Dr_W
(Charles Whitfield)
1
hi brian,
I haven’t really used HA since setting it up a while ago. From memory, i managed to find an Emon integration (maybe on Github? - - can’t remember) and get it to run in HA. However, i just logged into my HA GUI and found that the data coming from emonCMS is absent and there no longer an integration listed.
Sorry, I’m not much help there!
I’d really like to get HA set up properly again, so will have to find some time to sort it all out. I also want to link it to our heating system but i couldn’t find a Heatmiser integration for HA.
borpin
(Brian Orpin)
2
I moved this to a new topic.
You will need to expand on your setup and the HW you have.
Do you mean Run in HA or simply get the data into HA?
Do you have a Pi running emoncms?
Dr_W
(Charles Whitfield)
3
hi brian,
I’ve got an EmonPi and EmonTX running for a couple of years.
I’ve setup Home Assistant running in Docker, and have managed to get the emoncms integration kind of working using this guide:
There are a few issues though. I can see the feeds listed as ‘entities’ in HA but the big problem is that the feed data isn’t coming into HA. If i reboot HA the data from the emonCMS feeds gets refreshed, but once HA is running no new data comes in. Other integrations seem to working ok, e.g. data from solarEdge.
You can see in this graph of my emonCMS ‘use’ feed that the data is only refreshed when i’ve rebooted HA
borpin
(Brian Orpin)
4
If you click reply to the previous message or Quote me, I’ll get a notification, else your response might get lost.
That (IME) is never a good idea. I used to do this, but decided investing in the same HW the Devs seemed to use was the path of least resistance. So many issues on the forum are from folk running in an ‘unsupported way’.
I’ve no idea why it isn’t pulling in the data.
Is HA up to date?
Dr_W
(Charles Whitfield)
5
HA is up to date (latest version downloaded on Sunday). For now i’d rather continue to get it to work in Docker rather than set up another device to run HA.
I had a “doh” moment this morning and realised that i may be using the wrong feeds. I should be using the cumulative kwh data feeds rather than continuous kw data feeds! I’m not at home at the moment so can’t check. Will do that tonight.
borpin
(Brian Orpin)
6
Yes, and you may be OK. For me it got too tiresome (that was over 2 years ago). Possibly improved now.
Dr_W
(Charles Whitfield)
7
It isn’t anything to do with which feed i use. None of the feeds from emonCMS are being updated by HA. It just refreshes the data value when HA is rebooted, then the feed value doesn’t change.
I had it working on a previous setup using Docker, so it must be possible.
borpin
(Brian Orpin)
8
I wouldn’t bet on that as HA changes with alarming regularity. They have done something recently about polling intervals, but my system still works. I don’t really know what might be wrong. Anything in the logs?
Dr_W
(Charles Whitfield)
9
hi brian,
most recent log
Is the problem something to do with missing values in the feeds? I recall reading somewhere that having missing values in feeds will cause problems for HA, but i thought that was fixed in most recent version. I have HA version 2023.3.5.
There’s also the error about negative values, which is from the solar energy export feed.
I tried editing the configuration.yaml file to include only specific feeds, hoping that might stop the issue, but i’m not sure what the feed numbers are or where to find them in emonCMS. I guessed some feed numbers to see what happened. But after restarting HA nothing changed.
EDIT - I found the feed numbers in Data Viewer - Feeds in View stats table.
Dr_W
(Charles Whitfield)
10
I’ve now set the config yaml to only include specific feeds, and the errors in the logs have stopped appearing on restarting HA. Looks like data is now coming in from emonCMS.
Also if you hover your mouse over the name of the feed on the Feeds page of emonCMS.
