Hi all,
I’m running emonESP flashed to a generic Expressif ESP8266, ESP-12F module.
I send it data in the normal key:value format it likes. I send data every four seconds for it to then post to EmonCMS.
However,
It routinely misses the first few characters.
For instance, I send
“CT1_Rp:100.00, CT2_Rp:99.99, CT3_Rp:98.98”
However, it receives
“T1_Rp:100.00, CT2_Rp:99.99, CT3_Rp:98.98”
or
“_Rp:100.00, CT2_Rp:99.99, CT3_Rp:98.98”
Is this just me? Am I sending data too fast? It only ever misses the first few characters in a seemingly random way. Is the ESP just too busy or missing a serial interrupt (not sure if the ESP even has that…) As a workaround I could add a dummy value as the first in the string.
Interesting, I have seen garbled data at times from an EmonESP device but dont think I noticed a pattern with the first few characters. How often does it miss these characters? Is it every time or once every few hours?
It might be the Baud rate speed, or one of the other Serial Communications Parameters.
If it were a Baud rate mismatch, all of the characters would be affected, not just the first few.
I wouldn’t have thought so. There are ~40 characters, 320 bits at 115200 bits/second? Every 4 seconds? You can easily prove it by sending less frequently (it gets better) or even more frequently (it gets worse).
I think it’s more likely that you have not left a big enough delay to allow something else to complete before you send the serial data to the ESP, and it is that which is messing up the timing of the serial data. Try adding a small delay just before the Serial.print("CT1…
I concur.
Right, I don’t believe any mismatch of serial settings, as it works reliably beyond the first few characters I send.
It seems to be fairly frequent, like to the point where my first CT’s data isn’t reliably logged to a feed. Last time I got a good value for CT1_Rp was 8 hours ago per my EmonCMS inputs… my EmonCMS inputs fills with junk inputs because of this…
I’m going to try a couple of things, based on feedback here.
  1. I’ll try and add a delay of sorts before sending my data to the EmonESP from my device (I’m using a Teensy 3.2).
  2. I’m also going to try and re-flash the EmonESP firmware to the ESP-12F to see if that helps (not at the same time as the above change of course).
Thanks for the input! For those curious what my hardware looks like, see here.
So I re-flashed my ESP-12F with the latest & greatest EmonESP. So far it’s missed a couple of those first characters in the past few minutes… I’ll keep an eye on it, and if it’s still bad I’ll make those above mentioned ‘delay’ modifications to my firmware that runs on the Teensy 3.2.
What’s curious is that this setup has been running like this for over a year with no issues, then in the past few weeks this issue started to occur.
It would have been helpful to know that from the beginning. So what has been updated/updated itself recently?
I don’t believe anything had been updated prior to this happening.
Consequently, I just saw the issue started in again 5 hours ago after logging into my installation of EmonCMS. I re-flashed my EmonESP when I posted last - about 20 days ago. It has worked fine until just 5 hours ago! Strange.
No updates to EmonESP firmware, no changes to my MCU that sends it data, just randomly started happening.
Unfortunately my EmonESP inputs then fills up with gibberish values as shown above. I have used some commands to clean the SQL database out of the 1000s extraneous inputs… IE something like
“DELETE FROM input WHERE input.id > XXXX”
Since all these are newer than other values, and EmonCMS keeps track of them by incrementing the input.id, it’s at least easy to clean.
You can see in the EmonESP logs where it now consistently misses the first character, sometimes more:
Note as of now we’re at 358,661 successful messages, and since I send messages every 4 seconds, about 16.5 days. (must’ve lost power since I flashed it 20 days ago)
Curious.
Now that I’ve looked at the EmonESP logs, I see that they’re not evenly spaced out every 4 seconds like I would think they should be based on my code that sends this data to the ESP… Hm.
Where is the data coming from for the EmonESP to pass on? Is it an EmonTX?
Are you sure it is getting to the EmonESP correctly?
Don’t you mean, is the data arriving in the ESP8266 correct? I thought an emonESP is an emonTx with an ESP8266 inside the case. Although we think very many are in use and I can’t recollect anyone reporting a similar problem, it’s still worth checking if at all possible.
In my experience, a garbled serial message is usually due to a previous interrupt-driven process not having completed, resulting in the timing of the serial data being disturbed. And the easy cure is to add a delay to allow that first process to complete. If that’s what is happening, then the ESP8266 is doing exactly as it ought - and passing on the garbled data it’s receiving. No amount of reflashing it will cure that.
@fillycheezstake
Have you included the delay I suggested? It should go before the print statement that issues the missing first character.
