Emoncms V9.8.0 iphone Can't select items on mobile webpage after update
Since updating my emonpi to V9.8.0 I can’t access any of the menu items on the mobile webpage.using an iPhone I’ve tried this on 3 separate phones, and on 2 copies of EMONCMS. The mobile menu expands when I select the top level items, but I can’t select any of the items underneath. I can only select the main dashboard and the logout button.
I can however get to the individual items by putting the full URL such as
http://192.168.8.77/emoncms/config/view into the address bar.
Its only the navigation that seems broken. and It works OK on Windows 10, both desktop and tablet. Both local http and remote https which I’ve just enabled seem aflicted, and at least 1 of the phones would have never seen the system before so that should rule out cache in the phone issues
UPDATE:
I have just rolled the system back to before the update and it works fine, until I click the update button in the web interface, which breaks it again. Log attached for the updateemonpiupdate.txt (17.7 KB)
Is this a known issue @glyn.hudson
Copying the previous /var/www/emoncms directory over the top of the newer version restores the functionality too, so something that is replaced with git pull is breaking the mobile web page
Hi Kevin,
Thanks for letting us know. V9.8.2 (current master) works fine on an Android:
I don’t have an iphone at hand to test, could you post a screenshot?
Any insight into what could be causing the issue?
Does anyone else have an iphone to test
How can I get into 9.8.2 - git pull as of 12 hours ago gave me 9.8.0, although as the navigation is totally different I think the Android one is loading a different style sheet?
The navigation screen in your screenshot is different to the iPhone one which has a single menu with 2 levels, see attached - in the screenshot it’s “My Electric and My Solar” that can’t be selected. The “Extra” and “Setup” tabs also expand but nothing in them can be selected. According to the logs it’s loading “bootstrap-responsive.min.css” and simply replacing that file with an earlier version doesn’t seem to fix it.
V9.8.2 is the latest master branch while V9.8.0 is the stable branch. If you did want to try the latest master branch you can switch using:
git checkout master
git pull origin master
I’m working away this week, When I’m back at the office next week I will dig out an iphone and test. Sorry for the delay.
Out of interest, do you have the same issue if you hold the phone in landscape. What iphone, Safari version and ios version are you using?
Same issue in landscape mode,and I’ve tested on iPhone 6 ios10.2.1, iPhone 5 ios10.2.1, iPhone 4, ios 7.1.2 .
All seem OK on EMONCMS V9.7.7, so I’ll leave the Pi with that version until you get time to recreate the issue
Looks and works OK on this device - viewed on Safari (and Chrome) on an iPhone 5c, ios10.2.1.
That’s interesting as it seems to be the same template that @glyn.hudson has on his Android, I have a different template on mine which has a single icon on the right - see the picture in post 4.
I wonder how it decides which template to serve? Perhaps my template is obsolete and needs deleting.
Yes, this sounds like the issue. Can you test with the default Emoncms template?
Can you also test loading Emoncms from https://emoncms.org on your iphone? This should work fine.
This issue must be with your installation
How do I get the other template to load? It’s been the single icon template I sent a screen picture of since I migrated to V9.
Emoncms.org is the same template as on your phone and it seems to work.
I’m back on V9.7.7 now and it’s working on the single icon template, so that one stops working when I migrate to 9.8.0.
Has it been retired at some stage and my install hasn’t noticed? What decides what is served to a particular device?
The ‘basic’ theme and bootstrap lib should be included in the default Emoncms core.
https://github.com/emoncms/emoncms/tree/master/Theme/basic
Can you check you have the updated template files by running
cd /var/www/emoncms
git checkout master
git status
All done and working - I now have the same layout as you guys. There was a bit of git weirdness, including suggestions I should stash changes which I don’t even remember doing. After googling I entered
git reset --hard
and it stopped complaining. I guess something somewhere was changed which stopped the original update from working properly.
