I’ve just gone back over this log, and I strongly suggest it is an internal network issue. Whilst you may not see it on other machines, that does not exclude your router ‘not liking’ the Pi. I guess it is connected via Wi-Fi and that is a fickle beast. To exclude Wi-Fi as the issue, you need to either connect to a different AP (preferably one with just a 2.4MHz SSID available) or use an ethernet cable.
Note the software does recover where it can; the failures are interspersed with sending the buffered data.
2020-07-26 00:56:31,799 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721365.2993395,5,39,-3,36,241.77,0,0,0,0,0,0,0],[1595721370.2700872,5,41,0,41,242.70000000000002,0,0,0,0,0,0,0],[1595721375.322579,5,38,8,46,239.65,0,0,0,0,0,0,0],[1595721375.4420671,8,0,1,229,0,252.66,300,300,300,300,300,300,0,-29],[1595721380.3053825,5,41,6,47,242.47,0,0,0,0,0,0,0],[1595721385.2897246,5,14,1,15,242.67000000000002,0,0,0,0,0,0,0],[1595721385.4076974,8,0,1,256,0,252.81,300,300,300,300,300,300,0,-28],[1595721390.2920363,5,17,-8,9,242.93,0,0,0,0,0,0,0]]&sentat=1595721391
2020-07-26 00:57:49,201 WARNING emoncmsorg emoncmsorg couldn't send to server: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2020-07-26 00:57:49,202 WARNING emoncmsorg send failure: wanted 'ok' but got 'None'
2020-07-26 00:58:19,290 DEBUG emoncmsorg Buffer size: 40
2020-07-26 00:58:19,295 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721365.2993395,5,39,-3,36,241.77,0,0,0,0,0,0,0],[1595721370.2700872,5,41,0,41,242.70000000000002,0,0,0,0,0,0,0],[1595721375.322579,5,38,8,46,239.65,0,0,0,0,0,0,0],[1595721375.4420671,8,0,1,229,0,252.66,300,300,300,300,300,300,0,-29],[1595721380.3053825,5,41,6,47,242.47,0,0,0,0,0,0,0],[1595721385.2897246,5,14,1,15,242.67000000000002,0,0,0,0,0,0,0],[1595721385.4076974,8,0,1,256,0,252.81,300,300,300,300,300,300,0,-28],[1595721390.2920363,5,17,-8,9,242.93,0,0,0,0,0,0,0],[1595721395.285541,5,34,7,41,242.9,0,0,0,0,0,0,0],[1595721395.409052,8,0,1,264,0,252.92000000000002,300,300,300,300,300,300,0,-28],[1595721400.373789,5,-4,16,12,242.43,0,0,0,0,0,0,0],[1595721404.8403149,8,0,1,253,0,252.84,300,300,300,300,300,300,0,-28],[1595721405.4609249,5,16,2,18,242.39000000000001,0,0,0,0,0,0,0],[1595721410.3332882,5,25,-3,22,242.18,0,0,0,0,0,0,0],[1595721414.7877738,8,0,0,266,0,252.95000000000002,300,300,300,300,300,300,0,-28],[1595721415.412424,5,-6,12,6,242.22,0,0,0,0,0,0,0],[1595721420.3501878,5,29,-4,25,243.21,0,0,0,0,0,0,0],[1595721424.6179383,8,0,1,233,0,253.06,300,300,300,300,300,300,0,-28],[1595721425.4440935,5,37,10,47,241.94,0,0,0,0,0,0,0],[1595721430.406607,5,23,2,25,242.91,0,0,0,0,0,0,0],[1595721434.5781276,8,0,1,227,0,253.11,300,300,300