Paul, as luck would have it, another hang occurred as a I was replying to you earlier. So i took the opportunity to timestamp when I initiated the reboot. This was a t 17:47. Here is the log which appears to indicate that the system went to sleep at 17:18. See bottom of file
2018-03-21 17:17:25,732 INFO MainThread EmonHub emonHub emon-pi variant v2.1.1
2018-03-21 17:17:25,734 INFO MainThread Opening hub...
2018-03-21 17:17:25,736 INFO MainThread Logging level set to DEBUG
2018-03-21 17:17:25,738 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2018-03-21 17:17:25,744 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2018-03-21 17:17:27,759 INFO MainThread RFM2Pi device firmware version: OK
2018-03-21 17:17:27,760 INFO MainThread RFM2Pi device current settings: 5 0 0 0 0 0 0 0 0 70 2 48 2 208 2 86 1 101 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:27,761 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2018-03-21 17:17:28,763 INFO MainThread Setting RFM2Pi group: 210 (210g)
2018-03-21 17:17:29,766 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2018-03-21 17:17:30,769 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2018-03-21 17:17:31,772 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2018-03-21 17:17:32,775 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2018-03-21 17:17:32,777 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2018-03-21 17:17:32,779 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2018-03-21 17:17:32,786 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2018-03-21 17:17:32,787 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2018-03-21 17:17:32,789 INFO MainThread Setting MQTT nodevar_format_enable: 1
2018-03-21 17:17:32,790 INFO MainThread Setting MQTT node_format_enable: 1
2018-03-21 17:17:32,791 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2018-03-21 17:17:32,797 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2018-03-21 17:17:32,799 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2018-03-21 17:17:32,801 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2018-03-21 17:17:32,802 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2018-03-21 17:17:32,803 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2018-03-21 17:17:32,805 INFO MainThread Setting emoncmsorg senddata: 1
2018-03-21 17:17:32,806 WARNING MainThread Setting emoncmsorg apikey: obscured
2018-03-21 17:17:32,807 INFO MainThread Setting emoncmsorg sendstatus: 1
2018-03-21 17:17:32,905 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2018-03-21 17:17:33,012 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q0 USA 0
2018-03-21 17:17:33,128 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 32 192 0 34 131 3 24 16 128 49 32 62 68 32 40 231 216 146 228 1 (-97)
2018-03-21 17:17:33,234 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q0 USA 0
2018-03-21 17:17:33,347 DEBUG RFM2Pi 1 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 70 2 47 2 206 2 86 1 100 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:33,354 DEBUG RFM2Pi 1 Timestamp : 1521652653.35
2018-03-21 17:17:33,356 DEBUG RFM2Pi 1 From Node : 5
2018-03-21 17:17:33,357 DEBUG RFM2Pi 1 Values : [0, 0, 0, 0, 58.2, 55.900000000000006, 71.8, 34.2, 35.6, 0, 1]
2018-03-21 17:17:33,359 DEBUG RFM2Pi 1 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:17:33,361 DEBUG RFM2Pi 1 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:17:33,473 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 23 129 6 225 192 1 0 1 4 192 32 96 0 32 0 0 9 17 145 240 68 (-101)
2018-03-21 17:17:33,528 INFO MQTT Connecting to MQTT Server
2018-03-21 17:17:33,534 INFO MQTT Could not connect...
2018-03-21 17:17:33,579 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q0 USA 0
2018-03-21 17:17:33,621 DEBUG emoncmsorg Buffer size: 1
2018-03-21 17:17:33,689 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 4 4 160 3 4 161 1 60 132 192 0 0 36 0 2 64 38 64 28 66 (-98)
2018-03-21 17:17:33,800 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 7 220 2 112 190 12 3 40 192 0 52 188 40 80 60 8 78 160 9 88 100 (-93)
2018-03-21 17:17:34,348 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 1 129 3 0 160 89 168 226 2 119 161 32 4 141 164 10 64 98 0 204 130 (-97)
2018-03-21 17:17:36,133 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 9 108 0 148 227 133 196 226 2 119 161 32 4 141 164 10 64 98 0 204 130 (-98)
2018-03-21 17:17:37,149 DEBUG RFM2Pi 2 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 70 2 47 2 204 2 86 1 100 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:37,153 DEBUG RFM2Pi 2 Timestamp : 1521652657.15
2018-03-21 17:17:37,154 DEBUG RFM2Pi 2 From Node : 5
2018-03-21 17:17:37,157 DEBUG RFM2Pi 2 Values : [0, 0, 0, 0, 58.2, 55.900000000000006, 71.60000000000001, 34.2, 35.6, 0, 1]
2018-03-21 17:17:37,159 DEBUG RFM2Pi 2 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:17:37,160 DEBUG RFM2Pi 2 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:17:37,267 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 15 144 66 38 89 68 5 39 106 2 50 143 128 42 49 34 176 117 0 155 169 (-94)
2018-03-21 17:17:37,358 INFO MQTT Connecting to MQTT Server
2018-03-21 17:17:37,361 INFO MQTT Could not connect...
