Just starting to commission my 6kW 22S Lithium Titanate Oxide ( LTO ) and the upper voltage on this battery bank is 61.25V, i have setup up a emondc to monitor the current and the battery voltage, I am finding that i can not get a reading above 55.7 volts, this battery banks gets below 44 volts, when i monitor the Victron mppt controller to get the calibration of the emondc it is within 0.06 volts, but when i get above the 55.7 volts the reading will not rise even thou the battery is 61.25 volts, Is this a firmware limitation?
Hi all,
I just change from 36V to 48V system. YES am still using the EmonDC, i get same valtage limitation not more than 54V. Can someone help. please
Gilles
Use a voltage divider made of 2 resistors and recalibrate the voltage. Also I do have some of the versions of firmware in my cloud.
Hi Ross,
Thanks for your reply.
Yes that seems a good idea. I will try.
Do we need to add the voltage divider at the shunt/Source pad.
Or do we need to connect to the V sense pad.
Please
