please can someone help I get the following error when I run the install script on ubuntu 20 system
Install Emoncms Core Modules
/opt/openenergymonitor/EmonScripts/install/emoncms_modules.sh: line 8: cd: /var/www/emoncms/Modules: No such file or directory
- Module dashboard already exists
- Module device already exists
- Module app already exists
- Module graph already exists
- Module postprocess already exists
- Module demandshaper already exists
- Module backup already exists
- Module sync already exists
- Module usefulscripts already exists
Update Emoncms database
PHP Warning: chdir(): No such file or directory (errno 2) in /opt/openenergymonitor/EmonScripts/common/emoncmsdbupdate.php on line 8
PHP Warning: require(process_settings.php): failed to open stream: No such file or directory in /opt/openenergymonitor/EmonScripts/common/emoncmsdbupdate.php on line 9
PHP Fatal error: require(): Failed opening required 'process_settings.php' (include_path='.:/usr/share/php') in /opt/openenergymonitor/EmonScripts/common/emoncmsdbupdate.php on line 9
