Hello,
With much patient help from @icenov, I have been able to setup LoRa data coming from an RAK7244 server which seems to be receiving and updating data (every 20 minutes) on my emonpi (two LHT65 temp/hum sensors). The inputs and show the latest data. (MQTT setup via Node-Red)
However, when I attempt to graph any of the data points, the only graphs I can get are in the 1-hour viewing slot. Other slots (6-hour, 12-hour, 1 week, etc.) are blank even though this has been running over 24 hours. The 1-hour slot is always current and correct.
The other devices (emonTX, emonTH, weewx weather station) sending to the emonpi show the correct graphs in all time slots and are running correctly.
I have something which is not configured correctly but am unable to understand what is causing this problem. If someone could help then I can send more information as needed. Below is some information on my setup. Many thanks in advance.
Bob
House power monitoring system (USA) with the following:
RPI 4 loaded with flashed OEM software on 64 GB SD (latest updates)
emonTXV3 + AC/AC power, RFM69Pi_433 (purchased July 2017)
2 x SCT023R (200A:50MA) on 220 mains (North America 2 x 110)
emonTH V2 (purchased Oct 2017)
weewx weather station (VP2) on Node 0
RAK7244 LoRa server/MQTT with data from two LHT65 sensors
All units on same LAN
<details><summary>Server Information</summary>
# Server Information
## Services
- **emonhub** :- **Active** Running
- **emoncms_mqtt** :- **Active** Running
- **feedwriter** :- **Active** Running - sleep 300s 256 feed points pending write
- **service-runner** :- **Active** Running
- **emonPiLCD** :- **Failed** Failed
- **redis-server** :- **Active** Running
- **mosquitto** :- **Active** Running
- **demandshaper** :- **Active** Running
## Emoncms
- **Version** :- low-write 10.8.5
- **Git** :-
- **URL** :- https://github.com/emoncms/emoncms.git
- **Branch** :- * stable
- **Describe** :- 10.8.5
- **Components** :- Emoncms Core v10.8.5 | App v2.3.4 | EmonHub Config v2.1.1 | Dashboard v2.1.5 | Device v2.1.3 | Graph v2.1.1 | Network Setup v1.0.2 | WiFi v2.1.0 | Backup v2.3.2 | DemandShaper v2.2.2 | Postprocess v2.2.2 | Sync v2.1.1 | Usefulscripts v2.3.7 | EmonScripts v1.3.9 | RFM2Pi v1.4.1 | Avrdude-rpi v1.0.0 | Emonhub v2.3.1 | EmonPi v2.9.4
## Server
- **OS** :- Linux 5.10.17-v7l+
- **Host** :- emonpi | emonpi | (192.168.1.173)
- **Date** :- 2021-10-02 15:38:05 EDT
- **Uptime** :- 15:38:05 up 5:23, 0 users, load average: 0.13, 0.08, 0.02
## Memory
- **RAM** :- Used: 2.89%
- **Total** :- 7.69 GB
- **Used** :- 227.75 MB
- **Free** :- 7.47 GB
- **Swap** :- Used: 0.00%
- **Total** :- 100 MB
- **Used** :- 0 B
- **Free** :- 100 MB
Write Load Period
## Disk
- **/** :- Used: 55.12%
- **Total** :- 4.07 GB
- **Used** :- 2.24 GB
- **Free** :- 1.63 GB
- **Write Load** :- n/a
- **/boot** :- Used: 18.90%
- **Total** :- 252.05 MB
- **Used** :- 47.65 MB
- **Free** :- 204.4 MB
- **/var/opt/emoncms** :- Used: 2.01%
- **Total** :- 54.13 GB
- **Used** :- 1.09 GB
- **Free** :- 50.29 GB
- **/var/log** :- Used: 5.95%
- **Total** :- 50 MB
- **Used** :- 2.98 MB
- **Free** :- 47.02 MB
## HTTP
- **Server** :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
## MySQL
- **Version** :- 5.5.5-10.3.29-MariaDB-0+deb10u1
- **Host** :- 127.0.0.1 (127.0.0.1)
- **Date** :- 2021-10-02 15:38:05 (UTC -04:00)
- **Stats** :- Uptime: 19426 Threads: 13 Questions: 2540 Slow queries: 0 Opens: 47 Flush tables: 1 Open tables: 40 Queries per second avg: 0.130
## Redis
- **Version** :-
- **Redis Server** :- 5.0.3
- **PHP Redis** :- 5.3.4
- **Host** :- localhost:6379
- **Size** :- 426 keys (771.54K)
- **Uptime** :- 0 days
## MQTT Server
- **Version** :- Mosquitto 1.5.7
- **Host** :- localhost:1883 (127.0.0.1)
## PHP
- **Version** :- 7.3.29-1~deb10u1 (Zend Version 3.3.29)
- **Modules** :- apache2handlercalendar Core ctype curl date dom v20031129exif fileinfo filter ftp gd gettext hash iconv json v1.7.0libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $openssl pcre PDO pdo_mysql Phar posix readline redis v5.3.4Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zlib
## Pi
- **Model** :- Raspberry Pi Model N/A Rev - ()
- **Serial num.** :- 10000000E91C8CAC
- **CPU Temperature** :- 57.45°C
- **GPU Temperature** :- 56.9°C
- **emonpiRelease** :- emonSD-21Jul21
- **File-system** :- read-write
</details>
<details><summary>Client Information</summary>
