hi,
i have install (emonSD-07nov 16) on Raspberry PI ver. 3 model B
and i have EmonTX ver 3.4.2 connectet by USB to serial
when i check USB connection, it look like it was ok
[email protected](ro):~$ ls -la /dev/{tty{AMA,S,USB},serial}*
crw–w---- 1 root tty 204, 64 Aug 30 20:20 /dev/ttyAMA0
crw-rw---- 1 root dialout 4, 64 Aug 30 20:17 /dev/ttyS0
crw-rw---- 1 root dialout 188, 0 Aug 30 20:17 /dev/ttyUSB0
/dev/serial:
total 0
drwxr-xr-x 4 root root 80 Aug 30 20:17 .
drwxr-xr-x 15 root root 3340 Aug 30 20:17 …
drwxr-xr-x 2 root root 60 Aug 30 20:17 by-id
drwxr-xr-x 2 root root 60 Aug 30 20:17 by-path
If you’re talking about the programmer from the OEM Shop and an emonTx, Tx goes to TXD and Rx goes to RXD. It’s actually the emonTx that’s labelled backwards, as it receives data from TXD on the programmer on Tx pin of the FTDI connector, which is connected on the p.c.b. to RXD and transmits it from TXD on the pin labelled Rx on the FTDI connector, to RXD on the programmer.
ls: cannot access /dev/ttyUSB*: No such file or directory
ls: cannot access /dev/serial*: No such file or directory
crw--w---- 1 root tty 204, 64 Aug 31 08:29 /dev/ttyAMA0
crw-rw---- 1 root dialout 4, 64 Aug 30 21:17 /dev/ttyS0
but i cant get data on emonhub, is there other thing i need do ?
