Emonhub upgrade not working
I have been successfully running an old version of emoncms with emonhub on a Raspberry pi for a very long time (more than ten years), but I have found that very occasionally, my temperature updates have stopped working, requiring a reboot. This only happens say once every few weeks, so it is difficult to debug.
I have since found that restarting the emonhub service resolves the issue. I was running version 2.1.2, so decided to update to the latest version before asking for any help.
I downloaded the latest version from git and installed using the script. I am now running version 2.7.2, which appears to be mostly working, except for updating emoncms.
Note that I had to manually install paho using the suggestion here: Emonhub - paho-mqtt fails to install - #16 by MBC
From my old installation, here is an extract of the log when sending to emoncms:
2025-01-26 17:52:25,251 INFO     emonCMS    sending: http://localhost/emoncms/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1737913922.482998,23,17,0,55,2.8000000000000003,0,-68]]&sentat=1737913945
This command still works when pasting into a browser, and replacing the API key with the correct value.
Here is an extract of the log for the current version:
2025-02-19 13:17:15,852 DEBUG    RFM2Pi     7 NEW FRAME : OK 23 164 0 0 0 211 1 28 0 0 0 0 0 (-63)
2025-02-19 13:17:15,856 DEBUG    RFM2Pi     7 Timestamp : 1739971035.852215
2025-02-19 13:17:15,857 DEBUG    RFM2Pi     7 From Node : 23
2025-02-19 13:17:15,859 DEBUG    RFM2Pi     7    Values : [16.400000000000002, 0, 46.7, 2.8000000000000003, 0]
2025-02-19 13:17:15,860 DEBUG    RFM2Pi     7      RSSI : -63
2025-02-19 13:17:15,862 DEBUG    RFM2Pi     7 Sent to channel(start)' : ToEmonCMS
2025-02-19 13:17:15,863 DEBUG    RFM2Pi     7 Sent to channel(end)' : ToEmonCMS
2025-02-19 13:17:16,159 INFO     MQTT       Connecting to MQTT Server
2025-02-19 13:17:16,232 DEBUG    emonCMS    Buffer size: 1
2025-02-19 13:17:16,234 DEBUG    emoncmsorg Buffer size: 1
2025-02-19 13:17:16,235 INFO     emonCMS    sending: http://192.168.0.30/emoncms/input/bulk.json?sentat=1739971036 (68 bytes of data, 1 frames, uncompressed)
2025-02-19 13:17:16,266 INFO     MQTT       connection status: Connection successful
2025-02-19 13:17:16,270 DEBUG    MQTT       CONACK => Return code: 0
2025-02-19 13:17:16,285 WARNING  emonCMS    send failure: wanted 'ok' but got ''
2025-02-19 13:17:16,373 INFO     MQTT       on_subscribe
To me, this looks like the temperature signal is being received and processed, but the code is not including any data in the post to emoncms – just the sentat parameter.
Here is an extract from my config file:
[[emonCMS]]
    [[[init_settings]]]
    [[[runtimesettings]]]
        pubchannels = ToRFM12,
        subchannels = ToEmonCMS,
        url = http://localhost/emoncms
        apikey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        senddata = 1                    # Enable sending data to emoncms
        sendstatus = 1                  # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/my$
        sendinterval= 30                # Bulk send interval to Emoncms.org in seconds
Are you able to help please?
Maybe try replacing with the following:
[[emoncmsorg]]
    [[[init_settings]]]
        url = https://emoncms.org
        senddata = 1    # Enable sending data to Emoncms.org
        sendnames = 0    # Send full input names (compression will be automatically enabled)
        interval = 30    # Bulk send interval to Emoncms.org in seconds
sendnames = 0 for compatibility with your inputs that will be number based.
Thanks for your help. I’ve tried your suggestion, but the post to emoncms remains the same - i.e. the data would appear to be missing.
The issue seems to be in the local emoncms install I think, perhaps that needs an update?
But emonhub has been working fine, and I can successfully post to it via a URL in the browser. From looking at the log, I think that for some reason, emonhub is only sending the sentat parameter, and none of the other data needed (unless the logging is misleading).
The log does indicate that one frame was sent, 68 bytes of data and without compression which is a newer feature. The content of the frame is not printed to the log.
Is there any way to log the contents?
I’m afraid not…
I noticed that one difference is that the API key is now passed in the Http header, rather than the URL. But even making some changes to the Python code, I still couldn’t get this to work.
So I have reverted, and added an hourly cron job to restart the emonhub service.