The output isn’t exactly the same as the default sketch, so it’s clearly not running that. Without sight of the emonTx sketch, I can’t attempt to replicate your problem.
Well I did but I asked where was the data coming from for the EmonESP to pass on - same difference.
The EmonESP is just an ESP with the EmonESP firmware - doesn’t need to be connected to an EmonTX.
If there is a conversation elsewhere about modifying the EmonTX sketch, I’d suggest hooking the EmonTX to something else to monitor the serial output for a while.
I know this post is nearly a year old but did you ever find a solution, started to notice this with one of my emontxv3 boards.
Also don’t recall seeing this before i updated both with the newer continuous monitoring firmware and strange that its only affecting one of them.
I swapped the boards around last night just in case something it was monitoring was influencing it but the issue seems to have followed the board
Welcome, Jake, to OEM.
We never heard the outcome, so one of three possibilities - the OP corrected the problem, or it went away, or they live with it.
The first thing that springs to mind when somebody writes that is it’s an edge case involving temperature or timing.
If you have a programmer, I suggest adding the delay I mentioned, because it appears that the OP wasn’t using the standard emonTx software, but we don’t know the changes made.
I think the emomtx might actually be restarting, some of the feeds generated by the emonesp look like init output from the emontx
going to hook up the serial connection and see whats going on
Yes, that happens, but it should only happen once. If the emonTx is continually restarting, then the most likely explanation is an inadequate power supply. There’s no possibility of the on-board 3.3 V from the a.c. adapter supporting the ESP8266, a good 5 V USB supply and a high current (low resistance) cable is essential.
i’ve ordered some better shorter cables
is 2.1a for the pair of them enough?
2.1 Amps? It should be - I think an ESP8266 draws around 800 mA, the emonTx well less than the 200 mA remaining available (more like 20 mA).
But if the cables don’t solve the problem, I’d wonder about using the charger built into the socket. We don’t have details of any tests done on those, but some USB chargers are good for battery charging but not good as a power supply (i.e. a lot of noise on the output).
so the new power cables and adaptor made no difference to the misbehaving emontx
I’ve sniffed the serial traffic while its having one of its episodes
ignore the reboots that’s me,
these messages are also dropping fairly frequently they’re about 1s apart which doesn’t seem right
MSG:531,Vrms:239.26,P1:154,P2:148,P3:1,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:533,Vrms:239.19,P1:153,P2:144,P3:2,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:535,Vrms:239.20,P1:153,P2:147,P3:1,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:536,Vrms:239.10,P1:153,P2:148,P3:1,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:537,Vrms:239.11,P1:154,P2:144,P3:1,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:538,Vrms:239.05,P1:153,P2:146,P3:1,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:539,Vrms:239.05,P1:153,P2:149,P3:0,P4:-2,E1:24,E2:20,E3:0,E4:0,pulse:0
MSG:549,Vrms:238.56,P1:153,P2:148,P3:0,P4:-2,E1:25,E2:20,E3:0,E4:0,pulse:0
MSG:550,Vrms:238.48,P1:153,P2:150,P3:1,P4:-2,E1:25,E2:20,E3:0,E4:0,pulse:0
,E4:0,pulse:0
rms:238.48,P1:153,P2:151,P3:0,P4:-2,E1:25,E2:20,E3:0,E4:0,pulse:0
MSG:552,Vrms:238.52,P1:155,P2:151,P3:1,P4:-3,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:553,Vrms:238.74,P1:153,P2:153,P3:0,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:554MSG:555,Vrms:238.93,P1:153,P2:147,P3:2,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:556,Vrms:238.94,P1:154,P2:148,P3:1,P4:-3,E198,P1:153,P2:152,P3:1,P4:-3,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:559,Vrms:239.00,P1:154,P2:150,P3:2,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:560,Vrms:239.16,P1:154,P2:150,P3:0,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:5639.25,P1:153,P2:149,P3:1,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:562,Vrms:239.28,P1:153,P2:147,P3:1,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:563,Vrms:239.35,P1:153,P2:154,P3:2,P4:-2,E1:25,E2:21,E3:0,E4:0,pulse:0
MSG:564,Vrms:239.45,P1:153,P2:147,P3:0,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
1,P1:153,P2:148,P3:2,P4:-2,E1:26,E0,pulse:0
MSG:566,Vrms:239.26,P1:153,P2:148,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
MSG:567,Vrms:239.16,P1:154,P2:148,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
MSG:568,Vrms:239.13,P1:154,P2:149,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
1,Vrms:2MSG:569,Vrms:239.16,P1:154,P2:150,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
MSG:570,Vrms:239.18,P1:153,P2:151,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
MSG:571,Vrms:239.21,P1:153,P2:148,P3:0,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
MSG:572,Vrms:239.17,P1:153,P2:151,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
MSG:573,Vrms:239.27,P1:154,P2:149,P3:1,P4:-2,E1:26,E2:21,E3:0,E4:0,pulse:0
emonTx V3.4 EmonLibCM Continuous Monitoring V2.10
OpenEnergyMonitor.org
Loaded EEPROM config
Settings:
Gro = 0
pulse period = 100
temp_enable = 1
RF whitened
RFM69CW only Node: 15 Freq: 433MHz Group: 210
POST.....wait 10s
'+++' then [Enter] for config mode
Lead = 4.20
i2Cal = 90.90
i2Lead = 4.20
i3Cal = 90.90
i3Lead = 4.20
i4Cal = 16.67
i4Lead = 6.00
datalog = 1.00
pulsesre measuCT1 detected, i1Cal:90.90
CT2 detected, i2Cal:90.90
CT3 detected, i3Cal:90.90
CT4 detected, i4Cal:16.67
Temperature Sensors found = 0 of 3
Temperaturement is enabled.