2018-03-21 17:17:39,861 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 66 34 38 32 159 189 50 171 227 194 76 232 160 120 183 152 65 38 0 200 (-97)
2018-03-21 17:17:42,178 DEBUG RFM2Pi 3 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 202 2 85 1 100 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:42,183 DEBUG RFM2Pi 3 Timestamp : 1521652662.18
2018-03-21 17:17:42,184 DEBUG RFM2Pi 3 From Node : 5
2018-03-21 17:17:42,185 DEBUG RFM2Pi 3 Values : [0, 0, 0, 0, 58.300000000000004, 56, 71.4, 34.1, 35.6, 0, 1]
2018-03-21 17:17:42,187 DEBUG RFM2Pi 3 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:17:42,188 DEBUG RFM2Pi 3 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:17:42,300 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 2 1 168 70 40 169 248 39 195 17 137 73 148 21 129 0 25 2 120 27 208 (-96)
2018-03-21 17:17:42,408 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 9 33 80 152 64 32 138 65 100 51 212 62 136 5 128 81 36 35 16 35 224 (-94)
2018-03-21 17:17:42,411 INFO MQTT Connecting to MQTT Server
2018-03-21 17:17:42,413 INFO MQTT Could not connect...
2018-03-21 17:17:43,222 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 19 145 129 35 195 96 162 189 20 17 143 64 160 1 39 56 192 11 1 1 146 (-93)
2018-03-21 17:17:44,338 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 11 112 57 133 242 26 171 80 128 15 178 32 9 225 241 36 23 73 131 115 66 (-95)
2018-03-21 17:17:45,050 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 8 15 200 149 13 64 108 50 18 3 36 162 128 189 185 136 99 4 66 148 113 (-98)
2018-03-21 17:17:47,109 DEBUG RFM2Pi 4 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 47 2 200 2 85 1 100 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:47,113 DEBUG RFM2Pi 4 Timestamp : 1521652667.11
2018-03-21 17:17:47,114 DEBUG RFM2Pi 4 From Node : 5
2018-03-21 17:17:47,116 DEBUG RFM2Pi 4 Values : [0, 0, 0, 0, 58.300000000000004, 55.900000000000006, 71.2, 34.1, 35.6, 0, 1]
2018-03-21 17:17:47,117 DEBUG RFM2Pi 4 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:17:47,118 DEBUG RFM2Pi 4 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:17:47,227 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 19 64 8 132 92 226 164 38 9 161 0 34 140 129 36 52 162 0 26 59 229 (-98)
2018-03-21 17:17:47,261 INFO MQTT Connecting to MQTT Server
2018-03-21 17:17:47,365 INFO MQTT connection status: Connection successful
2018-03-21 17:17:47,367 DEBUG MQTT CONACK => Return code: 0
2018-03-21 17:17:47,469 INFO MQTT on_subscribe
2018-03-21 17:17:47,676 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 10 224 142 9 64 24 208 24 104 25 122 16 192 0 0 96 13 232 58 3 160 (-96)
2018-03-21 17:17:49,004 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 46 60 40 18 176 73 176 2 8 6 37 109 36 29 33 32 40 32 23 1 (-97)
2018-03-21 17:17:52,151 DEBUG RFM2Pi 5 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 198 2 85 1 100 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:52,156 DEBUG RFM2Pi 5 Timestamp : 1521652672.15
2018-03-21 17:17:52,157 DEBUG RFM2Pi 5 From Node : 5
2018-03-21 17:17:52,159 DEBUG RFM2Pi 5 Values : [0, 0, 0, 0, 58.300000000000004, 56, 71, 34.1, 35.6, 0, 1]
2018-03-21 17:17:52,160 DEBUG RFM2Pi 5 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:17:52,162 DEBUG RFM2Pi 5 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:17:52,316 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:17:52,319 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:17:52,322 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:17:52,324 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:17:52,327 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:17:52,330 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:17:52,332 DEBUG MQTT Publishing: emon/emonpi/t3 71
2018-03-21 17:17:52,335 DEBUG MQTT Publishing: emon/emonpi/t4 34.1
2018-03-21 17:17:52,337 DEBUG MQTT Publishing: emon/emonpi/t5 35.6
2018-03-21 17:17:52,340 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:17:52,342 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:17:52,345 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,71,34.1,35.6,0,1
2018-03-21 17:17:53,180 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 3 4 96 9 39 0 153 33 157 114 21 0 32 0 36 16 161 37 56 34 182 (-95)
