Emoncms home assistant integration : usage with automation - examples of use cases?
hi,
An HA developper asks for some use cases on how to use emoncms integration with automation.
The goal is to improve the doc in order to give people an example idea of what they can do with this integration. What would someone use this for? How do you use it in automations?
Could you some of you illustrate their usage ? or do you only use the integration for the energy dashboard ? which was last year reported as the main reason for the update : cf EmonCMS Integration · Open-Building-Management/emoncms · Discussion #23 · GitHub
best
Alex
You wouldn’t directly, but you might trigger an automation based on a sensor value. So when Temp x is > y then…
It is producing sensor state data so the answer is anything you can do with any other (numeric) state sensor.
