I have the same issue but “systemctl status emonPiLCD.service” and rebooting a few times didn’t solve it. What do you suggest?
Thanks,
Kevin.
Thanks,
Kevin.
Have you run an update? I think a couple of changes have been made to the LCD script and it may be that?
What is the output from systemctl status emonPiLCD.service
Hi Brian,
Thanks for your reply.
Yes I ran the update yesterday, it started showing as exited halfway through the update and hasn’t worked since.
Here’s the output…
pi@emonpi:~ $ systemctl status emonPiLCD.service
● emonPiLCD.service - LSB: emonPi LCD controller
Loaded: loaded (/etc/init.d/emonPiLCD; generated; vendor preset: enabled)
Active: active (exited) since Sun 2020-08-09 17:48:49 UTC; 15h ago
Docs: man:systemd-sysv-generator(8)
Process: 1181 ExecStop=/etc/init.d/emonPiLCD stop (code=exited, status=0/SUCCE
Process: 1189 ExecStart=/etc/init.d/emonPiLCD start (code=exited, status=0/SUC
CGroup: /system.slice/emonPiLCD.service
Aug 09 17:48:49 emonpi systemd[1]: Starting LSB: emonPi LCD controller…
Aug 09 17:48:49 emonpi emonPiLCD[1189]: Starting system emonPiLCD daemon:.
Aug 09 17:48:49 emonpi systemd[1]: Started LSB: emonPi LCD controller.
lines 1-11/11 (END)…skipping…
Process: 1181 ExecStop=/etc/init.d/emonPiLCD stop (code=exited, status=0/SUCCESS)
Process: 1189 ExecStart=/etc/init.d/emonPiLCD start (code=exited, status=0/SUCCESS)
Thanks,
Kevin.
Can you post the update log, please? Also if you widen the SSH window, there is probably more info.
For future reference, when posting code or bash output, put in 3 ‘backticks’ (found at the top left of the keyboard normally) on a line on their own, then the code, then 3 more backticks on a line following the code.
code
If it is something like php you can add a language identifier that after the first 3 backticks so ```php
Hi Brian,
Thanks again for your help on this.
I widened the putty window…
Active: active (exited) since Sun 2020-08-09 17:48:49 UTC; 19h ago
Aug 09 17:48:49 emonpi systemd[1]: Starting LSB: emonPi LCD controller...
Heres the update log…
Starting update via service-runner-update.sh (v2.0) >
- emonSD version: emonSD-30Oct18
emonSD base image check passed...continue update
git pull /home/pi/emonpi
enable-ssh
enable-ssh-button
gpiozero-enable-ssh
greeebs-patch-1
* master
python-systemd-servicerunner
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
Already up-to-date.
Main Update Script
Date: Sun 9 Aug 16:49:28 UTC 2020
EUID: 1000
usrdir: /home/pi
type: all
firmware: none
Checking environment:
- pi user found
EUID: 1000
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Reading package lists...
Building dependency tree...
Reading state information...
rng-tools is already the newest version (2-unofficial-mt.14-1).
python-gpiozero is already the newest version (1.5.0).
python-rpi.gpio is already the newest version (0.6.5~stretch-1).
0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
git pull /home/pi/RFM2Pi
* master
On branch master
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
* emon-pi
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
Already up-to-date.
Creating emonhub logfile
Symlinking emonhub.conf to /etc/emonhub/emonhub.conf
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- emoncms directory: /var/www/emoncms
current settings.php md5: 59e80f731935867f5f93753d49c0fe86
Default settings.php md5: 59e80f731935867f5f93753d49c0fe86
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
Fetching origin
- git branch: stable
- no local changes
- running: git pull origin stable
Branch stable set up to track remote branch stable from origin.
Already up-to-date.