AC present
MSG:1,Vrms:239.24,P1:154,P2:316,P3:2,P4:-1,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:2,Vrms:239.11,P1:154,P2:321,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:3,Vrms:239.06,P1:153,P2:320,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:4,Vrms:239.27,P1:153,P2:322,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:5,Vrms:239.36,P1:153,P2:338,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:6,38,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:8,Vrms:239.50,P1:154,P2:333,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:7,Vrms:239.43,P1:154,P2:331,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:9,Vrms:239.51,P1:154,P2:334,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:10,Vrms:239.47,P1:154,P2:337,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:11,Vrms:239.49,P1:153,P2:331,P3:2,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:1239.30,P1:154,P2:329,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,p,Vrms:239.44,P1:154,P2:329,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:13,Vrms:239.30,P1:154,P2:330,P3:2,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:14,Vrms:239.37,P1:154,P2:328,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:15,Vrms:2Vrms:239.80,P1:154,P2:325,P3:3,P4:-2,E1:1,E2:2,E3:0,E4:0,pulMSG:25,Vrms:239.76,P1:153,P2:325,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:26,Vrms:239.85,P1:154,P2:323,P3:1,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:27,Vrms:239.76,P1:153,P2:320,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:28,Vrms:240.02,P1:155,P2:317,P3:1,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
se:0
.11,P1:155:314,P3:1,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
240.05,P1:155,P2:318,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:33,Vrms:240.07,P1:155,P2:318,P3:2,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:34,Vrms:240,P2240.28,P1:156,P2:309,P3:2,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:40,Vrms:240.23,P1:154,P2:308,P3:3,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:41,Vrms:240.18,P1:156,P2:306,P3:2,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:420
Vrms:240.14,P1:157,P2:306,P3:2,P4:-2,E1:1,E2:3,E3:0,E4:04,P2:307,P3:2,P4:-2,E1:1,E2:4,E3:0,E4:0,pulse:0
MSG:47,Vrms:240.36,P1:151,P2:306,P3:1,P4:-3,E1:2,E2:4,E3:0,E4:0,pulse:0
MSG:48,Vrms:240.30,P1:152,P2:301,P3:0,Vrms:240.17,P1:155,P2:305,P3:1,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:MSG:43,MSG:45,Vrms:240.32,P1:157,P2:309,P3:2,P4:-2,E1:1,E2:4,E3:0,E4:0,pulse:0
MSG:46,Vrms:240.31,P1:154:0,pulse:0
5,P3:0,P4:-2,E1:2,E2:5,E3:0,E4:0,pulse:0
MSG:66,Vrms:240.20,P1:156,P2:285,P3:2,P4:-2,E1:2,E2:5,E3:0,E4:0,pulse:0
MSG:67,Vrms:240.21,P1:155,P2:284,P3:1,P4:-2,E1:2,E2:5,E3:0,E4:0,pulse:0
MSG:68,Vrms:240.22,P1:155,P2:283,P3:2,P4:-2,E1:2,E2:5,E3:0,E4:0,pulse:0
MSG:63,Vrms:240.21,P1:155,P2:288,P3:0,P4:-2,E1:2,E2:5,E3:0,E4:0,pulse:0
MSG:64,Vrms:240.18,P1:153,P2:288,P3:2,P4MSG:71,Vrms:240.06,P1:155,P2:279,P3:0,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
155,P2:283,P3:0,P4:-2,E1:2,E2:5,E3:0,E4:0,pulse:0
MSG:70,Vrms:240.13,P1:156,P2:282,P3:1,P4:-2,E1:2,E2:6,E3:0,E4:0,pulse:0
