Another problem.
This is an out of the box emonBase I am setting up (not the previous one), including the pre loaded SD card.
I fired it up, changed the root password, and went into node red to add an MQTT node I have used on my previous emonBase to subscribe to emon/# topic as I have done before. This time however, it is saying ‘disconnected’
In my log file, it is saying it is it is publishing:
2017-12-07 00:35:15,188 DEBUG MQTT Publishing: emon/powerNode-2-1/vrms 4.57
I had a dig around some log files and in mosquitto.log I found this:
[email protected](ro):mosquitto$ sudo tail mosquitto.log
1512606261: Socket error on client , disconnecting.
1512606284: New connection from 127.0.0.1 on port 1883.
1512606284: Socket error on client , disconnecting.
1512606371: New connection from 127.0.0.1 on port 1883.
1512606371: Socket error on client , disconnecting.
emoncms.log
2017-12-07 10:22:04.346|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#0 /var/www/emoncms/scripts/phpmqtt_input.php(112): Mosquitto\Client->loop()
#1 {main}
2017-12-07 10:22:04.415|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' in /var/www/emoncms/scripts/phpmqtt_input.php:121
Stack trace:
#0 /var/www/emoncms/scripts/phpmqtt_input.php(121): Mosquitto\Client->connect('localhost', 1883, 5)
#1 {main}
2017-12-07 10:22:04.416|WARN|phpmqtt_input.php|Not connected, retrying connection
2017-12-07 10:22:05.418|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:06.420|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:07.423|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:08.425|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.428|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.430|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.431|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.433|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.435|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.436|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.438|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-07 10:22:09.440|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
Any ideas?