NEW default settings.php md5: 59e80f731935867f5f93753d49c0fe86
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
Fetching origin
- git tags: 2.1.6
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/config module
Fetching origin
- git tags: 2.0.5-6-gd28ff1e
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/dashboard module
Fetching origin
- git tags: 2.0.8
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/device module
Fetching origin
- git tags: 2.0.6
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/graph module
Fetching origin
- git tags: 2.0.9-3-g6c18b0c
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/wifi module
Fetching origin
- git tags: 2.0.3
- no local changes
Already up-to-date.
Updating postprocess module
Fetching origin
- git tags: 2.1.4
- no local changes
Already up-to-date.
Updating sync module
Fetching origin
- git tags: 2.0.5-3-g109816f
- no local changes
Already up-to-date.
Updating backup module
Fetching origin
- git tags: 2.2.4
- no local changes
Already up-to-date.
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
/home/pi/emonpi/sudoers.d/emoncms-rebootbutton: parsed OK
emoncms-rebootbutton sudoers entry installed
/home/pi/emonpi/sudoers.d/emoncms-filesystem: parsed OK
emoncms-filesystem sudoers entry installed
/home/pi/emonpi/sudoers.d/wifi-sudoers: parsed OK
wifi-sudoers sudoers entry installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
Symlinking emonpiupdate.log
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
Emoncms update script complete
Starting emonPi LCD service..
emonPi update done: Sun 9 Aug 16:50:32 UTC 2020
restarting service-runner
service-runner: no process found
Thank-you,
Kevin.
I moved topic because this is a different issue I suspect.
The update seems to have worked but this is the older stretch image and that may be causing issues (@TrystanLea note).
The simplest solution is to get a new SD Card, flash the new image and import all your data dashboards etc. Beware, on first boot, wait a good long while for updates to complete.
There are now a lot of changes to the underlying structure, Python version etc that are getting increasingly difficult to ensure work on the Oct18 image.
As I don’t have that image and there are no obvious errors anywhere, I’m not sure where the issue lies.
Thanks Brian, I will give it a go and report back.
FYI
@borpin I have just encountered a similar issue, having just done an update but, noting your comment
this is on emonpiRelease: emonSD-17Oct19, so not an old one.
I’ve read the split topic, so…
● emonPiLCD.service - emonPi LCD driver
Loaded: loaded (/opt/openenergymonitor/emonpi/lcd/emonPiLCD.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2020-09-23 15:25:39 BST; 18min ago
Process: 717 ExecStartPre=/bin/mkdir -p ${LOG_PATH}/ (code=exited, status=0/SUCCESS)
Process: 719 ExecStartPre=/bin/chgrp -R pi ${LOG_PATH}/ (code=exited, status=0/SUCCESS)
Process: 720 ExecStartPre=/bin/chmod 775 ${LOG_PATH}/ (code=exited, status=0/SUCCESS)
Process: 721 ExecStart=/usr/bin/python3 /opt/openenergymonitor/emonpi/lcd/emonPiLCD.py --logfile=${LOG_PATH}/emonpilcd.log (c
Main PID: 721 (code=exited, status=1/FAILURE)
Sep 23 15:25:39 emonpi systemd[1]: emonPiLCD.service: Service RestartSec=100ms expired, scheduling restart.
Sep 23 15:25:39 emonpi systemd[1]: emonPiLCD.service: Scheduled restart job, restart counter is at 5.
Sep 23 15:25:39 emonpi systemd[1]: Stopped emonPi LCD driver.
Sep 23 15:25:39 emonpi systemd[1]: emonPiLCD.service: Start request repeated too quickly.
Sep 23 15:25:39 emonpi systemd[1]: emonPiLCD.service: Failed with result 'exit-code'.
Sep 23 15:25:39 emonpi systemd[1]: Failed to start emonPi LCD driver.
lines 1-15/15 (END)
I can post the whole update log if needed, but the LCD Update section might be a help in diagnosing?
EmonPi LCD Update
i2c-tools is already the newest version (4.1-1).