2018-03-21 17:17:53,993 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 11 0 128 0 32 1 25 120 18 10 130 53 0 160 0 42 116 160 16 48 129 (-98)
2018-03-21 17:17:55,207 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 22 49 16 12 64 1 25 120 18 10 130 53 0 160 0 42 116 160 16 48 129 (-102)
2018-03-21 17:17:57,123 DEBUG RFM2Pi 6 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 195 2 85 1 100 1 0 0 1 0 0 0 (-0)
2018-03-21 17:17:57,126 DEBUG RFM2Pi 6 Timestamp : 1521652677.12
2018-03-21 17:17:57,127 DEBUG RFM2Pi 6 From Node : 5
2018-03-21 17:17:57,129 DEBUG RFM2Pi 6 Values : [0, 0, 0, 0, 58.300000000000004, 56, 70.7, 34.1, 35.6, 0, 1]
2018-03-21 17:17:57,130 DEBUG RFM2Pi 6 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:17:57,131 DEBUG RFM2Pi 6 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:17:57,408 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:17:57,411 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:17:57,413 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:17:57,415 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:17:57,418 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:17:57,420 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:17:57,422 DEBUG MQTT Publishing: emon/emonpi/t3 70.7
2018-03-21 17:17:57,424 DEBUG MQTT Publishing: emon/emonpi/t4 34.1
2018-03-21 17:17:57,426 DEBUG MQTT Publishing: emon/emonpi/t5 35.6
2018-03-21 17:17:57,428 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:17:57,430 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:17:57,432 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,70.7,34.1,35.6,0,1
2018-03-21 17:17:57,654 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 18 217 132 99 185 135 0 192 27 192 69 160 23 43 32 250 201 112 122 146 1 (-93)
2018-03-21 17:17:58,064 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 21 18 192 8 39 32 121 96 151 69 48 160 23 43 32 250 201 112 122 146 1 (-95)
2018-03-21 17:17:58,172 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 4 100 185 108 153 38 2 60 82 68 58 176 108 96 139 35 38 226 26 126 17 (-93)
2018-03-21 17:17:58,482 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 5 168 101 60 42 97 69 168 29 224 8 172 34 120 0 144 1 31 26 126 17 (-96)
2018-03-21 17:18:02,170 DEBUG RFM2Pi 7 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 193 2 85 1 99 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:02,173 DEBUG RFM2Pi 7 Timestamp : 1521652682.17
2018-03-21 17:18:02,175 DEBUG RFM2Pi 7 From Node : 5
2018-03-21 17:18:02,176 DEBUG RFM2Pi 7 Values : [0, 0, 0, 0, 58.300000000000004, 56, 70.5, 34.1, 35.5, 0, 1]
2018-03-21 17:18:02,176 DEBUG RFM2Pi 7 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:02,177 DEBUG RFM2Pi 7 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:02,302 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:02,306 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:02,309 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:02,312 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:02,316 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:18:02,319 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:02,322 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 171 0 16 2 67 32 0 24 46 16 0 39 32 8 38 184 48 131 225 112 (-99)
2018-03-21 17:18:02,324 DEBUG MQTT Publishing: emon/emonpi/t3 70.5
2018-03-21 17:18:02,328 DEBUG MQTT Publishing: emon/emonpi/t4 34.1
2018-03-21 17:18:02,330 DEBUG MQTT Publishing: emon/emonpi/t5 35.5
2018-03-21 17:18:02,333 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:02,336 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:02,341 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,70.5,34.1,35.5,0,1
2018-03-21 17:18:03,339 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 18 146 192 9 37 192 1 94 60 33 223 163 65 36 64 37 2 174 132 46 40 (-101)
2018-03-21 17:18:03,636 DEBUG emoncmsorg Buffer size: 6
2018-03-21 17:18:04,049 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 19 118 188 102 0 1 145 195 132 7 74 58 32 100 33 0 55 117 32 10 17 (-98)
2018-03-21 17:18:05,921 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 1 163 168 212 18 41 141 6 0 0 187 128 5 33 2 224 80 40 2 43 55 (-98)
2018-03-21 17:18:07,156 DEBUG RFM2Pi 8 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 191 2 84 1 99 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:07,159 DEBUG RFM2Pi 8 Timestamp : 1521652687.16
