EmonPI firmware build
I am running emonSD-17Oct19, and I have been trying to modify the emonpi firmware to send powerfactor and current values.
However when I build and flash using platformio on the Raspberry PI, my emonTH devices input stop reporting their values, and no traffic for them is seen in EmonHUB.
To rule out the changes I have made, I tried downloading a clean copy of the source from github and building / flashing that and get the same result.
If i flash a copy of latest.hex that I took before starting everything works as expected.
Any ideas?
Hello @adtyne and welcome to the forum.
Trying to replicate here I seem to be having trouble uploading the firmware with platformio on the emonpi. But I have been able to successfuly compile and then upload using avrdude.
cd /opt/openenergymonitor/emonpi/firmware
pio run
sudo service emonhub stop
avrdude -v -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/opt/openenergymonitor/emonpi/firmware/.pio/build/emonpi/firmware.hex
sudo service emonhub start
The emonTH and emontx devices here then appear as normal in the input list.
Did the upload using platformio work for you?
Hi @TrystanLea, Many Thanks Ive tried flashing using avr-dude and get the same result.
Ive cleared out the /opt/openenergymonitor/emonpi/firmware and done a
git clone GitHub - openenergymonitor/emonpi: Raspberry Pi Based Energy Monitor. Hardware, Firmware & related software for the PI. to pull back a clean copy of the source before building for this test.
Logs from the plaformio build and avr-dude upload below, and emonhub.log attached showing that the data from RF remote nodes stops coming in, around 11:30 am this morning when doing a test.
Everything appears to build and upload with no errors, I am getting data coming in from the emonpi it’s self, but not from any of the 433MHz devices.
./compile.sh
./compile.sh: line 6: rpi-rw: command not found
Warning! `env_default` configuration option in section [platformio] is deprecated and will be removed in the next release! Please use `default_envs` instead
Processing emonpi (platform: atmelavr; framework: arduino; board: emonpi)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/emonpi.html
PLATFORM: Atmel AVR 1.15.0 > OpenEnergyMonitor emonPi
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
PACKAGES: toolchain-atmelavr 1.50400.190710 (5.4.0), framework-arduinoavr 4.1.2
Converting src.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 15 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <DallasTemperature> 3.7.7
|   |-- <OneWire> 2.3.5
|-- <EmonLib> 1.1.0
|-- <LiquidCrystal_I2C>
|   |-- <Wire> 1.0
|-- <jeelib> #f097c00
|-- <arduino-onewire-DS2438> #a7ec6ac
|   |-- <OneWire> 2.3.5
|-- <OneWire> 2.3.5
|-- <Wire> 1.0
Building in release mode
Compiling .pio/build/emonpi/src/src.ino.cpp.o
Linking .pio/build/emonpi/firmware.elf
Checking size .pio/build/emonpi/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
DATA:    [=====     ]  52.7% (used 1079 bytes from 2048 bytes)
PROGRAM: [======    ]  60.2% (used 18482 bytes from 30720 bytes)
=============================================================== [SUCCESS] Took 17.18 seconds ===============================================================
Environment    Status    Duration
emonpi         SUCCESS   00:00:17.182
direct-upload  IGNORED
emonpi_deploy  IGNORED
================================================================ 1 succeeded in 00:00:17.182 ===============================================================
./update
avrdude-original: Version 6.3-20171130
                  Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                  Copyright (c) 2007-2014 Joerg Wunsch
                  System wide configuration file is "/etc/avrdude.conf"
                  User configuration file is "/root/.avrduderc"
                  User configuration file does not exist or is not a regular file, skipping
                  Using Port                    : /dev/ttyAMA0
                  Using Programmer              : arduino
                  Overriding Baud Rate          : 115200
avrdude-original: Using autoreset DTR on GPIO Pin 7