MSG:72,Vrms:240.02,P1:156,P2:286,P3:1,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:73,Vrms:240.07,P1:156,P2:283,P3:0,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:74,Vrms:240.02,P1:155,P2:284,P3:2,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:75,Vrms:239.94,P1:156,P2:279,P3:0,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:76,Vrms:239.92,P1:155,P2:281,P3:1,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:77,Vrms:239.90,P1:154,P2:282,P3:0,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:78,Vrms:239.85,P1:155,P2:281,P3:1,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:79,Vrms:231:155,P29.87,P:282,P3:1,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:80,Vrms:239.94,P1:155,P2:279,P3:1,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:81,Vrms:239.87,P1:155,P2:280,P3:0,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:82,Vrms:239.80,P1:155,P2:281,P3:1,P4:-2,E1:3,E2:6,E3:0,E4:0,pulse:0
MSG:83,Vrms:239.61,P1:155,P2:279,P3:1,P4:-2,E1:3,MSG:84,Vrms:239.61,P1:154,P2:280,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:85,Vrms:239.73,P1:155,P2:2:0
MSG:89,Vrms:239.69,P1:155,P2:282,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
79,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:86,Vrms:239.63,P1:155,P2:278,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:87,Vrms:239.61,P1:154,P2:281,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:88,Vrms:239.66,P1:154,P2:282,P3:0,P4:-2,E1:3,E2:7,E3:0,E4:0,pulseMSG:91,Vrms:239.68,P1:154,P2:283,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:90,Vrms:239.62,P1:154,P2:283,P3:1,P4:-2,E4:0,pulse:0
MSG:92,Vrms:239.77,P1:155,P2:282,P3:1,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:93,Vrms:239.85,P1:154,P2:282,P3:2,P4:-2,E1:3,E2:7,E3:0,E4:0,pulse:0
MSG:94,Vrms:239.89,P1:155,P2:282,P3:1,P4:-2,E1:4,E2:7,E3:0,E4:0,pulse:0
MSG:95,Vrms:239.78,P1:155,P2:286,P3:2,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:96,Vrms:239.79,P1:154,P2:284,P3:1,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:97,Vrms:239.77,P1:155,P2:285,P3:1,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:98,Vrms:239.75,P1:154,P2:284,P3:1,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:99,Vrms:239.62,P1:281,P3:2,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:100,Vrms:239.39,P1:154,P2:284,P3:1,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:101,Vrms:239.30,P1:154,P2:285,P3:1,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:103,Vrms:239.43,P1:154,P2:286,P3:1,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:102,Vrms:239.42,P1:154,P2:284,P3:0,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:106,Vrms:239.44,P1:154,P2:284,P3:0,P4:-2,E1:4,E2:8,E3:0,E4:0,pulse:0
MSG:108,Vrms:239.47,P1:154,P2:284,P3:1,P4:-2,E1:4,E2:9,E3:0,E4:0,pulse:0
MSG:110,Vrms:239.52,P1:154,P2:284,P3:1,P4:-2,E1:4,E2:9,E3:0,E4:0,pulse:0
MSG:114,Vrms:239.81,P1:154,P2:290,P3:2,P4:-2,E1:4,E2:9,E3:0,E4:0,pulse:0
MSG:115,Vrms:239.65,P1:155,P2:288,P3:1,P4:-2,E1:4,E2:9,E3:0,E4:0,pulse:0
MSG:116,Vrms:239.51,P1:154,P2:285,P3:1,P4:-2,e:0
MSG:117,Vrms:239.50,P1:153,P2:285,P3:0,P4:-2,E1:5,E2:9,E3:0,E4:0,pulse:0
MSG:118MSG:120,Vrms:239.59,P1:154,P2:284,P3:1,P4:-2,E1:5,E2:9,E3:0,E4:0,pulse:0
MSG:121,Vrms:239.54,P1:154,P2:289,P3:1,P4:-2,E1:5,E2:10,E3:0,E4:0,pulseMSG:123,Vrms:239.40,P1:154,P2:284,P3:0,P4:-2,E1:5,E2:10,E3:0,E4:0,pulse:0
MSG:124,Vrms:239.46,P1:155,P2:289,P3:1,P4:-2,E1:5,E2:10,E3:0,E4:0,pulse:0
MSG:125,Vrms:239.47,P1:154,P2:291,P3:0,P4:-2,E1:5,E2:10,E3:0,E4:0,pulse:0
MSG:126,Vrms:239.38,P1:153,P2:292,P3:1,P4:-2,E1:5,E2:10,E3:0,E4:0,pulse:0
MSG:127,Vrms:239.37,P1:154,P2:296,P3:1,P4:-2,E1:5,E2:10,E3:0,E4:0,pulse:0
F whitened
POST.....wait 10s
Settings:
Group 210, Node 15, Band 433 MHz
Calibration:
vCal = 268.97
assumedV = 240.00
i1Cal = 90.90
i1Lead = 4.20
i2Cal = 90.90
i2Lead = 4.20
i3Cal = 90.90
i3Lead = 4.20
i4Cal = 16.67
