I have 3 EmonTX in two separate locations and 1 EmonBase centrally located.
On a regular interval (at least every two weeks), the Emonbase reports its not receiving feeds. To resolve the issue i merely have to restart the Emonhub on the EmonBase.
From the logs there is mention of not receiving radio packets, however, as simply restarting the emonhub (not the full emonbase) solves the issue, it leads me to think its a software issue, but I dont know.
My current config is below:
####################### emonhub.conf #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
autoconf = 1
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[EmonPi2]]
Type = EmonHubOEMInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 115200
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
[[USB0]]
[[[init_settings]]]
com_port = /dev/ttyUSB0
com_baud = 115200
nodename = emonTx4
[[SPI]]
Type = EmonHubRFM69LPLInterfacer
[[[init_settings]]]
nodeid = 5
networkID = 210
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 0
nodevar_format_enable = 1
# Single JSON payload published - use with Emoncms MQTT
node_JSON_enable = 0
node_JSON_basetopic = emon/
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
senddata = 1 # Enable sending data to Emoncms.org
sendnames = 1 # Send full input names (compression will be automatically enabled)
interval = 30 # Bulk send interval to Emoncms.org in seconds
[[DS18B20]]
Type = EmonHubDS18B20Interfacer
[[[init_settings]]]
read_interval = 10
nodename = sensors
# ids = 28-000008e2db06, 28-000009770529, 28-0000096a49b4
# names = ambient, cyl_bot, cyl_top
####################### Nodes #######################
## See config user guide: https://github.com/openenergymonitor/emonhub
## If autoconf is enabled above, node configuration will automatically
## populate based on templates listed in available.conf
[nodes]
[[28]]
nodename = EmonTx4DB_rf1_28
[[[rx]]]
names = MSG, Vrms1, Vrms2, Vrms3, P1_UpLightsSmoke, P2_UpLights, P3_UnderStairs, P4_KitchenLightsFront, P5_DownLights, P6_KitchenLightsRear, E1_UpLightsSmoke, E2_UpLights, E3_UnderStairs, E4_KitchenLightsFront, E5_DownLights, E6_KitchenLightsRear, pulse, Analog
datacodes = L, h, h, h, h, h, h, h, h, h, l, l, l, l, l, l, L, H
scales = 1.0, 0.01, 0.01, 0.01, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0
units = n, V, V, V, W, W, W, W, W, W, Wh, Wh, Wh, Wh, Wh, Wh, p, n
[[29]]
nodename = EmonTx4DB_rf2_29
[[[rx]]]
names = MSG, Vrms2, Vrms3, P7_KitchenSockets, P8_DownAndUpSockets, P9_LoftSockets, P10_KitchenSocketsRear, P11_GarageSupply, P12_Cooker, E7_KitchenSockets, E8_DownAndUpSockets, E9_LoftSockets, E10_KitchenSocketsRear, E11_GarageSupply, E12_Cooker, digPulse, anaPulse
datacodes = L, h, h, h, h, h, h, h, h, l, l, l, l, l, l, L, L
scales = 1.0, 0.01, 0.01, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0
units = n, V, V, W, W, W, W, W, W, Wh, Wh, Wh, Wh, Wh, Wh, p, p
[[27]]
nodename = emon_DB_6CT_1phase_27
[[[rx]]]
names = MSG, V1, P1_MainFeed, P2, P3, P4, P5, P6, E1_MainFeed, E2, E3, E4, E5, E6, pulse
datacodes = L, h, h, h, h, h, h, h, l, l, l, l, l, l, L
scales = 1.0, 0.01, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0
units = n, V, W, W, W, W, W, W, Wh, Wh, Wh, Wh, Wh, Wh, p
[[24]]
nodename = emonTx4_24
[[[rx]]]
names = MSG, Vrms1, Vrms2, Vrms3, P1_LightsFan, P2, P3_Sockets, P4_Sockets, P5, P6_Sockets, E1_LightsFan, E2, E3_Sockets, E4_Sockets, E5, E6_Sockets, pulse, Analog
[[25]]
nodename = emonTx4_25
[[[rx]]]
names = MSG, Vrms2, Vrms3, P7, P8_Sockets, P9_ShedSupply, P10_Sockets, P11, P12, E7, E8_Sockets, E9_ShedSupply, E10_Sockets, E11, E12, digPulse, anaPulse
[[88]]
nodename = emonth1_88
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacodes = h, h, h, h
scales = 0.1, 0.1, 0.1, 0.1
units = C, C, %, V
[[130]]
nodename = emonTx4_130
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, P5, P6, E1, E2, E3, E4, E5, E6, T1, T2, T3, pulse
datacodes = L, h, h, h, h, h, h, h, l, l, l, l, l, l, h, h, h, L
scales = 1.0, 0.01, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 0.01, 0.01, 0.01, 1.0
units = n, V, W, W, W, W, W, W, Wh, Wh, Wh, Wh, Wh, Wh, C, C, C, p
[[67]]
nodename = emonTx4_67
[[[rx]]]
[[157]]
nodename = emonTx4_157
[[[rx]]]
[[92]]
nodename = emonTx4_92
[[[rx]]]
[[144]]
nodename = emonTx4_144
[[[rx]]]
[[241]]
nodename = emon_DB_6CT_1phase_241
[[[rx]]]
names = MSG, V1, P1, P2, P3, P4, P5, P6, E1, E2, E3, E4, E5, E6, pulse
[[9]]
nodename = emon_DB_6CT_1phase_9
[[[rx]]]
[[206]]
nodename = emonpiCM_206
[[[rx]]]
names = Msg, power1, power2, power1pluspower2, vrms, t1, t2, t3, t4, t5, t6, pulse1count, pulse2count, E1, E2
datacodes = L, h, h, h, h, h, h, h, h, h, h, L, L, l, l
scales = 1.0, 1.0, 1.0, 1.0, 0.01, 0.01, 0.01, 0.01, 0.01, 0.01, 0.01, 1.0, 1.0, 1.0, 1.0
units = n, W, W, W, V, C, C, C, C, C, C, p, p, Wh, Wh
I do have a log file from when it last stopped just before i restarted the emonhub…and it immediately started working again, so can post it if it would be useful.
Any help debugging would be helpful as currently im having to watch for feeds not updating, and manually hitting restart, which seems absurd.
