I’m wondering whether it is possible with existing emonhub interfaces to parse the following serial line structure from LaCrosse temp&humidity sensors:
// Format
// OK 9 56 1 4 156 37 (ID = 56 T: 18.0 H: 37 no NewBatt)
// OK 9 49 1 4 182 54 (ID = 49 T: 20.6 H: 54 no NewBatt)
// OK 9 55 129 4 192 56 (ID = 55 T: 21.6 H: 56 WITH NewBatt)
// OK 9 ID XXX XXX XXX XXX
// | | | | | | --- Humidity incl. WeakBatteryFlag
// | | | | | |------ Temp * 10 + 1000 LSB
// | | | | |---------- Temp * 10 + 1000 MSB
// | | | |-------------- Sensor type (1 or 2) +128 if NewBatteryFlag
// | | |----------------- Sensor ID
// | |------------------- fix "9"
// |---------------------- fix "OK"
It is essential for me to support the new battery flag and weak battery flag.
I couldn’t find an interfacer for this format, but can’t belief it does not already exist.
Thanks you in advance!
