Hi all,
I have installed the cms locally on a PI3. I try to log energy, oil heater and water consumption.
All sensor are working fine. My problem is to sum up the results on every feed. I added the inp+
process with the same arg. My expectation was an increasing output value but nothing happend.
How to realize?
Best regards
Uwe
type or paste code here
Thank You for the fast response. It works but it is postprocessing. Is there the possibility to add
in realtime? Can I speed up the processing?
What means the time value in the right raw?
Thanks in advance
Uwe
