Because my Inputs still don’t work I digging little more and I discover, that Emoncms and emonpi have new version ( my system have 2.8.2 emonpi and Emoncms 9.8.0 version) - but when I pressing the update buttons, system starts to something, rebooting, but version’s of system still are the same.
Can I update my system from terminal somehow ? or what are my options ?
Edit - Log file is attached to post #3 in this thread. BT, Moderator
Please upload your log file here. i.e. as an attachment to your post. We avoid using third party sites. If your file were to become inacessable, or disappear altogether, your post would become useless.
If it’s not a short file, the preferred method is to zip it first, then upload it.
Yes I cleaned cache and trying with 2-3 different browser and PC - but seems the system itself on old version - because when booting up system the emonpi LCD shows version 2.82 - newest is 2.83 - I think the problem with that - that system don’t updating ;(
Ok that is the firmware version, can you confirm if emoncms has updated?
The firmware update does try to run, looking at this part or the last log entry
Start emonPi Atmega328 firmware update:
EmonPi update started
EUID: 1000
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
Stopping OpenEnergyMonitor emonHub: emonhub has been stopped ok.
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/home/pi/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
Starting OpenEnergyMonitor emonHub: emonhub has been started ok.
there is no sign of a problem (or confirmation of a successful upload for that matter).
Can you check for a file called /var/log/service-runner.log for any errors. There is a quirk in the way the emonPi update log works and some errors get posted to this less used logfile. If you have rebooted it will be lost so you may need to retry the “update emonPi” button from emoncms again.
Start emoncms update:
Emoncms update started
Tue 2 May 22:26:02 UTC 2017
EUID: 1000
Checking cron tab for service runner entry...
service runner crontab entry already installed
git pull /var/www/emoncms
dev-mosquitto-php
master
* stable
symlinked_modules
On branch stable
Your branch is up-to-date with 'origin/stable'.
nothing to commit, working directory clean
Have you tried restarting the apache server?
sudo service apache2 restart
I have just fired up my test emonPi and looked at /var/log/service-runner.log and found
update via service-runner
after running the update from emoncms I had this
STARTING: /home/pi/emonpi/service-runner-update.sh emonpi >> /home/pi/data/emonpiupdate.log
From https://github.com/openenergymonitor/emonpi
e60cb72..ec62210 master -> origin/master
* [new branch] startupAP -> origin/startupAP
* [new tag] 2.8.3 -> 2.8.3
From https://github.com/openenergymonitor/RFM2Pi
30e650d..e5d874d master -> origin/master
From https://github.com/openenergymonitor/emonhub
79ff05b..0a4da93 emon-pi -> origin/emon-pi
* [new branch] dev -> origin/dev
* [new branch] lanip-status -> origin/lanip-status
error: insufficient permission for adding an object to repository database .git/objects
fatal: failed to write object
fatal: unpack-objects failed
From https://github.com/openenergymonitor/huawei-hilink-status
e5c046b..48ee3d0 master -> origin/master
You are using pip version 8.1.2, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/home/pi/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (17898 bytes):
Writing | ################################################## | 100% 2.47s
avrdude-original: 17898 bytes of flash written
avrdude-original: verifying flash memory against /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex contains 17898 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.87s
avrdude-original: verifying ...
avrdude-original: 17898 bytes of flash verified
strace: |autoreset: Broken pipe
avrdude-original done. Thank you.
From https://github.com/emoncms/emoncms
0ea274f..2e48fd1 master -> origin/master
* [new branch] emonpi-setup-wizard -> origin/emonpi-setup-wizard
22c0ae9..1044bec stable -> origin/stable
* [new tag] 9.8.1 -> 9.8.1
* [new tag] 9.8.3 -> 9.8.3
error: Your local changes to the following files would be overwritten by merge:
Modules/admin/admin_main_view.php
Please, commit your changes or stash them before you can merge.
Aborting
From https://github.com/emoncms/app
14345bc..6d07ab2 9.0 -> origin/9.0
* [new branch] refactor -> origin/refactor
From https://github.com/emoncms/wifi
149f909..14fa926 9.0 -> origin/9.0
* [new branch] develop -> origin/develop
From https://github.com/emoncms/dashboard
0687caa..a06cd2f master -> origin/master
From https://github.com/emoncms/graph
28e1536..e68cdc7 master -> origin/master
Already on 'emonpi'
From https://github.com/emoncms/postprocess
93c7cd7..526a254 emonpi -> origin/emonpi
a4a0c89..33f1d21 emoncmsorg -> origin/emoncmsorg
error: The following untracked working tree files would be overwritten by merge:
mainserver/postprocess/postprocess_menu.php
Please move or remove them before you can merge.
Aborting
mount: / is busy
COMPLETE: /home/pi/emonpi/service-runner-update.sh emonpi >> /home/pi/data/emonpiupdate.log
since then I have noticed another “update via service-runner” gets added about every minute or so. try clicking the “update emonpi” button again and rechecking this log. The “avrdude” stuff and the “strace” errors are produced with every update attempt so they should be there at the very least.
something like this I found from service-runner.log
STARTING: /home/pi/emonpi/service-runner-update.sh rfm69pi >> /home/pi/data/emonpiupdate.log
fatal: unable to access 'https://github.com/openenergymonitor/emonpi/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/openenergymonitor/RFM2Pi/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/openenergymonitor/emonhub.git/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/openenergymonitor/oem_openHab/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/usefulscripts/': Failed to connect to github.com port 443: No route to host
error: cannot open .git/FETCH_HEAD: Permission denied
wget: missing URL
Usage: wget [OPTION]... [URL]...
Try `wget --help' for more options.
fatal: unable to access 'https://github.com/emoncms/emoncms.git/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/app.git/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/config/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/wifi.git/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/dashboard.git/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/graph/': Failed to connect to github.com port 443: No route to host
Already on 'emonpi'
fatal: unable to access 'https://github.com/emoncms/postprocess.git/': Failed to connect to github.com port 443: No route to host
fatal: unable to access 'https://github.com/emoncms/backup.git/': Failed to connect to github.com port 443: No route to host
COMPLETE: /home/pi/emonpi/service-runner-update.sh rfm69pi >> /home/pi/data/emonpiupdate.log
yes ping is working - but - now I killed wifi connection ( I have wifi and LAN in same time ) after that I updated again and now the system is up to date - then came the settings.php issues, but loaded from default and It’s works!
BUT this all don’t fix the main problem - “My Input don’t loading” - now it’s grey and “the wheel spins” , but still nothing - I want add new component - but I cant to this very long time ;(
Thanks ph66 for looking for answers, but all the input not loading ideas is done - refresh page, flush the redis(once it’s helps - some weeks ago) , but now still nothing ;( the input just not loading - and with that problem I can’t add any device as well to monitoring.
not sure how your wifi/LAN was set up. but from the sounds, on the same access point --generally you can not have two networks connected to the same access point from the same device. as spanning protocols come into effect, then either one or both device will be blocked, if no spanning protocol is enabled then it creates a network loop and nothing works or works sporadically as what you described above.
I have lan and wifi enable on my pi, but the wifi is an AP in it own range just for wifi capable IOT devices to connect too and the lan is for routing internet access
