I have two RFM69Pis on two separate Raspberry Pis. Both Pis are located in physically the same location. Both RFM69Pis are working and getting data from all my nodes, except for my emonTx on node 10, which is showing up on one of the RFM69Pis, but not the other.
Here is the minicom output from the RFM69Pi that sees node 10, with the version and config dump.
[RF12demo.12] O i15 g210 @ 433 MHz q1
OK 22 20 0 0 0 34 13 (-39)
OK 26 123 3 225 1 65 11 221 12 (-71)
OK 23 120 75 85 13 14 0 0 0 (-60)
OK 10 118 253 112 253 136 8 0 0 251 46 0 0 0 0 0 0 0 0 0 0 0 0 5 0 (-38)
OK 1 73 0 73 0 0 0 (-77)
OK 20 243 0 0 0 146 1 24 0 (-43)
OK 23 121 75 75 13 16 0 0 0 (-61)
OK 1 73 0 73 0 0 0 (-72)
OK 26 123 3 227 1 65 11 221 12 (-70)
OK 22 22 0 0 0 106 13 (-39)
OK 1 73 0 73 0 0 0 (-76)
OK 23 122 75 221 12 15 0 0 0 (-60)
OK 10 88 252 140 252 101 10 0 0 233 46 0 0 0 0 0 0 0 0 0 0 0 0 5 0 (-38)
Here is the minicom output from the RFM69Pi that does not see node 10, with the version and configuration dump.
[RF12demo.14] B i2 g210 @ 434 MHz q1
OK 23 122 75 221 12 15 0 0 0 (-64)
OK 23 123 75 64 13 15 0 0 0 (-61)
OK 19 202 0 0 0 232 1 25 0 (-50)
OK 13 101 6 155 12 (-52)
OK 1 73 0 73 0 0 0 (-74)
OK 22 21 0 0 0 95 13 (-47)
OK 23 124 75 24 13 14 0 0 0 (-60)
OK 21 241 0 0 0 181 1 25 0 (-54)
OK 26 123 3 233 1 65 11 221 12 (-83)
OK 1 73 0 73 0 0 0 (-75)
OK 23 125 75 34 13 15 0 0 0 (-60)
OK 22 22 0 0 0 95 13 (-48)
OK 23 126 75 54 13 15 0 0 0 (-59)
The RFM69Pi that sees node 10 is running the factory firmware that came with it when it shipped to me in July of 2015, so I can’t be sure precisely what that code looks like.
The RFM69Pi that doesn’t see node 10 is running the following firmware. Any ideas?
//RFM12Pi V2 with RFM69CW Firmware
//Based on JCW RF12 Demo: https://github.com/jcw/jeelib/tree/master/examples/RF12/RF12demo
//Edited for RFM12Pi and emonPi operation June 2014 by Glyn Hudson and Trystan Lea
//http://OpenEnergyMonitor.org
//https://github.com/openenergymonitor/RFM2Pi
// V1.4 Jan 17
// Compile with platformIO and relase with GH releases using TravisCI
// V1.3 July 15 - add RF trace mode debug and fix node ID isse, merge pb66 pull requests
// https://github.com/openenergymonitor/RFM2Pi/pull/2
// https://github.com/openenergymonitor/RFM2Pi/pull/4
// Version V1.0 - Nov 2014
// * 433Mhz default frequency, 15 default node ID
// V0.9 June 2014
// * 210 default network group
// * activity LED to light on startup and each time packet is received
/// @dir RF12demo
/// Configure some values in EEPROM for easy config of the RF12 later on.
// 2009-05-06 <[email protected]> http://opensource.org/licenses/mit-license.php
// this version adds flash memory support, 2009-11-19
// Adding frequency features, author JohnO, 2013-09-05
// Major EEPROM format change, refactoring, and cleanup for v12, 2014-02-13
#define RF69_COMPAT 1 // define this to use the RF69 driver i.s.o. RF12
#include <JeeLib.h>
#include <util/crc16.h>
#include <avr/eeprom.h>
#include <avr/pgmspace.h>
#include <util/parity.h>
#define MAJOR_VERSION RF12_EEPROM_VERSION // bump when EEPROM layout changes
#define MINOR_VERSION 2 // bump on other non-trivial changes
#define VERSION "[RF12demo.14]" // keep in sync with the above
#define SERIAL_BAUD 38400 // max baud for 8Mhz RFM12Pi http://openenergymonitor.org/emon/node/6244/
#define DATAFLASH 0 // set to 0 for non-JeeLinks, else 4/8/16 (Mbit)
#define LED_PIN 9 // activity LED, comment out to disable
/// Save a few bytes of flash by declaring const if used more than once.
