emonSD-06Mar24 ERROR: emonSD base image old or undefined
Hello,
I´m running on my Raspberry Pi 400 the local emoncms and couldn´t update that.
The Raspberry debian is up to date
Can someone help me?
- emonSD version: emonSD-06Mar24<br />
- supported images: emonSD-01Feb24 emonSD-20Nov23 emonSD-10Nov22 emonSD-21Jul21 emonSD-08May21 emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19<br />
ERROR: emonSD base image old or undefined...update will not continue<br />
See latest verson: https://github.com/openenergymonitor/emonpi/wiki/emonSD-pre-built-SD-card-Download-&-Change-Log<br />
Stopping update</details><br />
Thanks and best regards
I was hoping an emonCMS expert would answer you, because I don’t know much about emonCMS.
I think you must be updating the 30 Oct 2018 or earlier version. I think what you must do is run a full backup of your data, and then restore to the latest version. I would recommend you use a new SD Card and download and flash the latest image, rather than erasing and re-flashing the present card.
Setup → Backup → Export (tab). Click ‘Create backup’, wait and then download the file to another computer.
Alternatively, if you have a USB SD card reader you can connect to the Raspberry Pi, you can use the ‘Import USB’ tab instead.
Thanks, but your answer I cannot understand.
My version is the emonSD-06Mar24 and not from 2018.
Do the version is nearly new would I say.
Is there any expert who can help me?
Best regards
I don’t know which method it uses to recognise the version you have.
Look to see if you have this file in the ‘bootfs’ partition of your SD Card.
One of the ways is to check this file exists. I suspect it does not know “emonSD-06Mar24” is a valid name, because this version is not listed here.
If you do not have the file, make an empty file in the root of that partition called “emonSD-01Feb24” and try the update again.
If that does not help, we will ask @TrystanLea. In any case, he needs to know about the problem.
@TrystanLea 06Mar24 is not on the safe update list. Neither is 06Jan25 (although that isn’t listed in the docs).
raw.githubusercontent.com/openenergymonitor/EmonScripts/master/safe-update
emonSD-01Feb24
emonSD-20Nov23
emonSD-10Nov22
emonSD-21Jul21
emonSD-08May21
emonSD-24Jul20
emonSD-02Oct19
emonSD-17Oct19
Error: emonSD base image old or undefined with image emonSD-06Jan25 · Issue #200 · openenergymonitor/EmonScripts
The problem is (I think) that if you create the image with Emonscripts, it sets the date to today’s date which isn’t a recognised Image :man_facepalming:
Ah - is that the mechanism then? I couldn’t work out how @Ulf had an image that was not on the list. Do you know if it looks for the file - I know Trystan writes that this is the way for people to identify the SD download - in which case my suggestion of creating a file should work.
The issue here is that EmonScripts install script generates a new image date that is custom to that particular build, @Ulf and @mnbf9rca both installed using the EmonScripts install script, hence the creation of an image date that’s not familiar.
The quick solution is to rename the image filename in the boot partition to match one that’s on the available images list. Perhaps a better solution would be to have a custom build image key in that list something like emonSD-custom-build and have EmonScripts generate that file for custom builds…?
A much better idea. Or keep the actual build date if this is important, and append ‘custom’ - then look for “custom” when testing for suitability. This will retain the individuality and avoid two potentially completely different builds from appearing to be the same, and if you parse the file name out and make it a date-time, you can still know if it can or can’t be updated.
“custom” needs to appear in the error message and logs too, of course.
Yes it needs something like this. You could parse the date and check it isn’t too old.
Me neither!
@Robert.Wall & @borpin & @TrystanLea
Thanks to you.
You are right. I used the install skript and the install date would written. - crazy for my understaning..
I renamed the file like this via SSH:
sudo mv /boot/emonSD* /boot/emonSD-01Feb24
Hope it helps also others.
I agree completely. At least,now we all know what the problem is and how to work around it.
I sort of understand why, but unexpected consequence law kicks in.