,300,300,300,0,-28],[1595721435.3994215,5,48,-4,44,242.09,0,0,0,0,0,0,0],[1595721440.3642502,5,28,0,28,241.68,0,0,0,0,0,0,0],[1595721444.5209508,8,0,0,246,0,253,300,300,300,300,300,300,0,-28],[1595721445.3485134,5,28,2,30,242.86,0,0,0,0,0,0,0],[1595721450.395642,5,8,-1,7,242.98000000000002,0,0,0,0,0,0,0],[1595721454.3391504,8,0,1,248,0,253.04,300,300,300,300,300,300,0,-28],[1595721455.3619828,5,8,9,17,242.15,0,0,0,0,0,0,0],[1595721460.4250638,5,66,-5,61,242.11,0,0,0,0,0,0,0],[1595721464.2810664,8,1,1,213,0,252.96,300,300,300,300,300,300,0,-28],[1595721465.4058502,5,0,-9,-9,241.63,0,0,0,0,0,0,0],[1595721470.359067,5,26,-6,20,242.67000000000002,0,0,0,0,0,0,0],[1595721474.2093008,8,0,0,245,0,253.01000000000002,300,300,300,300,300,300,0,-28],[1595721475.432744,5,52,-1,51,241.32,0,0,0,0,0,0,0],[1595721480.3935678,5,13,4,17,242.36,0,0,0,0,0,0,0],[1595721484.0546203,8,0,1,271,0,253.04,300,300,300,300,300,300,0,-29],[1595721485.477837,5,71,-2,69,242.84,0,0,0,0,0,0,0],[1595721490.5415988,5,10,-9,1,243.13,0,0,0,0,0,0,0],[1595721493.9912837,8,1,2,253,0,252.72,300,300,300,300,300,300,0,-32],[1595721495.530174,5,35,6,41,241.99,0,0,0,0,0,0,0]]&sentat=1595721499
2020-07-26 00:58:19,627 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
2020-07-26 00:58:49,716 DEBUG emoncmsorg Buffer size: 9
2020-07-26 00:58:49,718 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721500.4966364,5,76,12,88,242.04,0,0,0,0,0,0,0],[1595721503.9340851,8,0,0,285,0,252.92000000000002,300,300,300,300,300,300,0,-29],[1595721505.5649207,5,32,3,35,242.76,0,0,0,0,0,0,0],[1595721510.6261597,5,50,2,52,242.37,0,0,0,0,0,0,0],[1595721513.7884817,8,0,1,304,0,253,300,300,300,300,300,300,0,-28],[1595721515.5335834,5,6,2,8,242.73000000000002,0,0,0,0,0,0,0],[1595721520.5960112,5,52,6,58,243.04,0,0,0,0,0,0,0],[1595721523.7556305,8,1,1,239,0,253.13,300,300,300,300,300,300,0,-29],[1595721525.5933404,5,41,0,41,242.91,0,0,0,0,0,0,0]]&sentat=1595721529
2020-07-26 00:59:46,927 WARNING emoncmsorg emoncmsorg couldn't send to server: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2020-07-26 00:59:46,928 WARNING emoncmsorg send failure: wanted 'ok' but got 'None'
2020-07-26 01:00:17,007 DEBUG emoncmsorg Buffer size: 36
2020-07-26 01:00:17,014 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721500.4966364,5,76,12,88,242.04,0,0,0,0,0,0,0],[1595721503.9340851,8,0,0,285,0,252.92000000000002,300,300,300,300,300,300,0,-29],[1595721505.5649207,5,32,3,35,242.76,0,0,0,0,0,0,0],[1595721510.6261597,5,50,2,52,242.37,0,0,0,0,0,0,0],[1595721513.7884817,8,0,1,304,0,253,300,300,300,300,300,300,0,-28],[1595721515.5335834,5,6,2,8,242.73000000000002,0,0,0,0,0,0,0],[1595721520.5960112,5,52,6,58,243