I’ve shrunk it to fit an 8 GB card, and written it up - somewhere. It’s tortuous and while 8 GB and for that matter 16 GB cards are hard to find, I can’t understand why the image has to be made for a specific size of card, as it’s a whole lot easier to expand the image than shrink it.
Here’s what I did - it was on a Staff-only topic:
I followed
from the heading:
Shrinking images on Linux
to the bottom. Where it states:
Now notice a few things:
- There is one partition.
- The partition allocates the entire disk/device/image.
that’s not correct, it showed all the usual partitions. At that stage, I used GParted to resize the 10 GB partition only down to not very much (i.e. so that the total was well below 8 GB, then finally, when it was on the 8 GB SD card, expanded it again with GParted to fill the card).
Those who study the details will warn that the card will wear faster because there’s less free space where wear-levelling can take place, so this is something to bear in mind. If you value your data (rather than just testing/experimenting), then I’d suggest go with the type of card we use in The Shop.