const char INVALID1[] PROGMEM = "\rInvalid\n";
const char INITFAIL[] PROGMEM = "config save failed\n";
#if RF69_COMPAT
byte trace_mode = 0;
#endif
#define _receivePin 8
static int _bitDelay;
static char _receive_buffer;
static byte _receive_buffer_index;
// TODO: replace with code from the std avr libc library:
// http://www.nongnu.org/avr-libc/user-manual/group__util__delay__basic.html
void whackDelay (word delay) {
byte tmp=0;
asm volatile("sbiw %0, 0x01 \n\t"
"ldi %1, 0xFF \n\t"
"cpi %A0, 0xFF \n\t"
"cpc %B0, %1 \n\t"
"brne .-10 \n\t"
"+r" (delay), "+a" (tmp)
"0" (delay)
ISR (PCINT0_vect) {
char i, d = 0;
if (digitalRead(_receivePin)) // PA2 = Jeenode DIO2
return; // not ready!
whackDelay(_bitDelay - 8);
for (i=0; i<8; i++) {
whackDelay(_bitDelay*2 - 6); // digitalread takes some time
d |= (1 << i);
whackDelay(_bitDelay*2);
if (_receive_buffer_index)
return;
_receive_buffer = d; // save data
_receive_buffer_index = 1; // got a byte
static byte inChar () {
byte d;
if (! _receive_buffer_index)
return -1;
d = _receive_buffer; // grab first and only byte
_receive_buffer_index = 0;
return d;
static unsigned long now () {
// FIXME 49-day overflow
return millis() / 1000;
static void activityLed (byte on) {
#ifdef LED_PIN
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, on);
#endif
static void printOneChar (char c) {
Serial.print(c);
/// @details
/// For the EEPROM layout, see http://jeelabs.net/projects/jeelib/wiki/RF12demo
/// Useful url: http://blog.strobotics.com.au/2009/07/27/rfm12-tutorial-part-3a/
// RF12 configuration area
typedef struct {
byte nodeId; // used by rf12_config, offset 0
byte group; // used by rf12_config, offset 1
byte format; // used by rf12_config, offset 2
byte hex_output :
2; // 0 = dec, 1 = hex, 2 = hex+ascii
byte collect_mode :
1; // 0 = ack, 1 = don't send acks
byte quiet_mode :
1; // 0 = show all, 1 = show only valid packets
byte spare_flags :
4;
word frequency_offset; // used by rf12_config, offset 4
byte pad[RF12_EEPROM_SIZE-8];
word crc;
RF12Config;
static RF12Config config;
static char cmd;
static word value;
static byte stack[RF12_MAXDATA+4], top, sendLen, dest;
static byte testCounter;
static void showNibble (byte nibble) {
char c = '0' + (nibble & 0x0F);
if (c > '9')
c += 7;
Serial.print(c);
static void showByte (byte value) {
if (config.hex_output) {
showNibble(value >> 4);
showNibble(value);
else
Serial.print((word) value);
static void showString (PGM_P s) {
for (;;) {
char c = pgm_read_byte(s++);
if (c == 0)
break;
if (c == '\n')
printOneChar('\r');
printOneChar(c);
static word calcCrc (const void* ptr, byte len) {
word crc = ~0;
for (byte i = 0; i < len; ++i)
crc = _crc16_update(crc, ((const byte*) ptr)[i]);
return crc;
static void loadConfig () {
// eeprom_read_block(&config, RF12_EEPROM_ADDR, sizeof config);
// this uses 166 bytes less flash than eeprom_read_block(), no idea why
for (byte i = 0; i < sizeof config; ++ i)
((byte*) &config)[i] = eeprom_read_byte(RF12_EEPROM_ADDR + i);
static void saveConfig () {
config.format = MAJOR_VERSION;
config.crc = calcCrc(&config, sizeof config - 2);
// eeprom_write_block(&config, RF12_EEPROM_ADDR, sizeof config);
// this uses 170 bytes less flash than eeprom_write_block(), no idea why
eeprom_write_byte(RF12_EEPROM_ADDR, ((byte*) &config)[0]);
eeprom_write_byte(RF12_EEPROM_ADDR + i, ((byte*) &config)[i]);
if (rf12_configSilent())
rf12_configDump();
else
showString(INITFAIL);
static byte bandToFreq (byte band) {
return band == 4 ? RF12_433MHZ : band == 8 ? RF12_868MHZ : band == 9 ? RF12_915MHZ : 0;
// OOK transmit code
#if RF69_COMPAT // not implemented in RF69 compatibility mode
static void fs20cmd(word house, byte addr, byte cmd) {
static void kakuSend(char addr, byte device, byte on) {
#else
// Turn transmitter on or off, but also apply asymmetric correction and account
// for 25 us SPI overhead to end up with the proper on-the-air pulse widths.
