Emonpi FW version not available in emonhub
Having just set up an emonpi from the latest downloaded emonscripts generated image, I wanted to know if the front end FW had been updated (I can’t recall if I maybe played with it at some point), quickest way to see the emonpi FW version is (or so I thought) to restart emonhub whilst watching the log . . .
It seems I’m now running FW version “OK” and the emonpi’s rfm settings (baseid, group, freq and quiet mode) are “5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)”.
2021-01-27 00:27:26,987 INFO     MainThread RFM2Pi device firmware version: OK
2021-01-27 00:27:26,988 INFO     MainThread RFM2Pi device current settings:  5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
Somethings not quite right there!
I haven’t looked that deep into yet it as it’s late but wanted to note the issue for debugging.
I have run updates more than once, this is the last log. It shows I had “emonpi” FW selected for an update “all”. It shows the emonpi repo is upto date with emonpi/master, it shows a successful flash of “compiled/latest.hex” FW, so I would expect to have version 2.9.3 DS FW going by the changelog page.
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-24Jul20
- supported images: emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19
- emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Wed 27 Jan 00:45:49 GMT 2021
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: emonpi
Reading package lists...
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5+rpt1).
The following package was automatically installed and is no longer required:
rpi-eeprom-images
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 81 not upgraded.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: redis in /home/pi/.local/lib/python3.7/site-packages (3.5.3)
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
Running apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git fetch --all --prune -v
Fetching origin
From https://github.com/openenergymonitor/emonhub
= [up to date] stable -> origin/stable
= [up to date] MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
= [up to date] emon-pi -> origin/emon-pi
= [up to date] env_example -> origin/env_example
= [up to date] fix_reply_http_interfacer -> origin/fix_reply_http_interfacer
= [up to date] include_serial_number -> origin/include_serial_number
= [up to date] lanip-status -> origin/lanip-status
= [up to date] master -> origin/master
= [up to date] redis_config_interface -> origin/redis_config_interface
= [up to date] sdm120_check_keys -> origin/sdm120_check_keys
= [up to date] sdm120_datafield_config -> origin/sdm120_datafield_config
= [up to date] unitless_decoder -> origin/unitless_decoder
git status
On branch stable
Untracked files:
(use "git add ..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
git pull origin stable
* branch stable -> FETCH_HEAD
Already up to date.
Running emonhub install & update script emonSD_pi_env:1
python3-configobj is already the newest version (5.0.6-3).
python3-pymodbus is already the newest version (2.1.0+dfsg-1).
python3-serial is already the newest version (3.4-4).
bluetooth is already the newest version (5.50-1.2~deb10u1+rpt2).
libbluetooth-dev is already the newest version (5.50-1.2~deb10u1+rpt2).
rpi-eeprom-images
Requirement already satisfied: paho-mqtt in /usr/local/lib/python3.7/dist-packages (1.5.0)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
Requirement already satisfied: pybluez in /usr/local/lib/python3.7/dist-packages (0.23)
Requirement already satisfied: py-sds011 in /usr/local/lib/python3.7/dist-packages (0.9)
Requirement already satisfied: sdm_modbus in /usr/local/lib/python3.7/dist-packages (0.4.4)
Requirement already satisfied: pyserial in /usr/lib/python3/dist-packages (from py-sds011) (3.4)
Requirement already satisfied: pymodbus>=2.3.0 in /usr/local/lib/python3.7/dist-packages (from sdm_modbus) (2.4.0)
Requirement already satisfied: six>=1.15.0 in /usr/local/lib/python3.7/dist-packages (from pymodbus>=2.3.0->sdm_modbus) (1.15.0)
Requirement already satisfied: RPi.GPIO in /usr/lib/python3/dist-packages (0.7.0)
The user `emonhub' is already a member of `gpio'.
Unit /etc/systemd/system/[email protected] is masked, ignoring.
useradd: user 'emonhub' already exists
- installing emonhub.service
- Service ActiveState=active
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
Already up to date.
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.2.4-4-g7c5f348
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.5-6-gd28ff1e
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.8-9-gdc07d12
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.9-3-g6c18b0c
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.3
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.2.6
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 2.1.2-3-ga216b3d
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.4
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.5-3-g109816f
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- no local changes
Already up to date.
