emonSD next steps: filesystem & logrotate
Ok. The issue then is that it is not just emonhub log entries saved in daemon.log - all services default to writing log entries to that file.
I’ve developed a mechanism to isolate the emonhub log entries here emonSD next steps: emonhub logging which might be worth investigating.
Can you explain what you mean here?
One of the problems is the rate of logging fills the logs. For emonhub at least, I don’t think there is an appetite to reduce the granularity, just a means of managing it. I also think we need to cater for worst case i.e. maximum logging.
Are you still running hourly logrotates?