// With thanks to JGJ Veken for his help in getting these values right.
static void ookPulse(int on, int off) {
rf12_onOff(1);
delayMicroseconds(on + 150);
rf12_onOff(0);
delayMicroseconds(off - 200);
static void fs20sendBits(word data, byte bits) {
if (bits == 8) {
++bits;
data = (data << 1) | parity_even_bit(data);
for (word mask = bit(bits-1); mask != 0; mask >>= 1) {
int width = data & mask ? 600 : 400;
ookPulse(width, width);
byte sum = 6 + (house >> 8) + house + addr + cmd;
for (byte i = 0; i < 3; ++i) {
fs20sendBits(1, 13);
fs20sendBits(house >> 8, 8);
fs20sendBits(house, 8);
fs20sendBits(addr, 8);
fs20sendBits(cmd, 8);
fs20sendBits(sum, 8);
fs20sendBits(0, 1);
delay(10);
int cmd = 0x600 | ((device - 1) << 4) | ((addr - 1) & 0xF);
if (on)
cmd |= 0x800;
for (byte i = 0; i < 4; ++i) {
for (byte bit = 0; bit < 12; ++bit) {
ookPulse(375, 1125);
int on = bitRead(cmd, bit) ? 1125 : 375;
ookPulse(on, 1500 - on);
ookPulse(375, 375);
delay(11); // approximate
#endif
// DataFlash code
#if DATAFLASH
#include "dataflash.h"
#else // DATAFLASH
#define df_present() 0
#define df_initialize()
#define df_dump()
#define df_replay(x,y)
#define df_erase(x)
#define df_wipe()
#define df_append(x,y)
#endif
const char helpText1[] PROGMEM =
"\n"
"Available commands:\n"
" <nn> i - set node ID (standard node ids are 1..30)\n"
" <n> b - set MHz band (4 = 433, 8 = 868, 9 = 915)\n"
" <nnnn> o - change frequency offset within the band (default 1600)\n"
" 96..3903 is the range supported by the RFM12B\n"
" <nnn> g - set network group (RFM12 only allows 212, 0 = any)\n"
" <n> c - set collect mode (advanced, normally 0)\n"
" t - broadcast max-size test packet, request ack\n"
" ...,<nn> a - send data packet to node <nn>, request ack\n"
" ...,<nn> s - send data packet to node <nn>, no ack\n"
" <n> q - set quiet mode (1 = don't report bad packets)\n"
" <n> x - set reporting format (0: decimal, 1: hex, 2: hex+ascii)\n"
#if RF69_COMPAT
" <nnn> y - enable signal strength trace mode, default:0 (disabled)\n"
" sample interval <nnn> secs/100 (0.01s-2.5s) eg 10y=0.1s\n"
#endif
" 123 z - total power down, needs a reset to start up again\n"
"Remote control commands:\n"
" <hchi>,<hclo>,<addr>,<cmd> f - FS20 command (868 MHz)\n"
" <addr>,<dev>,<on> k - KAKU command (433 MHz)\n"
const char helpText2[] PROGMEM =
"Flash storage (JeeLink only):\n"
" d - dump all log markers\n"
" <sh>,<sl>,<t3>,<t2>,<t1>,<t0> r - replay from specified marker\n"
" 123,<bhi>,<blo> e - erase 4K block\n"
" 12,34 w - wipe entire flash memory\n"
static void showHelp () {
showString(helpText1);
if (df_present())
showString(helpText2);
showString(PSTR("Current configuration:\n"));
rf12_configDump();
static void handleInput (char c) {
if ('0' <= c && c <= '9') {
value = 10 * value + c - '0';
return;
if (c == ',') {
if (top < sizeof stack)
stack[top++] = value; // truncated to 8 bits
value = 0;
return;
if ('a' <= c && c <= 'z') {
showString(PSTR("> "));
for (byte i = 0; i < top; ++i) {
Serial.print((word) stack[i]);
printOneChar(',');
Serial.print(value);
Serial.println(c);
// keeping this out of the switch reduces code size (smaller branch table)
if (c == '>') {
// special case, send to specific band and group, and don't echo cmd
// input: band,group,node,header,data...
