marco
(marco)
24 June 2019 10:17
#1
Hallo!
Mein Englisch ist nicht das beste, daher in zwei sprachen…
Ich habe das emonpi Solar Paket, leider habe ich ein Problem.
originalzustand.
Das system läuft einige Stunden. dann werden keine Eingänge mehr gelesen.
Nach einem Neustart des emonPi funktioniert es einige Stunden und Stoppt dann wieder…
Was kann ich tun?
Hello!
My English is not the best, so in two languages …
I have the emonpi solar package, unfortunately I have a problem.
original state.
The system runs for several hours. then no inputs are read.
After a restart of the emonPi it works a few hours and then stops again …
What can I do?
borpin
(Brian Orpin)
24 June 2019 11:25
#2
Is the system fully up to date? Run a full update from the admin screen and post the update log please.
marco
(marco)
24 June 2019 12:00
#3
Hallo!
Thank you!
i have run a full update…
i am a new user in this forum
I can not post Log file with the links and can not
t upload attachments.
marco
(marco)
24 June 2019 12:02
#4
now it works again …
Hope he will not stop again.
maybe this problem is already solved?
borpin
(Brian Orpin)
24 June 2019 12:21
#5
Possibly.
I have increased your privileges.
You can post the text output. Format it using 3 backticks on a line before the log output and again on a line afterwards.
marco
(marco)
24 June 2019 12:24
#6
Thank you!
Starting update via service-runner-update.sh (v2.0) >
- emonSD version: emonSD-30Oct18
emonSD base image check passed...continue update
git pull /home/pi/emonpi
enable-ssh
enable-ssh-button
gpiozero-enable-ssh
greeebs-patch-1
* master
python-systemd-servicerunner
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
From https://github.com/openenergymonitor/emonpi
b8c057f..0a0c6ba master -> origin/master
Updating b8c057f..0a0c6ba
Fast-forward
defaults/etc/emonhub/emonhub.env | 3 ---
update/emonhub.sh | 19 +++++++++++++++----
2 files changed, 15 insertions(+), 7 deletions(-)
delete mode 100644 defaults/etc/emonhub/emonhub.env
Main Update Script
Date: Mon 24 Jun 11:52:56 UTC 2019
EUID: 1000
usrdir: /home/pi
type: all
firmware: emonpi
Checking environment:
- pi user found
EUID: 1000
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD DETECTED Ox27
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Fetched 11.7 MB in 17s (660 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
rng-tools is already the newest version (2-unofficial-mt.14-1).
python-gpiozero is already the newest version (1.5.0).
python-rpi.gpio is already the newest version (0.6.5~stretch-1).
0 upgraded, 0 newly installed, 0 to remove and 121 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
git pull /home/pi/RFM2Pi
* master
On branch master
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
EmonPi Firmware Update
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/home/pi/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/home/pi/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (17886 bytes):
Writing | ################################################## | 100% 2.48s
avrdude-original: 17886 bytes of flash written
avrdude-original: verifying flash memory against /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex contains 17886 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.87s
avrdude-original: verifying ...
avrdude-original: 17886 bytes of flash verified
strace: |autoreset: Broken pipe
avrdude-original done. Thank you.
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
* emon-pi
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
From https://github.com/openenergymonitor/emonhub
f850a88..ee1f537 emon-pi -> origin/emon-pi
Updating f850a88..ee1f537
Fast-forward
configuration.md | 2 +-
install.sh | 4 +++-
service/emonhub.service | 2 +-
3 files changed, 5 insertions(+), 3 deletions(-)
Creating emonhub logfile
Symlinking emonhub.conf to /etc/emonhub/emonhub.conf
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- emoncms directory: /var/www/emoncms
current settings.php md5: 0e4803a641b7784ed23edf87506ce761
Default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
From https://github.com/emoncms/emoncms
* branch stable -> FETCH_HEAD
Already up-to-date.
NEW default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 1.2.0-108-g6e5016a
- no local changes
From https://github.com/emoncms/app
Already up-to-date.
Updating /var/www/emoncms/Modules/config module
- git tags: 1.0.0-63-g1d9238e
- no local changes
From https://github.com/emoncms/config
Already up-to-date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 1.3.1-115-gabd1a0b
- no local changes
From https://github.com/emoncms/dashboard
abd1a0b..337df80 stable -> origin/stable
Updating abd1a0b..337df80
Fast-forward
Views/dashboard_list.php | 318 +++++--
dashboard_controller.php | 8 +-
dashboard_model.php | 22 +-
locale/cy_GB/LC_MESSAGES/dashboard_messages.mo | Bin 0 -> 1067 bytes
locale/cy_GB/LC_MESSAGES/dashboard_messages.po | 1203 ++++++++++++++++++++++++
module.json | 2 +-
6 files changed, 1448 insertions(+), 105 deletions(-)
create mode 100644 locale/cy_GB/LC_MESSAGES/dashboard_messages.mo
create mode 100644 locale/cy_GB/LC_MESSAGES/dashboard_messages.po
Updating /var/www/emoncms/Modules/device module
- git branch: master
- git tags: 1.1.1-48-g2ea6e74
- no local changes
- running: git pull origin master
From https://github.com/emoncms/device
* branch master -> FETCH_HEAD
Already up-to-date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 1.2.1-151-gc7f4ea9
- no local changes
From https://github.com/emoncms/graph
Already up-to-date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 1.2.0-39-gb67783d
- no local changes
From https://github.com/emoncms/wifi
Already up-to-date.
Updating postprocess module
- git branch: emonpi
- git tags: 2.1.0
- no local changes
- running: git pull origin emonpi
From https://github.com/emoncms/postprocess
3c2d737..1d25eb6 emonpi -> origin/emonpi
Updating 3c2d737..1d25eb6
Fast-forward
postprocess-module/postprocess_controller.php | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
Already on 'emonpi'
Your branch is up-to-date with 'origin/emonpi'.
Updating sync module
- git tags: 2.0.1-2-gc5eb931
- no local changes
From https://github.com/emoncms/sync
c5eb931..3ae3226 master -> origin/master
Updating c5eb931..3ae3226
Fast-forward
readme.md | 4 ++--
sync-module/sync_controller.php | 12 +++++-------
sync-module/sync_menu.php | 27 +++++++++++++++------------
sync-module/sync_view.php | 12 +-----------
4 files changed, 23 insertions(+), 32 deletions(-)
Already on 'master'
Updating backup module
- git tags: 2.0.0-12-g67a1f1d
- no local changes
From https://github.com/emoncms/backup
67a1f1d..e365ab5 master -> origin/master
Already up-to-date.
Already on 'stable'
Your branch is up-to-date with 'origin/stable'.
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
Symlinking emonpiupdate.log
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
Emoncms update script complete
Starting emonPi LCD service..
emonPi update done: Mon 24 Jun 11:54:38 UTC 2019
restarting service-runner
service-runner: no process found
borpin
(Brian Orpin)
24 June 2019 12:37
#7
The emonhub.service
file was updated so hopefully that has solved the issue.
It is the backtick you need not the apostrophe. On a UK keyboard, it is found next to the ‘1’ key top left of the keyboard. I edited your post if you want to see how it looks .
borpin:
On a UK keyboard,
Looks like Marco is in Germany.
borpin
(Brian Orpin)
24 June 2019 12:45
#9
Yes that was why I said the key would be found top left on a UK keyboard, in case a German keyboard is different in that respect as I know the Keyboard layout is different in some respects.
marco
(marco)
24 June 2019 12:58
#10
Hello!
Thank you very much for the quick support from you!
I think next time I will find the right button
best regards
Marco
