I loaded emonSD-24Jul20.img on to the RPiZero, and emonTx V3.4 EmonLibCM on to the emonTx.
jjb@MacBook-Pro ~ % ssh [email protected]
[email protected]'s password:
Linux emonpi 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Mar 4 08:30:17 2021 from 192.168.2.33
pi@emonpi:~ $ miniterm --rtscts /dev/ttyAMA0 115200
--- Miniterm on /dev/ttyAMA0 115200,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
emonTx V3.4 EmonLibCM Continuous Monitoring V2.00
OpenEnergyMonitor.org
ERROR EEPROM config contains 3 invalid values
Consider restoring defaults and re-applying config.
Loaded EEPROM config
Settings:
Group 210, Node 15, Band 433 MHz
Calibration:
vCal = 0.00
assumedV = 224.00
i1Cal = 0.00
i1Lead = 0.00
i2Cal = 0.00
i2Lead = 0.00
i3Cal = 0.00
i3Lead = 3.00
i4Cal = 8.33
i4Lead = 3.00
datalog = 8.94
pulses = 1
pulse period = 100
�����enable = 0
����������������������������������enable = 0 of 1
����������������������������������������������������������������������������������������������������������������enable = NOT��������������������������������������������������������������������������������������������������������������������������enable =
RF whitened
RFM69CW only Node: 15 Freq: 433MHz Group: 210
POST.....wait 10s
'+++' then [Enter] for config mode
CT1 detected, i1Cal:0.00
CT2 detected, i2Cal:0.00
AC present
MSG:1,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:2,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:3,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:4,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:5,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:6,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:7,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:8,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:9,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
MSG:10,Vrms:0.00,P1:0,P2:0,E1:0,E2:0,T1:0.00,T2:0.00,T3:0.00,pulse:0
Is the EEPROM error important here?
I don’t know what the black question mark characters mean. It looks like both CT sensors are being picked up. Does assumedV mean it is seeing that voltage, or just assuming it?
TIA