.04,0,0,0,0,0,0,0],[1595721523.7556305,8,1,1,239,0,253.13,300,300,300,300,300,300,0,-29],[1595721525.5933404,5,41,0,41,242.91,0,0,0,0,0,0,0],[1595721530.564131,5,11,10,21,241.91,0,0,0,0,0,0,0],[1595721533.6248238,8,0,1,278,0,252.88,300,300,300,300,300,300,0,-28],[1595721535.551502,5,9,0,9,242.39000000000001,0,0,0,0,0,0,0],[1595721540.6006122,5,26,-6,20,242.28,0,0,0,0,0,0,0],[1595721543.541161,8,0,1,263,0,253.11,300,300,300,300,300,300,0,-28],[1595721545.572008,5,36,8,44,242.79,0,0,0,0,0,0,0],[1595721550.543105,5,28,-2,26,242.52,0,0,0,0,0,0,0],[1595721553.3978488,8,0,0,286,0,252.62,300,300,300,300,300,300,0,-28],[1595721555.6400719,5,32,3,35,241.81,0,0,0,0,0,0,0],[1595721560.5924678,5,16,11,27,242.72,0,0,0,0,0,0,0],[1595721563.335027,8,0,1,285,0,252.93,300,300,300,300,300,300,0,-28],[1595721565.5725543,5,33,-2,31,242.72,0,0,0,0,0,0,0],[1595721570.6284306,5,21,-5,16,242.73000000000002,0,0,0,0,0,0,0],[1595721573.2747355,8,0,1,290,0,252.84,300,300,300,300,300,300,0,-29],[1595721575.719619,5,3,-17,-14,242.39000000000001,0,0,0,0,0,0,0],[1595721580.6719935,5,66,8,74,242.85,0,0,0,0,0,0,0],[1595721583.1107914,8,0,2,250,0,253.08,300,300,300,300,300,300,0,-29],[1595721585.6476479,5,5,12,17,242.62,0,0,0,0,0,0,0],[1595721590.6154983,5,32,-1,31,241.77,0,0,0,0,0,0,0],[1595721593.0571353,8,0,1,240,0,252.9,300,300,300,300,300,300,0,-28],[1595721595.588118,5,46,6,52,242.34,0,0,0,0,0,0,0],[1595721600.6626167,5,46,7,53,242.97,0,0,0,0,0,0,0],[1595721603.0053282,8,0,0,308,0,252.88,300,300,300,300,300,300,0,-28],[1595721605.668775,5,30,11,41,242.74,0,0,0,0,0,0,0],[1595721610.6431515,5,37,-2,35,242.59,0,0,0,0,0,0,0],[1595721612.8798814,8,0,1,229,0,252.8,300,300,300,300,300,300,0,-29],[1595721615.7176247,5,-4,-14,-18,241.5,0,0,0,0,0,0,0]]&sentat=1595721617
2020-07-26 01:00:32,376 WARNING emoncmsorg emoncmsorg couldn't send to server: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2020-07-26 01:00:32,378 WARNING emoncmsorg send failure: wanted 'ok' but got 'None'
2020-07-26 01:01:02,464 DEBUG emoncmsorg Buffer size: 49
2020-07-26 01:01:02,471 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721500.4966364,5,76,12,88,242.04,0,0,0,0,0,0,0],[1595721503.9340851,8,0,0,285,0,252.92000000000002,300,300,300,300,300,300,0,-29],[1595721505.5649207,5,32,3,35,242.76,0,0,0,0,0,0,0],[1595721510.6261597,5,50,2,52,242.37,0,0,0,0,0,0,0],[1595721513.7884817,8,0,1,304,0,253,300,300,300,300,300,300,0,-28],[1595721515.5335834,5,6,2,8,242.73000000000002,0,0,0,0,0,0,0],[1595721520.5960112,5,52,6,58,243.04,0,0,0,0,0,0,0],[1595721523.7556305,8,1,1,239,0,253.13,300,300,300,300,300,300,0,-29],[1595721525.5933404,5,41,0,41,242.91,0,0,0,0,0,0,0],[1595721530.564131,5,11,10,21