Already on 'stable'
Backup module installation and update script
- Loading EmonScripts config.ini
- Copying default.config.cfg to config.cfg
- Setting config.cfg settings
- Backup module symlink already exists
- PHP Version: 7.3
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- /var/opt/emoncms/backup already exists
- /var/opt/emoncms/backup/uploads already exists
- restarting apache
EmonPi LCD Update
i2c-tools is already the newest version (4.1-1).
python3-smbus is already the newest version (4.1-1).
python3-gpiozero is already the newest version (1.5.1).
python3-rpi.gpio is already the newest version (0.7.0-0.1~bpo10+4).
rpi-eeprom-images
Requirement already satisfied: xmltodict in /home/pi/.local/lib/python3.7/site-packages (0.12.0)
- reinstalling emonPiLCD.service
Removed /etc/systemd/system/emonPiLCD.service.
Removed /etc/systemd/system/multi-user.target.wants/emonPiLCD.service.
- installing emonPiLCD.service
Created symlink /etc/systemd/system/multi-user.target.wants/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.
Created symlink /etc/systemd/system/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.
EmonPi Firmware Update (Discrete Sampling)
Start ATmega328 serial upload using avrdude with latest.hex
chmod: cannot access '/var/log/emoncms/firmware.log': No such file or directory
Attempt: 1
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex
Note: progress written to logfile /var/log/emoncms/firmware.log
avrdude-original: Using autoreset DTR on GPIO Pin 7
strace: |autoreset: Broken pipe
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (18526 bytes):
Writing | ################################################## | 100% 2.64s
avrdude-original: 18526 bytes of flash written
avrdude-original: verifying flash memory against /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex contains 18526 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 2.05s
avrdude-original: verifying ...
avrdude-original: 18526 bytes of flash verified
avrdude-original done. Thank you.
SUCCESS: flash verifed
waiting for emonpi to stop controlling LCD
Starting emonPi LCD service..
emonPi update done: Wed 27 Jan 00:48:44 GMT 2021
restarting service-runner
and yet if I do a full shutdown and power cycle the lcd screen still says v2.9.2, the emonpi screen says (using the reset or rebooting doesn’t bring up the FW version screen).
Is the emonpi repo readme correct? is there a new hex for 2.9.3? has 2.9.3 FW been told it’s updated by editing the number in the sketch? These questions I will explore tomorrow maybe. Along with, why doesn’t the FW version and current status no longer work? Is it the FW or emonhub?
[Edit -So to answer my own question, it seems whilst 2.9.3 was added to the chancellor 21 days ago, the compiled hex files haven’t changed in 6mths, one mystery solved I guess]
Further to the above, having left the browser window open last night after updating again, I noticed this error this morning
and the same message grabbed with some background for context.
[edit] No matter how many times I hit the ok button this box returns immediately, I have noticed however that the update log entries have cleared, most of the lefthand menu item have disappeared and the footer has repositioned, not at the foot of the page.
perhaps it’s just a “login expiry” thing? I’ll try opening another tab to log in again and see what that does for this tab.
[edit 2] Maybe I won’t!! When I go to http://emonpi I’m presented with
which is odd since we are already communicating over LAN wifi not AP mode ! I cannot explore this rabbit hole right now, I must get on with some other stuff. May comeback to this later?
[edit 3] So, I couldn’t resist “just” clicking connect to wifi, selecting my network and adding the password. This caused the emonpi to reboot, telling me to try either “http://emonpi” or the IP displayed on the emonPi whilst rebooting. BOTH take me back to the same screen above, I’ve tried this several times and it seems to be a closed loop with no way out. I’ve cleared the cache and used an incognito browser window with the same loop occurring. Since the emonpi is already restarting each loop iteration I’m not sure how to break out of this loop. Do I ssh in a play around a bit, do I run an Ethernet cable or do I start again with a fresh 16gb image (and possibly NOT update?).
This is an absolutely vanilla image installed to a 2015 emonpi and seemed to at least work last night despite the points in my first post. I have made no changes beyond updating via the admin page with “full” and “emonpi” selected, Unfortunately I really must walk away from this for now.
[edit 4] but before I go, just to head off the obvious suggestions, yes I have been patient and allowed enough time at every juncture, I have been doing other stuff and just popping back now and again to “click update” etc.
Ok so in reverse order!
