The numbers quoted come from the data sheet, so even if you measure yours, while it might be ‘typical’, it also might not be, and what the data sheet is saying is Silicon Labs don’t give any guarantee of performance outside the range they state.
I think I’ll still use it to measure OA RH, the specs are quite good and the price/spec ratio is excellent, in fact comparable to sensors costing >$500. Long term usage may be the issue, but time will tell.