,241.91,0,0,0,0,0,0,0],[1595721533.6248238,8,0,1,278,0,252.88,300,300,300,300,300,300,0,-28],[1595721535.551502,5,9,0,9,242.39000000000001,0,0,0,0,0,0,0],[1595721540.6006122,5,26,-6,20,242.28,0,0,0,0,0,0,0],[1595721543.541161,8,0,1,263,0,253.11,300,300,300,300,300,300,0,-28],[1595721545.572008,5,36,8,44,242.79,0,0,0,0,0,0,0],[1595721550.543105,5,28,-2,26,242.52,0,0,0,0,0,0,0],[1595721553.3978488,8,0,0,286,0,252.62,300,300,300,300,300,300,0,-28],[1595721555.6400719,5,32,3,35,241.81,0,0,0,0,0,0,0],[1595721560.5924678,5,16,11,27,242.72,0,0,0,0,0,0,0],[1595721563.335027,8,0,1,285,0,252.93,300,300,300,300,300,300,0,-28],[1595721565.5725543,5,33,-2,31,242.72,0,0,0,0,0,0,0],[1595721570.6284306,5,21,-5,16,242.73000000000002,0,0,0,0,0,0,0],[1595721573.2747355,8,0,1,290,0,252.84,300,300,300,300,300,300,0,-29],[1595721575.719619,5,3,-17,-14,242.39000000000001,0,0,0,0,0,0,0],[1595721580.6719935,5,66,8,74,242.85,0,0,0,0,0,0,0],[1595721583.1107914,8,0,2,250,0,253.08,300,300,300,300,300,300,0,-29],[1595721585.6476479,5,5,12,17,242.62,0,0,0,0,0,0,0],[1595721590.6154983,5,32,-1,31,241.77,0,0,0,0,0,0,0],[1595721593.0571353,8,0,1,240,0,252.9,300,300,300,300,300,300,0,-28],[1595721595.588118,5,46,6,52,242.34,0,0,0,0,0,0,0],[1595721600.6626167,5,46,7,53,242.97,0,0,0,0,0,0,0],[1595721603.0053282,8,0,0,308,0,252.88,300,300,300,300,300,300,0,-28],[1595721605.668775,5,30,11,41,242.74,0,0,0,0,0,0,0],[1595721610.6431515,5,37,-2,35,242.59,0,0,0,0,0,0,0],[1595721612.8798814,8,0,1,229,0,252.8,300,300,300,300,300,300,0,-29],[1595721615.7176247,5,-4,-14,-18,241.5,0,0,0,0,0,0,0],[1595721620.678896,5,37,0,37,242.18,0,0,0,0,0,0,0],[1595721622.8181,8,0,0,242,0,252.99,300,300,300,300,300,300,0,-29],[1595721625.6719697,5,19,3,22,242.65,0,0,0,0,0,0,0],[1595721630.6494544,5,52,3,55,242.67000000000002,0,0,0,0,0,0,0],[1595721632.6971965,8,0,0,230,0,252.68,300,300,300,300,300,300,0,-28],[1595721635.6549573,5,10,0,10,242.17000000000002,0,0,0,0,0,0,0],[1595721640.6230807,5,40,2,42,242.85,0,0,0,0,0,0,0],[1595721642.5685434,8,0,0,237,0,253.1,300,300,300,300,300,300,0,-28],[1595721645.621127,5,13,9,22,242.9,0,0,0,0,0,0,0],[1595721650.6847603,5,10,1,11,242.61,0,0,0,0,0,0,0],[1595721652.519857,8,0,1,242,0,252.66,300,300,300,300,300,300,0,-29],[1595721655.6785293,5,55,12,67,241.67000000000002,0,0,0,0,0,0,0],[1595721660.7612135,5,53,4,57,242.8,0,0,0,0,0,0,0]]&sentat=1595721662
2020-07-26 01:01:54,935 WARNING emoncmsorg emoncmsorg couldn't send to server: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2020-07-26 01:01:54,936 WARNING emoncmsorg send failure: wanted 'ok' but got 'None'
2020-07-26 01:02:25,021 DEBUG emoncmsorg Buffer size: 74