                  AVR Part                      : ATmega328P
                  Chip Erase delay              : 9000 us
                  PAGEL                         : PD7
                  BS2                           : PC2
                  RESET disposition             : dedicated
                  RETRY pulse                   : SCK
                  serial program mode           : yes
                  parallel program mode         : yes
                  Timeout                       : 200
                  StabDelay                     : 100
                  CmdexeDelay                   : 25
                  SyncLoops                     : 32
                  ByteDelay                     : 0
                  PollIndex                     : 3
                  PollValue                     : 0x53
                  Memory Detail                 :
                                           Block Poll               Page                       Polled
                    Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                    eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                    flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                    lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                    hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                    efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                    lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                    calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                    signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                  Programmer Type : Arduino
                  Description     : Arduino
                  Hardware Version: 3
                  Firmware Version: 4.4
                  Vtarget         : 0.3 V
                  Varef           : 0.3 V
                  Oscillator      : 28.800 kHz
                  SCK period      : 3.3 us
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: safemode: lfuse reads as 0
avrdude-original: safemode: hfuse reads as 0
avrdude-original: safemode: efuse reads as 0
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
                  To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (18482 bytes):
Writing | ################################################## | 100% 2.64s
avrdude-original: 18482 bytes of flash written
avrdude-original: verifying flash memory against /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex contains 18482 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.95s
avrdude-original: verifying ...
avrdude-original: 18482 bytes of flash verified
avrdude-original: safemode: Fuses OK (E:00, H:00, L:00)
strace: |autoreset: Broken pipe
avrdude-original done.  Thank you.
Hmm ok, are you using any different RFM radio configuration? group or frequency?
Is emonhub running again after the firmware upload, maybe check the result of:
sudo service emonhub status
@TrystanLea
All my devices are 433MHz, Group 210 and work with the default firmware shipped with the EmonPi. From the src.ino I am building these parameters are set.
byte RF_freq=RF12_433MHZ;                                        // Frequency of RF69CW module can be RF12_433MHZ, RF12_868MHZ or RF12_915MHZ. You should us$
byte nodeID = 5;                                                 // emonpi node ID
int networkGroup = 210;
Great, how about the emonhub status after an attempted upload (when the inputs are not updating)?
@TrystanLea
emonhub.service - emonHub service description
   Loaded: loaded (/opt/openenergymonitor/emonhub/service/emonhub.service; enabled; vendor preset: enabled)
   Active: active (running) since Tue 2019-11-12 12:15:29 GMT; 3min 13s ago
  Process: 6694 ExecStartPre=/bin/mkdir -p /var/log/emonhub/ (code=exited, status=0/SUCCESS)
  Process: 6695 ExecStartPre=/bin/chgrp -R emonhub /var/log/emonhub/ (code=exited, status=0/SUCCESS)
  Process: 6696 ExecStartPre=/bin/chmod 775 /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Main PID: 6697 (python)
    Tasks: 4 (limit: 2319)
   Memory: 12.7M
   CGroup: /system.slice/emonhub.service
