Hello Everyone, Yesterday - i try to calibrate the voltage from 234.26 to 260V as idea value using Arduino. I simply change the value to 260V and uploaded the file to EmonTX using USB to UART cable. After uploading an updated file, the led indicator turns off and there is no any power supply in a EmonTx. So, please, if there is any solution then it will be very glad to continue my work.
Next time, please attach the file to your post - it is much easier to read than a screenshot.
The change you made can not have stopped the emonTx from working. It can not have turned off the power to the emonTx.
How do you know there is no power to the emonTx? There is nothing in your sketch to flash the LED. But you should see the output on the monitor screen of the Arduino IDE.
I think your problem is, you are using a sketch for the emonTx V2. Which emonTx do you have?
In the emonTx V2, the voltage input is on Pin 2, which is what you have in your sketch. On the emonTx V3.x.x, the voltage input is Pin 0. Here is the equivalent line from the default sketch:
