Emonhub service failing after flashing SD
Hi! I’m new here and I don’t have much experience, please forgive my lack of experience.
So, long story short: I have an EmonPi from nov 18 with 2 EmonTH sensors. Many months ago failed to boot (stuck at “Raspberry Pi booting…”), maybe due to unplugging it without shutting it down. I am trying to fix it now, from what I read I thought the way to go was to flash the SD with a new image, which I did yesterday. Everything went pretty smoothly, the emonpi booted but there were no inputs wich led me to notice that emonhub service is failing. I tried rebooting it, shutting it down, and again after a full update. Can somebody help me figuring out the problem? Here are the logs:
Server Information
Server Information
Services
  • emonhub :- Failed Failed
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 300s 0 feed points pending write
  • service-runner :- Active Running
  • emonPiLCD :- Active Running
  • redis-server :- Active Running
  • mosquitto :- Active Running
  • demandshaper :- Active Running
Emoncms
Server
  • OS :- Linux 4.19.75-v7+
  • Host :- emonpi | emonpi | (192.168.0.41)
  • Date :- 2020-07-28 09:45:01 BST
  • Uptime :- 09:45:01 up 8 min, 0 users, load average: 0.16, 0.19, 0.12
Memory
  • RAM :- Used: 15.81%
    • Total :- 975.62 MB
    • Used :- 154.22 MB
    • Free :- 821.4 MB
  • Swap :- Used: 0.00%
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
      Write Load Period
Disk
  • / :- Used: 47.85%
    • Total :- 3.92 GB
    • Used :- 1.88 GB
    • Free :- 1.85 GB
    • Write Load :- 212.66 B/s (7 mins)
  • /var/opt/emoncms :- Used: 0.04%
    • Total :- 9.98 GB
    • Used :- 3.77 MB
    • Free :- 9.47 GB
    • Write Load :- 0 B/s (7 mins)
  • /boot :- Used: 20.55%
    • Total :- 252.05 MB
    • Used :- 51.79 MB
    • Free :- 200.25 MB
    • Write Load :- 1.16 B/s (7 mins)
  • /var/log :- Used: 4.73%
    • Total :- 50 MB
    • Used :- 2.37 MB
    • Free :- 47.63 MB
    • Write Load :- n/a
HTTP
  • Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
  • Host :- localhost:6379 (127.0.0.1)
  • Date :- 2020-07-28 09:45:01 (UTC 01:00‌​)
  • Stats :- Uptime: 662 Threads: 12 Questions: 2780 Slow queries: 0 Opens: 46 Flush tables: 1 Open tables: 40 Queries per second avg: 4.199
Redis
  • Version :-
    • Redis Server :- 5.0.3
    • PHP Redis :- 5.0.2
  • Size :- 16 keys (798.10K)
  • Uptime :- 0 days
MQTT Server
  • Version :- Mosquitto 1.5.7
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 7.3.9-1~deb10u1 (Zend Version 3.3.9)
  • Modules :- apache2handlercalendar Core ctype curl date dom v20031129exif fileinfo filter ftp gd gettext hash iconv json v1.7.0libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $openssl pcre PDO pdo_mysql Phar posix readline redis v5.0.2Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zlib
Pi
  • Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
  • Serial num. :- D0B17288
  • CPU Temperature :- 53.69°C
  • GPU Temperature :- 54.8°C
  • emonpiRelease :- emonSD-17Oct19
  • File-system :- read-write
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36
  • Language :- es-ES,es;q=0.9,ca;q=0.8,en-US;q=0.7,en;q=0.6
Update log
Blockquote
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Mon 27 Jul 16:06:05 BST 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: none
Running apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists...
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD DETECTED Ox27
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git fetch --all --prune -v
Fetching origin
From https://github.com/openenergymonitor/emonhub
= [up to date] stable -> origin/stable
= [up to date] MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
= [up to date] SDS011 -> origin/SDS011
= [up to date] emon-pi -> origin/emon-pi
= [up to date] env_example -> origin/env_example
= [up to date] include_serial_number -> origin/include_serial_number
= [up to date] lanip-status -> origin/lanip-status
= [up to date] master -> origin/master
= [up to date] redis_config_interface -> origin/redis_config_interface
= [up to date] unitless_decoder -> origin/unitless_decoder
git status
On branch stable
Untracked files:
(use "git add ..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
git pull origin stable
* branch stable -> FETCH_HEAD
Already up to date.
Running emonhub install & update script emonSD_pi_env:1
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
sudo: pip3: command not found
Unit /etc/systemd/system/[email protected] is masked, ignoring.
useradd: user 'emonhub' already exists
- installing emonhub.service
- Service ActiveState=active
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
Already up to date.
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.1.1-42-ge5d51a4
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.9
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.0-29-g274bcd5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.2.2-6-g70894e1
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 1.2.4-5-gd689aae
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.3-4-g5c50627
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.5
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- no local changes
Already up to date.
Already on 'stable'
Backup module installation and update script
- Loading EmonScripts config.ini
- Copying default.config.cfg to config.cfg
- Setting config.cfg settings
- Backup module symlink already exists
- PHP Version: 7.3
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- /var/opt/emoncms/backup already exists
- /var/opt/emoncms/backup/uploads already exists
- restarting apache
Starting emonPi LCD service..
emonPi update done: Mon 27 Jul 16:07:11 BST 2020
restarting service-runner
Blockquote
Emoncms log
Blockquote
2020-07-27 13:32:19.262|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 13:45:03.855|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 13:45:03.892|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 14:23:51.146|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 14:23:51.180|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 14:30:47.113|ERROR|index.php|Not Authenticated|device/list
2020-07-27 14:30:47.201|ERROR|index.php|Not Authenticated|input/list
2020-07-27 14:30:47.683|ERROR|index.php|Not Authenticated|input/view
2020-07-27 14:32:38.498|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 14:32:38.523|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 14:33:31.410|ERROR|index.php|Not Admin|admin/view
2020-07-27 14:34:26.338|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 14:34:26.361|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 14:42:24.140|ERROR|index.php|Not Admin|admin/view
2020-07-27 14:42:29.469|ERROR|index.php|Not Admin|admin/view
2020-07-27 14:45:45.062|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 14:45:45.084|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 14:50:02.513|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 14:50:02.583|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 15:06:30.492|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 15:06:30.514|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-27 15:11:10.725|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-27 15:11:10.790|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2020-07-28 08:34:02.916|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-07-28 08:34:02.983|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
Blockquote
Thanks a lot!
Update log
Blockquote
master
* stable
On branch stable
Already up to date.
Main Update Script
EUID: 1000
type: all
firmware: none
* master
On branch master
Fetching origin
Already up to date.
* master
On branch master
Fetching origin
Already up to date.
emonHub update
Fetching origin
git status
On branch stable
Untracked files:
src/src
Already up to date.
[[5]]
[[6]]
[[7]]
[[8]]
[[9]]
[[10]]
[[11]]
[[12]]
[[13]]
[[14]]
[[15]]
[[16]]
[[19]]
[[20]]
[[21]]
[[22]]
[[23]]
[[24]]
[[25]]
[[26]]
Update Emoncms Core
- no local changes
Fetching origin
Already up to date.
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- git tags: 2.0.9
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
- no local changes
Already up to date.
Already on 'stable'
- no local changes
Already up to date.
Already on 'stable'
- no local changes
Already up to date.
Already on 'stable'
- git tags: 2.0.5
- no local changes
Already up to date.
Already on 'stable'
- git tags:
- no local changes
Already up to date.
Already on 'stable'
- PHP Version: 7.3
post_max_size = 3G
- restarting apache
Blockquote
How long did you wait? the initial updates take a fair amount of time, so you really need to boot and leave for a good period of time before doing anything else.
Did you use a new SD Card?
Emonhub log file:
https://drive.google.com/file/d/1BNMD1H3UjVAUvKfXUwOOtWm3y9Cy_z56/view?usp=sharing
Thanks!
I would say I waited a fair amount of time, few minutes the first time, couple of hours after. Waiting after full update?
I didn’t try a new SD. I fixed it with windows before flashing it with Etcher, which validated the flash. I’ll try with a different one.
Did you reflash between these 2 attempts? If not, reflash and boot and then just leave it for at least 30 mins.
The SD card is oldish so there is a possibility of failure.
The logs show the serial port not opened correctly. I also note the time stamp is wrong.
2019-10-17 10:33:47,947 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2019-10-17 10:42:24,985 INFO     MainThread EmonHub emonHub emon-pi variant v2.1.2
2019-10-17 10:42:24,985 INFO     MainThread Opening hub...
2019-10-17 10:42:24,986 INFO     MainThread Logging level set to DEBUG
2019-10-17 10:42:24,986 INFO     MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2019-10-17 10:42:24,988 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2019-10-17 10:42:26,991 WARNING  MainThread Device communication error - check settings
Ok, will do. Reflash on new SD, boot and wait a couple of hours. Thanks for the superquick replies.
Yep, that did it. Different SD and waiting after putting it in gave me working feeds. Thanks a lot!
It is just so easy to be impatient. It would be better if the device gave some feedback. The new ones, have been booted in the shop for just that reason I think.
