Hi all,
is it possible to set an old data value (feed) after data loss as the base for the new accumulation?
Uwe
Hello @uro53 yes if you go to the feed api helper (top-right feeds page) and select insert new data point, then set the new value to the value you need and just leave time as 0, then click ‘Try’ the latest feed value will update.
Thanks for the quick answer
Hello,
the procedure described here was working fine last time. Now I have the same issue but the old values were not inserted.
What goes wrong?
Regards
solved
