Some months ago, I had a problem where Emonhub was crashing with the following messages:
2016-01-21 20:29:05,490 DEBUG MQTT CONACK => Return code: 0
2016-01-21 20:29:05,595 INFO MQTT on_subscribe
2016-01-21 20:29:15,589 WARNING MainThread ArduinoMini thread is dead
2016-01-21 20:29:15,847 WARNING MainThread ArduinoMini thread is dead
2016-01-21 20:29:16,105 WARNING MainThread ArduinoMini thread is dead
My setup is an Arduino mini, connected to a Raspberry 2 via the serial port.
At this time, I had a discussion with Paul (pb66) and I suggested to use an external button that would generate a “sudo service emonhub restart” command. I built all that stuff and it finally worked.
Last week I revisited this project and found a solution that is now acceptable for me!
For some reasons, the mini generates “null” chars on the serial port when it is reset. Quite strange and I don’t know if it’s a particularity with this device. Anyway, these chars were just crashing Emonhub.
To sort this out, I have added 2 debug messages in the function below in EmonHubSerialInterfacer.py to show the differences and put a regular expression in between to get rid of all chars, except the ones from Octal 040 to 071 (Dec 32 to 57). This is the range I need and nothing else. This solved my problem!
EmonHubSerialInterfacer.py (portion)
import serial
import time
import Cargo
from pydispatch import dispatcher
import emonhub_interfacer as ehi
import re
def read(self):
"""Read data from serial port and process if complete line received.
Return data as a list: [NodeID, val1, val2]
# Read serial RX
self._rx_buf = self._rx_buf + self._ser.readline()
# If line incomplete, exit
if '\r\n' not in self._rx_buf:
return
# Remove CR,LF
f = self._rx_buf[:-2]
# Keep only chars from 040 to 071 in octal and get rid of the message "thread is dead"
self._log.debug("Serial Port buffer content before: " + str(f))
f = re.sub('[^\040-\071]', '', f)
self._log.debug("Serial Port buffer content after: " + str(f))
# Reset buffer
self._rx_buf = ''
Hope it can be of any help to you.
Walter
