I ordered my emonTX v4 last weekend. Just awaiting the Royal Mail…
Does anyone have any experience of connecting an emonTX to an OPNSense computer? I have an old Raspberry PI /somewhere/ (2 or 3, can’t remember) but as I already have a computer next to the consumer unit, I was wondering if I could get this working in a FreeBSD jail?
To add to Bills reply, we have an install script for Emoncms and it’s dependencies here GitHub - openenergymonitor/EmonScripts: Emoncms Stack Installation and Update scripts This has replaced all the older emoncms install guides as there were so many steps. If you need to install step by step, reviewing the content in the scripts is probably your best bet.
It depends if you are intending to run the monitoring SW (EmonCMS) on it or just extract the data and send that on to a different machine running EmonCMS or another monitoring SW solution.
For now, I’ve not ordered anything else. I had understood I could hook it up via USB tty to something I already had and use that to fire at CMS. I ideally want to avoid another piece of kit since I have a fully functioning PC right next to where the consumer unit is.
I’ll probably stick EmonCMS in AWS or on a VM somewhere so I think I just need to get the USB piped into a jail running the script (name escapes me) that takes the USB data and throws it at EmonCMS.
