I flashed emontx v3 direct serial ino in Arduino Uno …on Arduino serial monitor data shows correctly but Serial data won’t show on emonesp data tab except emontx serial
Hello @sajjad_ali
What does the serial data from the emonTx v3 look like, it might not be the right format, it needs to be key: value, pairs. Can you try the main emonTx3 firmware? emontx3/firmware/emonTx34/emonTx34_CM at master · openenergymonitor/emontx3 · GitHub
