Dear members,
after upgrading to 10.2.7 I got my emonhub decoding humidity and battery data from emonth devices with many decimals places .
Emonhub reports :
2021-03-19 23:42:18,095 DEBUG RFM2Pi 55502 NEW FRAME : OK 23 205 0 0 0 153 1 29 0 1 0 0 0 (-68)
2021-03-19 23:42:18,096 DEBUG RFM2Pi 55502 Timestamp : 1616193738.095091
2021-03-19 23:42:18,097 DEBUG RFM2Pi 55502 From Node : 23
2021-03-19 23:42:18,097 DEBUG RFM2Pi 55502 Values : [20.5, 0, 40.900000000000006, 2.9000000000000004, 1]
2021-03-19 23:42:18,097 DEBUG RFM2Pi 55502 RSSI : -68
2021-03-19 23:42:18,098 DEBUG RFM2Pi 55502 Sent to channel(start)' : ToEmonCMS
2021-03-19 23:42:18,098 DEBUG RFM2Pi 55502 Sent to channel(end)' : ToEmonCMS
2021-03-19 23:42:18,355 DEBUG MQTT Publishing: emon/emonth5/temperature 20.5
2021-03-19 23:42:18,356 DEBUG MQTT Publishing: emon/emonth5/external temperature 0
2021-03-19 23:42:18,357 DEBUG MQTT Publishing: emon/emonth5/humidity 40.900000000000006
2021-03-19 23:42:18,358 DEBUG MQTT Publishing: emon/emonth5/battery 2.9000000000000004
2021-03-19 23:42:18,359 DEBUG MQTT Publishing: emon/emonth5/pulsecount 1
2021-03-19 23:42:18,360 DEBUG MQTT Publishing: emon/emonth5/rssi -68
and emonhub configuration related to emonth5 is:
[[23]]
nodename = emonth5
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
Could you help on having only one decimal place ?
Thanks in advance
Formatted text. BT, Moderator