2020-07-26 01:02:25,030 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721500.4966364,5,76,12,88,242.04,0,0,0,0,0,0,0],[1595721503.9340851,8,0,0,285,0,252.92000000000002,300,300,300,300,300,300,0,-29],[1595721505.5649207,5,32,3,35,242.76,0,0,0,0,0,0,0],[1595721510.6261597,5,50,2,52,242.37,0,0,0,0,0,0,0],[1595721513.7884817,8,0,1,304,0,253,300,300,300,300,300,300,0,-28],[1595721515.5335834,5,6,2,8,242.73000000000002,0,0,0,0,0,0,0],[1595721520.5960112,5,52,6,58,243.04,0,0,0,0,0,0,0],[1595721523.7556305,8,1,1,239,0,253.13,300,300,300,300,300,300,0,-29],[1595721525.5933404,5,41,0,41,242.91,0,0,0,0,0,0,0],[1595721530.564131,5,11,10,21,241.91,0,0,0,0,0,0,0],[1595721533.6248238,8,0,1,278,0,252.88,300,300,300,300,300,300,0,-28],[1595721535.551502,5,9,0,9,242.39000000000001,0,0,0,0,0,0,0],[1595721540.6006122,5,26,-6,20,242.28,0,0,0,0,0,0,0],[1595721543.541161,8,0,1,263,0,253.11,300,300,300,300,300,300,0,-28],[1595721545.572008,5,36,8,44,242.79,0,0,0,0,0,0,0],[1595721550.543105,5,28,-2,26,242.52,0,0,0,0,0,0,0],[1595721553.3978488,8,0,0,286,0,252.62,300,300,300,300,300,300,0,-28],[1595721555.6400719,5,32,3,35,241.81,0,0,0,0,0,0,0],[1595721560.5924678,5,16,11,27,242.72,0,0,0,0,0,0,0],[1595721563.335027,8,0,1,285,0,252.93,300,300,300,300,300,300,0,-28],[1595721565.5725543,5,33,-2,31,242.72,0,0,0,0,0,0,0],[1595721570.6284306,5,21,-5,16,242.73000000000002,0,0,0,0,0,0,0],[1595721573.2747355,8,0,1,290,0,252.84,300,300,300,300,300,300,0,-29],[1595721575.719619,5,3,-17,-14,242.39000000000001,0,0,0,0,0,0,0],[1595721580.6719935,5,66,8,74,242.85,0,0,0,0,0,0,0],[1595721583.1107914,8,0,2,250,0,253.08,300,300,300,300,300,300,0,-29],[1595721585.6476479,5,5,12,17,242.62,0,0,0,0,0,0,0],[1595721590.6154983,5,32,-1,31,241.77,0,0,0,0,0,0,0],[1595721593.0571353,8,0,1,240,0,252.9,300,300,300,300,300,300,0,-28],[1595721595.588118,5,46,6,52,242.34,0,0,0,0,0,0,0],[1595721600.6626167,5,46,7,53,242.97,0,0,0,0,0,0,0],[1595721603.0053282,8,0,0,308,0,252.88,300,300,300,300,300,300,0,-28],[1595721605.668775,5,30,11,41,242.74,0,0,0,0,0,0,0],[1595721610.6431515,5,37,-2,35,242.59,0,0,0,0,0,0,0],[1595721612.8798814,8,0,1,229,0,252.8,300,300,300,300,300,300,0,-29],[1595721615.7176247,5,-4,-14,-18,241.5,0,0,0,0,0,0,0],[1595721620.678896,5,37,0,37,242.18,0,0,0,0,0,0,0],[1595721622.8181,8,0,0,242,0,252.99,300,300,300,300,300,300,0,-29],[1595721625.6719697,5,19,3,22,242.65,0,0,0,0,0,0,0],[1595721630.6494544,5,52,3,55,242.67000000000002,0,0,0,0,0,0,0],[1595721632.6971965,8,0,0,230,0,252.68,300,300,300,300,300,300,0,-28],[1595721635.6549573,5,10,0,10,242.17000000000002,0,0,0,0,0,0,0],[1595721640.6230807,5,40,2,42,242.85,0,0,0,0,0,0,0],[1595721642.5685434,8,0,0,237,0,253.1,300,300,300,300,300,300,0,-28],[1595721645