Hi All
Hoping someone can help me with troubleshooting my installation a little. I’m trying to set up monitoring in a community building that has a mixture of single and multi phase supplies. I have two EmonTx4 units and one EmonPi emonBase [edit by MOD]. So far we have only put one of the Tx4s in (channel 18). It has four inputs, the first three are multiphase with 3x50A sensors, then a single phase with a 20A. The sensors were installed by an electrician following the instructions (I am not an expert in circuits as such). I then went in and set up the EmonTx config as above using the Web UI.
I have set up the EmonPi emonBase [edit by MOD] to connect to the mesh wifi, which starts off OK. But I am now encountering 2 problems:
1 On the inputs tab of the EmonCMS I just get an endless waiting spinner, with no data being received;
2. Maybe due to this problem, the system may be gradually overloading, as eventually my web connection to the EmonPi emonBase [edit by MOD] starts to timeout (after about 5 mins), only being fixed by a reboot.
Some pointers on what might be happening and what to try next would be great. Unfortunately I can’t easily check the clamp installation as they are inside the switch box.
emonhub.log
2023-06-07 09:50:13,129 INFO MainThread EmonHub v2.5.5
2023-06-07 09:50:13,129 INFO MainThread Opening hub...
2023-06-07 09:50:13,130 INFO MainThread Running as user: pi
2023-06-07 09:50:13,130 INFO MainThread Logging level set to DEBUG
2023-06-07 09:50:13,130 INFO MainThread Creating EmonHubOEMInterfacer 'EmonPi2'
2023-06-07 09:50:13,131 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2023-06-07 09:50:13,133 INFO MainThread Creating EmonHubOEMInterfacer 'USB0'
2023-06-07 09:50:13,134 ERROR MainThread Could not open serial port: /dev/ttyUSB0 @ 115200 bits/s (retry every 10s)
2023-06-07 09:50:13,135 INFO MainThread Creating EmonHubRFM69LPLInterfacer 'SPI'
2023-06-07 09:50:13,151 INFO MainThread Creating RFM69 LowPowerLabs interfacer
2023-06-07 09:50:13,151 INFO MainThread node_id = 5
2023-06-07 09:50:13,151 INFO MainThread network_id = 210
2023-06-07 09:50:13,151 INFO MainThread Starting radio setup
2023-06-07 09:50:13,175 INFO MainThread Radio setup complete
2023-06-07 09:50:13,176 DEBUG MainThread Setting SPI pubchannels: ['ToEmonCMS']
2023-06-07 09:50:13,178 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2023-06-07 09:50:13,179 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2023-06-07 09:50:13,179 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2023-06-07 09:50:13,179 INFO MainThread Setting MQTT node_format_enable: 0
2023-06-07 09:50:13,180 INFO MainThread Setting MQTT nodevar_format_enable: 1
2023-06-07 09:50:13,180 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2023-06-07 09:50:13,180 INFO MainThread Setting MQTT node_JSON_enable: 0
2023-06-07 09:50:13,181 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2023-06-07 09:50:13,182 DEBUG MainThread Setting emoncmsorg interval: 30
2023-06-07 09:50:13,182 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2023-06-07 09:50:13,182 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2023-06-07 09:50:13,183 WARNING MainThread Setting emoncmsorg apikey: obscured
2023-06-07 09:50:13,183 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2023-06-07 09:50:13,183 INFO MainThread Setting emoncmsorg senddata: 1
2023-06-07 09:50:13,184 INFO MainThread Setting emoncmsorg sendstatus: 0
2023-06-07 09:50:13,184 INFO MainThread Setting emoncmsorg sendnames: 1
2023-06-07 09:50:13,184 INFO MainThread Setting emoncmsorg compress: 0
2023-06-07 09:50:13,185 DEBUG MainThread Automatic configuration of nodes enabled
EmonHub Config
####################### emonhub.conf #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
autoconf = 1
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[EmonPi2]]
Type = EmonHubOEMInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 38400
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
[[USB0]]
[[[init_settings]]]
com_port = /dev/ttyUSB0
com_baud = 115200
nodename = emonTx4
[[SPI]]
Type = EmonHubRFM69LPLInterfacer
[[[init_settings]]]
nodeid = 5
networkID = 210
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 0
nodevar_format_enable = 1
# Single JSON payload published - use with Emoncms MQTT
node_JSON_enable = 0
node_JSON_basetopic = emon/
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
senddata = 1 # Enable sending data to Emoncms.org
sendnames = 1 # Send full input names (compression will be automatically enabled)
interval = 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
## See config user guide: https://github.com/openenergymonitor/emonhub
## If autoconf is enabled above, node configuration will automatically
## populate based on templates listed in available.conf
[nodes]
[[18]]
nodename = emonTx4_18
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, P5, P6, E1, E2, E3, E4, E5, E6, T1, T2, T3, pulse
datacodes = L, h, h, h, h, h, h, h, l, l, l, l, l, l, h, h, h, L
scales = 1.0, 0.01, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 0.01, 0.01, 0.01, 1.0
units = n, V, W, W, W, W, W, W, Wh, Wh, Wh, Wh, Wh, Wh, C, C, C, p
[[23]]
nodename = emonth2_23
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h, h, h, h, L
scales = 0.1, 0.1, 0.1, 0.1, 1.0
units = C, C, %, V, p
Edits by MOD as it is an emonBase as confirmed by OP.
