
[[17]]
nodename = emonTx4_17
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, P5, P6, E1, E2, E3, E4, E5, E6, T1, T2, T3, pulse
datacodes = L,h,h,h,h,h,h,h,l,l,l,l,l,l,h,h,h,L
scales = 1,0.01,1,1,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
units = n,V,W,W,W,W,W,W,Wh,Wh,Wh,Wh,Wh,Wh,C,C,C,p
Here is a relevant section of the emonHub log
2023-12-08 15:41:15,777 DEBUG RFM69Pi 1230 NEW FRAME : OK 17 241 0 0 0 192 93 11 0 5 0 6 0 2 0 2 0 2 0 7 0 0 0 3 0 0 0 3 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 48 117 48 117 48 117 0 0 0 0 (-72)
2023-12-08 15:41:15,781 DEBUG RFM69Pi 1230 Timestamp : 1702050075.777298
2023-12-08 15:41:15,782 DEBUG RFM69Pi 1230 From Node : 17
2023-12-08 15:41:15,782 DEBUG RFM69Pi 1230 Values : [241, 240, 11, 5, 6, 2, 2, 2, 7, 3, 3, 1, 0.01, 0.01, 300, 30000, 30000, 0, 0, 0.0]
2023-12-08 15:41:15,783 DEBUG RFM69Pi 1230 RSSI : -72
2023-12-08 15:41:15,784 DEBUG RFM69Pi 1230 Sent to channel(start)' : ToEmonCMS
2023-12-08 15:41:15,784 DEBUG RFM69Pi 1230 Sent to channel(end)' : ToEmonCMS
2023-12-08 15:41:15,882 DEBUG MQTT Publishing: emon/emonTx4_17/MSG 241
2023-12-08 15:41:15,884 DEBUG MQTT Publishing: emon/emonTx4_17/Vrms 240
2023-12-08 15:41:15,885 DEBUG MQTT Publishing: emon/emonTx4_17/P1 11
2023-12-08 15:41:15,886 DEBUG MQTT Publishing: emon/emonTx4_17/P2 5
2023-12-08 15:41:15,888 DEBUG MQTT Publishing: emon/emonTx4_17/P3 6
2023-12-08 15:41:15,889 DEBUG MQTT Publishing: emon/emonTx4_17/P4 2
2023-12-08 15:41:15,891 DEBUG MQTT Publishing: emon/emonTx4_17/P5 2
2023-12-08 15:41:15,892 DEBUG MQTT Publishing: emon/emonTx4_17/P6 2
2023-12-08 15:41:15,893 DEBUG MQTT Publishing: emon/emonTx4_17/E1 7
2023-12-08 15:41:15,894 DEBUG MQTT Publishing: emon/emonTx4_17/E2 3
2023-12-08 15:41:15,895 DEBUG MQTT Publishing: emon/emonTx4_17/E3 3
2023-12-08 15:41:15,897 DEBUG MQTT Publishing: emon/emonTx4_17/E4 1
2023-12-08 15:41:15,898 DEBUG MQTT Publishing: emon/emonTx4_17/E5 0.01
2023-12-08 15:41:15,899 DEBUG MQTT Publishing: emon/emonTx4_17/E6 0.01
2023-12-08 15:41:15,900 DEBUG MQTT Publishing: emon/emonTx4_17/T1 300
2023-12-08 15:41:15,902 DEBUG MQTT Publishing: emon/emonTx4_17/T2 30000
2023-12-08 15:41:15,903 DEBUG MQTT Publishing: emon/emonTx4_17/T3 30000
2023-12-08 15:41:15,904 DEBUG MQTT Publishing: emon/emonTx4_17/pulse 0
2023-12-08 15:41:15,905 DEBUG MQTT Publishing: emon/emonTx4_17/missed 0
2023-12-08 15:41:15,906 DEBUG MQTT Publishing: emon/emonTx4_17/missedprc 0.0
2023-12-08 15:41:15,908 DEBUG MQTT Publishing: emon/emonTx4_17/rssi -72
2023-12-08 15:41:15,909 INFO MQTT Publishing 'node' formatted msg
2023-12-08 15:41:15,909 DEBUG MQTT Publishing: emonhub/rx/17/values 241,240,11,5,6,2,2,2,7,3,3,1,0.01,0.01,300,30000,30000,0,0,0.0,-72
This shows the three temperature data all being received as two hex bytes of 48 117 which translates to 117*256+48=30000. However, the first is published as 300, but the second and third are published as 30000?
@TrystanLea Any thoughts?