           └─6697 python /usr/local/bin/emonhub/emonhub.py --config-file=/etc/emonhub/emonhub.conf --logfile=/var/log/emonhub/emonhub.log
Nov 12 12:17:50 emonpi emonhub.py[6697]:     self.stream.flush()
Nov 12 12:17:50 emonpi emonhub.py[6697]: IOError: [Errno 28] No space left on device
Nov 12 12:17:50 emonpi emonhub.py[6697]: Logged from file EmonHubMqttInterfacer.py, line 121
Nov 12 12:17:50 emonpi emonhub.py[6697]: Traceback (most recent call last):
Nov 12 12:17:50 emonpi emonhub.py[6697]:   File "/usr/lib/python2.7/logging/__init__.py", line 892, in mit
Nov 12 12:17:50 emonpi emonhub.py[6697]:     self.flush()
Nov 12 12:17:50 emonpi emonhub.py[6697]:   File "/usr/lib/python2.7/logging/__init__.py", line 852, in flush
Nov 12 12:17:50 emonpi emonhub.py[6697]: Logged from file EmonHubMqttInterfacer.py, line 152
it does appear to be running, but then it is indicating that your logs are full. Could you copy and paste here the output of:
df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       4.0G  3.1G  647M  84% /
devtmpfs        484M     0  484M   0% /dev
tmpfs           488M     0  488M   0% /dev/shm
tmpfs           488M   56M  433M  12% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           488M     0  488M   0% /sys/fs/cgroup
tmpfs            30M     0   30M   0% /tmp
tmpfs           1.0M  8.0K 1016K   1% /var/lib/php/sessions
tmpfs           1.0M     0  1.0M   0% /var/tmp
/dev/mmcblk0p3   10G  8.0M  9.5G   1% /var/opt/emoncms
/dev/mmcblk0p1  253M   52M  201M  21% /boot
log2ram          50M   41M  9.7M  81% /var/log
tmpfs            98M     0   98M   0% /run/user/1000
If I revert back to the standard firmware build I don’t get those errors…
interesting, could you copy and paste result of:
ls -lh /var/log/emoncms
You will need /var/log/emonhub/ as well :grin:
Bit high. Check logrotate is firing? Does log2ram create a log @pb66?
[12:28:15] pi@emonpi:/opt/openenergymonitor/emonpi/firmware/compiled$ ls -lh /var/log/emoncms/
total 612K
-rw-rw-r-- 1 root root 345K Nov 12 12:24 apache2-error.log
-rw-rw-rw- 1 pi   pi   248K Nov 12 12:26 emoncms.log
-rw-rw-rw- 1 pi   pi   3.0K Nov 10 19:18 emonpiupdate.log
-rw-rw-r-- 1 pi   pi      0 Nov 10 19:17 emonupdate.log
-rw-r--r-- 1 pi   pi   2.3K Oct 29 23:58 exportbackup.log
-rw-rw-r-- 1 root root  137 Nov 12 12:30 wificheck.log
-rw-rw-r-- 1 pi   pi    598 Nov  9 21:42 wifiscan.log
[12:34:40] pi@emonpi:/opt/openenergymonitor/emonpi/firmware/compiled$ ls -lh /var/log/emonhub/
total 328K
-rw-r--r-- 1 emonhub emonhub 325K Nov 12 12:36 emonhub.log
@borpin How can I confirm logrotate is firing?
Can’t remember exactly - not in front of a machine so I can check either right now - sorry.
It is looking like it is.
Are there any other big logs in the /var/log folder?
Ive had a manual clearout of the log files, and have tried my build firmware and no longer get the disk space errors when checking the status of the emonhub service. But still nothing coming back from the RF nodes.
One thing ive noticed is that I am bulding an unmodified src 2.9.0 and get a hex file of 52005 bytes, but the one shipped with the emonSD image is 50332 bytes, as is the prebult 2.9.0 on github.
Look for a log in /var/log/logrotate/
Can you reboot and then 'df -h` on reboot please.
Good but they should not have been there anyway! Unless we can fix that, the problem will reoccur.
Can you remember what the big files were?
[12:50:47] pi@emonpi:~$ df -h
/dev/root       4.0G  3.1G  691M  82% /
tmpfs           488M  6.6M  482M   2% /run
tmpfs           1.0M     0  1.0M   0% /var/lib/php/sessions
log2ram          50M  5.6M   45M  12% /var/log
Something is filling this up pretty rapidly I suggest as it was 81% in the last screenshot.
Unfortunatley I didnt make a note of logfiles etc… I’ll keep an eye on the /var/log space over the next few days and see how it grows… It’s not growing particularly fast now…
@borpin Many thanks for your input…
@TrystanLea Im guessing what I’ve learned is that the firmware is running otherwise I wouldnt be getting the data from the emonpi node… So there is something funny about my build and the RF config… Could this be a dependency (incorrect version) issue?