Not being able to access the emonpi/emoncms beyond the “AP or WiFi” page loop despite having a perfectly good WiFi connection (and ssh) was due to the file permissions of the wpa_supplicant.conf
pi@emonpi:~ $ ls -la /etc/wpa_supplicant/wpa_supplicant.conf
-rw------- 1 root root 200 Jan 27 11:24 /etc/wpa_supplicant/wpa_supplicant.conf
pi@emonpi:~ $ sudo chmod 644 /etc/wpa_supplicant/wpa_supplicant.conf
-rw-r--r-- 1 root root 200 Jan 27 11:24 /etc/wpa_supplicant/wpa_supplicant.conf
The reason the permissions had changed was due to the fact that I had added my own wpa_supplicant.conf file to the boot partition on my PC before installing the sdcard to the emonpi.
This worked perfectly fine during that first session, I even checked the wifi settings via emoncms as I know there have been issues reported on that front.
It’s only when I restarted the Pi the following day (after I got the error message that would not clear) that the emonpi’s “blue screen of wifi denial”.
A look at the emonScripts repo showed the wpa_supplicant.conf’s permissions are changed so that anyone can read the file contents (IMO not the best idea!)
Interestingly this only adds read permissions and yet emoncms has the ability to write to the file so I wonder why emoncms also needs there to be public access to the file in order to work?
When my own pre-written file was moved by the OS during startup it set the permissions back to the recommended “owner only” ie root, but that did not cause any issue for the initial session, despite several reboots following multiple updae attempts.
I therefore suspect this is linked to whether there is an active logged in (admin?) session, only when my session apparently expired over night did this issue come to the surface.
This leads into the next issue, the everlasting error message. Whilst the message has some specific detail as in the file and line number etc, it’s pretty obscure as to what the issue is. But as I suspected, it was indeed a session timeout. This isn’t the first time we have brought this up. This is really messy for a simple (admin?) timeout.
This was proved (once I had got passed the “blue screen of denial”) by the log messages on the admin page.
2021-01-27 11:24:14.778|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:15.769|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:16.769|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:17.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:18.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:19.766|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:20.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:21.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:22.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:23.772|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:24.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:25.772|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:26.772|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:27.771|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:28.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:29.764|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:30.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:31.770|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:32.768|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:43.806|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:43.940|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:44.065|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:24:44.168|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-27 11:49:02.886|WARN|emoncms_mqtt.php|Not connected, retrying connection
2021-01-27 11:49:02.973|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
This is just another manifestation of a very old and very annoying issue with emoncms admin session timeouts.
Which kinda just leaves me with the original mystery of why the FW version isn’t being logged in emonhub, that can wait for another day.
In the interim it should be noted that the “put wpa_supplicant.conf file in boot partition” method of setting or changing wifi settings IS NOT supported by the pre-built image unless you subsequently change the permission vis ssh. But it is supported (initially only?) in emonScripts IF you’re building your own image, item 6 of the rpi-install guide
  1. If you want to add a wpa_supplicant.conf to the boot folder so it connects to your Wi-Fi, especially if using a PiZero, do so now.
    ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    country=<Insert 2 letter ISO 3166-1 country code here>
    network={
    ssid="<Name of your wireless LAN>"
    psk="<Password for your wireless LAN>"
Yup! Just got the error message again after leaving the page open whilst I went off and did something else, returning and clicking a button.
But this time (since changing the wpa_supplicant.conf permissions) when I open another browser tab, I get the login page (not the blue screen of wifi denial) and once logged in and return to the original admin browser tab, one click of the “ok” button and the error box closes and stays closed!
The emoncms log is now filled with the same “Not Admin” entries as yesterday, but dated today
2021-01-28 13:11:40.254|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:41.242|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:42.244|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:43.244|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:44.246|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:45.246|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:46.246|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:47.246|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:48.241|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:49.243|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:50.260|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:51.243|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:52.252|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:53.240|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:54.247|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:55.258|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:56.401|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:58.243|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:11:59.452|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:12:01.244|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:12:02.242|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:12:03.241|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:12:04.251|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:12:05.245|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
2021-01-28 13:12:06.241|ERROR|index.php|Not Admin|admin/emonpi/getupdatelog
This would be a better way of doing the wifi settings
https://askubuntu.com/questions/1264995/allow-users-to-change-wpa-supplicant-conf
it’s not a million miles away from the service-runner style of interacting with a root system without baring all to all users, emoncms could use a copy of wpa_supplicant that is constantly updated via a service that wirtes emoncms chages to the file to the original file and at the same time keep the emoncms copy updated with any other changes found, eg if someone used a wpa_supplicant.conf file in boot at startup or manually edited. This would keep the wifi settings root access only, whilst allowing emoncms to edit wifi settings without root privileges.