.621127,5,13,9,22,242.9,0,0,0,0,0,0,0],[1595721650.6847603,5,10,1,11,242.61,0,0,0,0,0,0,0],[1595721652.519857,8,0,1,242,0,252.66,300,300,300,300,300,300,0,-29],[1595721655.6785293,5,55,12,67,241.67000000000002,0,0,0,0,0,0,0],[1595721660.7612135,5,53,4,57,242.8,0,0,0,0,0,0,0],[1595721662.397204,8,0,1,261,0,252.72,300,300,300,300,300,300,0,-32],[1595721665.7427611,5,14,10,24,242.47,0,0,0,0,0,0,0],[1595721670.7069654,5,52,24,76,241.76,0,0,0,0,0,0,0],[1595721672.3522832,8,0,1,253,0,252.58,300,300,300,300,300,300,0,-28],[1595721675.709659,5,11,-12,-1,242.24,0,0,0,0,0,0,0],[1595721680.6707008,5,39,-9,30,242.55,0,0,0,0,0,0,0],[1595721682.1971116,8,0,1,230,0,252.3,300,300,300,300,300,300,0,-28],[1595721685.7427049,5,28,4,32,240.75,0,0,0,0,0,0,0],[1595721690.7162955,5,73,13,86,241.70000000000002,0,0,0,0,0,0,0],[1595721692.1463468,8,0,1,261,0,252.27,300,300,300,300,300,300,0,-27],[1595721695.7059405,5,54,0,54,241.23000000000002,0,0,0,0,0,0,0],[1595721700.7218435,5,9,1,10,242.11,0,0,0,0,0,0,0],[1595721702.0700736,8,0,1,262,0,252.42000000000002,300,300,300,300,300,300,0,-29],[1595721705.731052,5,8,-3,5,242.27,0,0,0,0,0,0,0],[1595721710.6990197,5,14,-3,11,242.22,0,0,0,0,0,0,0],[1595721711.9357183,8,0,0,254,0,252.39000000000001,300,300,300,300,300,300,0,-29],[1595721715.6870236,5,29,-8,21,242.48000000000002,0,0,0,0,0,0,0],[1595721720.7699866,5,12,-17,-5,242.61,0,0,0,0,0,0,0],[1595721721.8058774,8,0,2,257,0,252.70000000000002,300,300,300,300,300,300,0,-28],[1595721725.7497613,5,0,3,3,242.51,0,0,0,0,0,0,0],[1595721730.7118385,5,31,7,38,242.25,0,0,0,0,0,0,0],[1595721731.7424705,8,0,1,258,0,252.46,300,300,300,300,300,300,0,-28],[1595721735.7077775,5,-1,4,3,241.5,0,0,0,0,0,0,0],[1595721740.7000027,5,18,7,25,242.52,0,0,0,0,0,0,0],[1595721741.6381173,8,0,1,276,0,252.77,300,300,300,300,300,300,0,-28]]&sentat=1595721745
2020-07-26 01:02:25,376 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
2020-07-26 01:02:55,464 DEBUG emoncmsorg Buffer size: 9
2020-07-26 01:02:55,467 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595721745.696244,5,51,2,53,242.39000000000001,0,0,0,0,0,0,0],[1595721750.672602,5,43,-1,42,241.63,0,0,0,0,0,0,0],[1595721751.6044698,8,0,1,234,0,252.61,300,300,300,300,300,300,0,-28],[1595721755.7444847,5,13,11,24,242.24,0,0,0,0,0,0,0],[1595721760.7227302,5,13,-9,4,242.3,0,0,0,0,0,0,0],[1595721761.4483879,8,1,2,261,0,252.55,300,300,300,300,300,300,0,-28],[1595721765.707056,5,31,6,37,242.65,0,0,0,0,0,0,0],[1595721770.7791088,5,29,1,30,242.48000000000002,0,0,0,0,0,0,0],[1595721771.3100579,8,0,1,257,0,252.5,300,300,300,300,300,300,0,-28]]&sentat=1595721775
2020-07-26 01:02:55,792 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