// TODO: frequency offset is taken from global config, is that ok?
rf12_initialize(stack[2], bandToFreq(stack[0]), stack[1],
config.frequency_offset);
rf12_sendNow(stack[3], stack + 4, top - 4);
rf12_sendWait(2);
rf12_configSilent();
else if (c > ' ') {
switch (c) {
case 'i': // set node id
if ((value > 0) && (value < 31)) {
config.nodeId = (config.nodeId & 0xE0) + (value & 0x1F);
saveConfig();
break;
case 'b': // set band: 4 = 433, 8 = 868, 9 = 915
value = bandToFreq(value);
if (value) {
config.nodeId = (value << 6) + (config.nodeId & 0x3F);
config.frequency_offset = 1600;
saveConfig();
break;
case 'o':
{ // Increment frequency within band
// Stay within your country's ISM spectrum management guidelines, i.e.
// allowable frequencies and their use when selecting operating frequencies.
if ((value > 95) && (value < 3904)) { // supported by RFM12B
config.frequency_offset = value;
saveConfig();
break;
case 'g': // set network group
config.group = value;
saveConfig();
break;
case 'c': // set collect mode (off = 0, on = 1)
config.collect_mode = value;
saveConfig();
break;
case 't': // broadcast a maximum size test packet, request an ack
cmd = 'a';
sendLen = RF12_MAXDATA;
dest = 0;
for (byte i = 0; i < RF12_MAXDATA; ++i)
stack[i] = i + testCounter;
showString(PSTR("test "));
showByte(testCounter); // first byte in test buffer
++testCounter;
break;
case 'a': // send packet to node ID N, request an ack
case 's': // send packet to node ID N, no ack
cmd = c;
sendLen = top;
dest = value;
break;
case 'f': // send FS20 command: <hchi>,<hclo>,<addr>,<cmd>f
rf12_initialize(0, RF12_868MHZ, 0);
activityLed(1);
fs20cmd(256 * stack[0] + stack[1], stack[2], value);
activityLed(0);
break;
case 'k': // send KAKU command: <addr>,<dev>,<on>k
rf12_initialize(0, RF12_433MHZ, 0);
activityLed(1);
kakuSend(stack[0], stack[1], value);
activityLed(0);
break;
case 'z': // put the ATmega in ultra-low power mode (reset needed)
if (value == 123) {
showString(PSTR(" Zzz...\n"));
Serial.flush();
rf12_sleep(RF12_SLEEP);
cli();
Sleepy::powerDown();
break;
case 'q': // turn quiet mode on or off (don't report bad packets)
config.quiet_mode = value;
saveConfig();
break;
case 'x': // set reporting mode to decimal (0), hex (1), hex+ascii (2)
config.hex_output = value;
saveConfig();
break;
case 'v': //display the interpreter version and configuration
displayVersion();
rf12_configDump();
break;
case 'l': // turn activity LED on or off
activityLed(value);
break;
case 'd': // dump all log markers
if (df_present())
df_dump();
break;
case 'r': // replay from specified seqnum/time marker
if (df_present()) {
word seqnum = (stack[0] << 8) | stack[1];
long asof = (stack[2] << 8) | stack[3];
asof = (asof << 16) | ((stack[4] << 8) | value);
df_replay(seqnum, asof);
break;
case 'e': // erase specified 4Kb block
if (df_present() && stack[0] == 123) {
word block = (stack[1] << 8) | value;
df_erase(block);
break;
case 'w': // wipe entire flash memory
if (df_present() && stack[0] == 12 && value == 34) {
df_wipe();
showString(PSTR("erased\n"));
break;
#if RF69_COMPAT
case 'y': // turn signal strength trace mode on or off (rfm69 only)
trace_mode = value;
break;
#endif
default:
showHelp();
value = top = 0;
static void displayASCII (const byte* data, byte count) {
for (byte i = 0; i < count; ++i) {
printOneChar(' ');
char c = (char) data[i];
printOneChar(c < ' ' || c > '~' ? '.' : c);
Serial.println();
static void displayVersion () {
showString(PSTR(VERSION));
void setup () {
activityLed(1);
delay(100); // shortened for now. Handy with JeeNode Micro V1 where ISP
// interaction can be upset by RF12B startup process.
