Hello @ZdenekRotrekl and welcome! You need to make the feeds that are used by the dashbord public as well. You can do this on the feeds page itself.
Now is ok. I foud it… Thank you your help. Best regards Zdenek
Hello TrystanLea, I need again help. I have probem wiht one graph. Value (feeld) is the some In “Vyroba dnes” ony with paremetr resset in night. This Value I see normaly without login. But in graph no see. In graph is kWh per day and not possible see log off. Some settings grahp is bad??? Thank you Zdenek
https://emoncms.org/dashboard/view?id=60933
Hello @poldom it looks like you are running an old version of emoncms, can you update to the latest? using the updater tool on the admin page?
Hi @TrystanLea , I have done it a few time ago… But I think the update script is not working
This is the log file
Starting update via service-runner-update.sh (v3.0) >
Filesystem Size Used Avail Use% Mounted on
/dev/root 4.1G 2.5G 1.5G 64% /
devtmpfs 431M 0 431M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 6.2M 457M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
tmpfs 1.0M 4.0K 1020K 1% /var/lib/php/sessions
tmpfs 30M 0 30M 0% /tmp
tmpfs 1.0M 0 1.0M 0% /var/tmp
/dev/mmcblk0p3 9.9G 9.4G 0 100% /var/opt/emoncms
/dev/mmcblk0p1 253M 54M 199M 22% /boot
log2ram 50M 4.5M 46M 9% /var/log
- emonSD version: emonSD-24Jul20
- supported images: emonSD-21Jul21 emonSD-08May21 emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19
- emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: defaults/emoncms/default.settings.php
no changes added to commit (use "git add" and/or "git commit -a")
Already up to date.
Main Update Script
Date: Wed 22 Sep 14:45:56 CEST 2021
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: emoncms
serial_port: ttyAMA0
firmware: none
Reading package lists...
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 144 not upgraded.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: redis in /home/pi/.local/lib/python3.7/site-packages (3.5.3)
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
Start emoncms update:
Update Emoncms Core
Updating /var/www/emoncms
- current branch: stable
WARNING local changes in /var/www/emoncms - Module not updated
- git status: On branch stable
Your branch is behind 'origin/stable' by 35 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
modified: Lib/process_old_settings.php
modified: default-settings.php
modified: default.emonpi.settings.php
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app
- local changes: no
- git fetch: Fetching origin
Already on 'stable'
- git checkout: Your branch is up to date with 'origin/stable'.
- git pull: Already up to date.
- database update: no changes
- component updated
Updating /var/www/emoncms/Modules/config
- local changes: no
Already on 'stable'
- component updated
Updating /var/www/emoncms/Modules/dashboard
- local changes: no
Already on 'stable'
- component updated
Updating /var/www/emoncms/Modules/device
- local changes: no
Already on 'stable'
- component updated
Updating /var/www/emoncms/Modules/graph
- local changes: no
Already on 'stable'
- component updated
Updating /var/www/emoncms/Modules/setup
- local changes: no
Already on 'stable'
- component updated
Updating /var/www/emoncms/Modules/wifi
- local changes: no
Already on 'stable'
- component updated
Updating /opt/emoncms/modules/backup
- local changes: no
Already on 'stable'
- running module install/update script
- config.cfg already exists, left unmodified
- creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- restarting apache
- component updated
Updating /opt/emoncms/modules/demandshaper
- local changes: no
Already on 'stable'
- reinstalling demandshaper.service
- demandshaper service: ActiveState=active
- component updated
Updating /opt/emoncms/modules/postprocess
- local changes: no
Already on 'stable'
- component updated
Updating /opt/emoncms/modules/sync
- local changes: no
Already on 'stable'
- component updated
Updating /opt/emoncms/modules/usefulscripts
- local changes: no
Already on 'stable'
- component updated
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Starting emonPi LCD service..
System update done: Wed 22 Sep 14:46:38 CEST 2021
restarting service-runner
Thanks @poldom it looks like you have made local changes to the EmonScripts and emoncms repositories. The following commands will clear those changes, these need to be entered via ssh terminal:
cd /opt/openenergymonitor/EmonScripts
git checkout .
cd /var/www/emoncms
git checkout .
Then try running the update via the admin page again
It worked, thanks!
Something of a surprise that this:
wasn’t noticed. (partition is full, no space left on device)
Although it might not have anything to do with the issue at hand, it will cause a problem as soon
as an attempt to write to that partition occurs.
