Just for reference, if anyone is trying to get emonTx’s connected to an emonPi over seial, using external USB-serial adapters, I’ll attach my modified emonTx src.ino for and the emonhub.conf from the emonPi for reference.
The trick to getting the code to download to the emonTx (from linux) using either the arduino IDE or with avrdude was to connect the RTS line on the serial adapter to the RST line on the emonTx.
Of course, Rx-Rx and Tx-Tx as the Rx pin is labeled Tx (and Tx labeled Rx) on the emonTx.
The library import to get the sketch to build in the arduino IDE is available in the learn section of this site.
In teh arduino IDE, the board type was Arduino Uno and the programmer type was Atmel STK500 dev board.
src.ino (26.8 KB)
emonhub.conf:
####################### emonhub.conf #########################
### http://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[RFM2Pi]]
Type = EmonHubJeeInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 38400 # 9600 for old RFM12Pi
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
group = 210
frequency = 433
baseid = 5 # emonPi / emonBase nodeID
quiet = true # Report incomplete RF packets (no implemented on emonPi)
calibration = 230V # (UK/EU: 230V, US: 110V)
# interval = 0 # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 1
nodevar_format_enable = 1
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
apikey = 50ee889c7fccb0a165231d76cc6df4c5
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
[[SerialDirect0]]
Type = EmonHubSerialInterfacer
[[[init_settings]]]
com_port = /dev/ttyUSB0 # or /dev/ttyAMA0 or/dev/ttyACM0 etc
com_baud = 115200 # to match the baud of the connected device
[[SerialDirect1]]
[[[init_settings]]]
com_port = /dev/ttyUSB1 # or /dev/ttyAMA0 or/dev/ttyACM0 etc
####################### Nodes #######################
[nodes]
## See config user guide: http://github.com/openenergymonitor/emonhub/blob/master/configuration.md
[[5]]
nodename = emonpi
[[[rx]]]
scales = 1.0588,1.0588,1,0.010588,0.1,0.1,0.1,0.1,0.1,0.1,1
units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
nodename = emontxshield
[[[rx]]]
names = power1, power2, power3, power4, vrms
datacode = h
scales = 1,1,1,1,0.01
units =W,W,W,W,V
[[7]]
nodename = emontx4
[[[rx]]]
units =W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
nodename = emontx3
[[[rx]]]
[[9]]
nodename = emontx2
[[[rx]]]
[[10]]
nodename = emontx1
[[[rx]]]
datacode = h
[[19]]
nodename = emonth1
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacode = h
scales = 0.1,0.1,0.1,0.1
units = C,C,%,V
[[20]]
nodename = emonth2
[[[rx]]]
datacode = h
units = C,C,%,V
[[21]]
nodename = emonth3
[[[rx]]]
datacode = h
units = C,C,%,V
[[22]]
nodename = emonth4
[[[rx]]]
datacode = h
units = C,C,%,V
[[23]]
nodename = emonth5
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
[[24]]
nodename = emonth6
[[[rx]]]
units = C,C,%,V,p
[[25]]
nodename = emonth7
[[[rx]]]
units = C,C,%,V,p
[[26]]
nodename = emonth8
[[[rx]]]
units = C,C,%,V,p