i4Lead = 6.00
datalog = 1.00
pulses = 0
pulse period = 100
temp_enable = 1
R:0,pulse:0
MSG:2,Vrms:238.98,P1:154,P2:290,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:3,VrmCT1 detected, i1Cal:90.90
s:238.98,P1:154,P2:289,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:4,V6,P1:154,P2:290,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:5,Vrms:238.88,P1:154,P2:292,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:6,Vrms:238.82,P1:153,P2:290,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:7,Vrms:238.87,P1:155,P2:295,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:8,Vrms:239.11,P1:153,P2:301,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:9,Vrms:239.12,P1:154,P2:301,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:10,Vrms:239.14,P1:154,P2:292,P3:2,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:11,Vrms:239.03,P1:153,P2:289,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pulse:0
MSG:12,Vrms:239.07,P1:154,P2:289,P3:1,P4:-2,E1:0,E2:0,E3:0,E4:0,pu
ms:239.19,P1:154,P2:286,P3:0,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:14,Vrms:239.17,P1:155,P2:288,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:15,Vrms:239.26,P1:153,:1,P4:-2,E1:0,E2:1,MSG:21,Vrms:239.23,P1:155,P2:296,P3:0,P4:-2,E1:0,E2:1,E3:0:239.36,P1:154,P2:299,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:18,Vrms:239.36,P1:154,P2:300,P3:0,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:19,Vrms:239.26,P1:153,P2:299,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:20239.28,P1:154,P2:290,P3:0,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:22,Vrms:239.14,P1:155,P2:294,P3:1,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:23,Vrms:239.21,P1:155,P2:293,P3:0,P4:-2,E1:0,E2:1,E3:0,E4:0,pulse:0
MSG:24,Vrms:239.13,P1:154,P2:295,P3:1,P4:-2,E1:1,E2:1,E3:0,E4:0,pulse:0
MSG:25,Vrms:239.09,P1:154,P2:294,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:26,Vrms:239.10,P1:154,P2:293,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:27.10,P1:156,P2:294,P3:1,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:28,Vrms:238.99,P1:154,P2:291,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:32,Vrms:238.78,P1:155,P2:24:-2,E1:1,E2:2,E3:0,E,Vrms:239MSG:30,Vrms:238.92,P1:155,P2:296,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:31,Vrms:238.93,P1:155,P2:294,P3:0,P4:-2MSG:34,Vrms:238.93,P1:155,P2:292,P3:1,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:35,Vrms:238.91,P1:155,P2:293,P3:2,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:36,Vrms:238.96,P1:155,P2:294,P3:0,P4:-2,E1:1,E2:2,E3:0,E4:0,pulse:0
MSG:37.21,P1:292,P3:0,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
,Vrms:239.09,P1:155,P2:292,P3:1,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:38,Vrms:239:154,P2Vrms:239.35,P1:155,P2:305,P3:1,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:43,Vrms:239.27,P1:155,P2:296,P3:0,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:44,Vrms:239.17,P1:154,P2:291,P3:1,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:45,Vrms:239.24,P1:154,P2:295,P3:1,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
MSG:46,Vrms:239.11,P1:155,P2:290,P3:0,P4:-2,E1:1,E2:3,E3:0,E4:0,pulse:0
E3:0,E4:0,pulse:0
2,P3:1,P4:-2,E1:2,E2:4,E3:0,E4:0,pulse:0
MSG:51,Vrms:239.23,P1:153,P2:295,P3:1,P4:-2,E1:2,E2:4,E3:0,E4:0,pulse:0
MSG:52,Vrms:239.24,P1:154,P2:292,P3:1,P4:-2,E1:2,E2:4,E3:0,E4:0,pulse:0
MSG:53,Vrms:239.31,P1:154,P2:293,P3:1,P4:-2,E1:2,E2:4,E3:0,E4:0,pulse:0
MSG:47,Vrms:239.15,P1:154,P2:289,P3:0,P4:-2,E1:2,E2:3,```