The following additional packages will be installed:
python3-colorzero python3-spidev rpi.gpio-common
Suggested packages:
python-gpiozero-docs python-spidev-doc
The following NEW packages will be installed:
python3-colorzero python3-gpiozero python3-rpi.gpio python3-smbus
0 upgraded, 6 newly installed, 0 to remove and 159 not upgraded.
Need to get 166 kB of archives.
After this operation, 887 kB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian buster/main armhf rpi.gpio-common armhf 0.7.0-0.1~bpo10+1 [5,776 B]
Get:2 http://archive.raspberrypi.org/debian buster/main armhf python3-rpi.gpio armhf 0.7.0-0.1~bpo10+1 [20.7 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf python3-spidev armhf 20190221~182651-1 [11.2 kB]
Get:4 http://archive.raspberrypi.org/debian buster/main armhf python3-colorzero all 1.1 [21.5 kB]
Get:5 http://archive.raspberrypi.org/debian buster/main armhf python3-gpiozero all 1.5.1 [94.9 kB]
Get:6 http://raspbian.mirror.uk.sargasso.net/raspbian buster/main armhf python3-smbus armhf 4.1-1 [11.7 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 166 kB in 0s (383 kB/s)
E: Sub-process /usr/bin/dpkg received a segmentation fault.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting redis
Downloading https://files.pythonhosted.org/packages/a7/7c/24fb0511df653cf1a5d938d8f5d19802a88cef255706fdda242ff97e91b7/redis-3.5.3-py2.py3-none-any.whl (72kB)
Requirement already satisfied: paho-mqtt in /usr/local/lib/python3.7/dist-packages (1.5.0)
Collecting xmltodict
Downloading https://files.pythonhosted.org/packages/28/fd/30d5c1d3ac29ce229f6bdc40bbc20b28f716e8b363140c26eff19122d8a5/xmltodict-0.12.0-py2.py3-none-any.whl
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
Installing collected packages: redis, xmltodict
Successfully installed redis-3.5.3 xmltodict-0.12.0
- reinstalling emonPiLCD.service
Removed /etc/systemd/system/multi-user.target.wants/emonPiLCD.service.
- installing emonPiLCD.service
Created symlink /etc/systemd/system/multi-user.target.wants/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.
Created symlink /etc/systemd/system/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.
- Service ActiveState=active
emonPi update done: Wed 23 Sep 14:56:19 BST 2020
I was just about to update to the latest emonSD image anyway, so it’s not a problem but I thought you would like to know it’s a potential problem with Oct19 too.
Couple things to try if the system is still up.
Does it generate an error? This might be seen in syslog from the service restarts.
Secondly, try running the update a second time?
Cheers
Yes system is still up.
pi@emonpi:~ $ python3 /opt/openenergymonitor/emonpi/lcd/emonPiLCD.py
File "/opt/openenergymonitor/emonpi/lcd/emonPiLCD.py", line 20, in <module>
from gpiozero import Button
ModuleNotFoundError: No module named 'gpiozero'
Not sure what you mean, sorry not that competent.
Ready to run update again…
It looks like gpiozero
is not installed.
try
sudo apt-get install python3-gpiozero
then rerun the LCD command
Oh dear. Might be time for new emonSD image…
Odd though, I only reinstalled quite recently.
pi@emonpi:~ $ sudo apt-get install python3-gpiozero
Reading package lists... Done
Reading state information... Done
python3-colorzero python3-rpi.gpio python3-spidev rpi.gpio-common
Suggested packages:
python3-colorzero python3-gpiozero python3-rpi.gpio python3-spidev rpi.gpio-common
0 upgraded, 5 newly installed, 0 to remove and 159 not upgraded.
Need to get 0 B/154 kB of archives.
After this operation, 836 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
E: Sub-process /usr/bin/dpkg exited unexpectedly
Could be. Check free space. Backups were going to the wrong partition at one point.
Free space is ok. I’ll try the newest image on a fresh SD card, and import from SD card…
Thanks for looking into it.
Many thanks @borpin - this worked for me.