Serial.begin(SERIAL_BAUD);
Serial.println();
displayVersion();
if (rf12_configSilent()) {
loadConfig();
else {
memset(&config, 0, sizeof config);
config.nodeId = 0x4F; // RFM12Pi - 433 MHz, node 15
config.group = 0xD2; // RFM12Pi - default group 210
config.quiet_mode = true; // Default flags, quiet on
saveConfig();
rf12_configDump();
df_initialize();
delay(1000); //rfm12pi keep LED for for 1s to show it's working at startup
activityLed(0);
void loop () {
if (Serial.available())
handleInput(Serial.read());
#if RF69_COMPAT
if (trace_mode == 0) {
#endif
if (rf12_recvDone()) {
byte n = rf12_len;
if (rf12_crc == 0)
activityLed(1);
showString(PSTR("OK"));
else {
if (config.quiet_mode)
return;
showString(PSTR(" ?"));
if (n > 20) // print at most 20 bytes if crc is wrong
n = 20;
printOneChar('X');
if (config.group == 0) {
showString(PSTR(" G"));
showByte(rf12_grp);
printOneChar(' ');
showByte(rf12_hdr & 0x1F);
for (byte i = 0; i < n; ++i) {
if (!config.hex_output)
printOneChar(' ');
showByte(rf12_data[i]);
#if RF69_COMPAT
// display RSSI value after packet data
showString(PSTR(" ("));
showByte(RF69::rssi);
else
Serial.print(-(RF69::rssi>>1));
showString(PSTR(") "));
#endif
Serial.println();
if (config.hex_output > 1) { // also print a line as ascii
showString(PSTR("ASC "));
showString(PSTR(" II "));
printOneChar(rf12_hdr & RF12_HDR_DST ? '>' : '<');
printOneChar('@' + (rf12_hdr & RF12_HDR_MASK));
displayASCII((const byte*) rf12_data, n);
if (rf12_crc == 0) {
activityLed(1);
if (df_present())
df_append((const char*) rf12_data - 2, rf12_len + 2);
if (RF12_WANTS_ACK && (config.collect_mode) == 0) {
showString(PSTR(" -> ack\n"));
rf12_sendStart(RF12_ACK_REPLY, 0, 0);
activityLed(0);
if (cmd && rf12_canSend()) {
activityLed(1);
showString(PSTR(" -> "));
Serial.print((word) sendLen);
showString(PSTR(" b\n"));
byte header = cmd == 'a' ? RF12_HDR_ACK : 0;
if (dest)
header |= RF12_HDR_DST | dest;
rf12_sendStart(header, stack, sendLen);
cmd = 0;
activityLed(0);
activityLed(0);
#if RF69_COMPAT
} else {
rf12_recvDone();
byte y = (RF69::rssi>>1);
for (byte i = 0; i < (100-y); ++i) {
printOneChar('-');
Serial.print("*");
for (byte i = 0; i < (y); ++i) {
printOneChar(' ');
Serial.print(-y);
Serial.println("dB");
delay(trace_mode*10);
#endif