2018-03-21 17:18:07,160 DEBUG RFM2Pi 8 From Node : 5
2018-03-21 17:18:07,161 DEBUG RFM2Pi 8 Values : [0, 0, 0, 0, 58.300000000000004, 56, 70.3, 34, 35.5, 0, 1]
2018-03-21 17:18:07,162 DEBUG RFM2Pi 8 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:07,162 DEBUG RFM2Pi 8 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:07,251 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:07,253 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:07,254 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:07,256 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:07,258 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:18:07,260 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:07,262 DEBUG MQTT Publishing: emon/emonpi/t3 70.3
2018-03-21 17:18:07,265 DEBUG MQTT Publishing: emon/emonpi/t4 34
2018-03-21 17:18:07,267 DEBUG MQTT Publishing: emon/emonpi/t5 35.5
2018-03-21 17:18:07,269 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:07,271 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:07,273 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,70.3,34,35.5,0,1
2018-03-21 17:18:09,794 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 24 208 9 97 145 193 205 162 56 181 33 0 114 214 231 174 87 160 210 40 223 (-97)
2018-03-21 17:18:10,937 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 236 86 4 43 107 235 139 50 49 41 28 99 214 231 174 87 160 210 40 223 (-97)
2018-03-21 17:18:12,173 DEBUG RFM2Pi 9 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 189 2 84 1 99 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:12,177 DEBUG RFM2Pi 9 Timestamp : 1521652692.17
2018-03-21 17:18:12,178 DEBUG RFM2Pi 9 From Node : 5
2018-03-21 17:18:12,178 DEBUG RFM2Pi 9 Values : [0, 0, 0, 0, 58.300000000000004, 56, 70.10000000000001, 34, 35.5, 0, 1]
2018-03-21 17:18:12,179 DEBUG RFM2Pi 9 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:12,180 DEBUG RFM2Pi 9 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:12,269 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:12,271 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:12,274 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:12,276 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:12,278 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:18:12,279 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:12,282 DEBUG MQTT Publishing: emon/emonpi/t3 70.1
2018-03-21 17:18:12,285 DEBUG MQTT Publishing: emon/emonpi/t4 34
2018-03-21 17:18:12,289 DEBUG MQTT Publishing: emon/emonpi/t5 35.5
2018-03-21 17:18:12,292 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:12,295 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:12,298 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,70.1,34,35.5,0,1
2018-03-21 17:18:12,302 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 26 81 131 160 65 32 2 225 1 160 96 52 48 1 71 5 9 220 132 160 162 (-96)
2018-03-21 17:18:13,844 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 0 160 65 32 2 225 1 160 96 52 48 1 71 5 9 220 132 160 162 (-103)
2018-03-21 17:18:14,861 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 160 160 65 32 2 225 1 160 96 52 48 1 71 5 9 220 132 160 162 (-104)
2018-03-21 17:18:17,178 DEBUG RFM2Pi 10 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 186 2 84 1 99 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:17,182 DEBUG RFM2Pi 10 Timestamp : 1521652697.18
2018-03-21 17:18:17,183 DEBUG RFM2Pi 10 From Node : 5
2018-03-21 17:18:17,184 DEBUG RFM2Pi 10 Values : [0, 0, 0, 0, 58.300000000000004, 56, 69.8, 34, 35.5, 0, 1]
2018-03-21 17:18:17,185 DEBUG RFM2Pi 10 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:17,186 DEBUG RFM2Pi 10 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:17,269 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:17,271 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:17,273 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:17,275 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:17,277 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:18:17,278 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:17,280 DEBUG MQTT Publishing: emon/emonpi/t3 69.8
2018-03-21 17:18:17,282 DEBUG MQTT Publishing: emon/emonpi/t4 34
2018-03-21 17:18:17,284 DEBUG MQTT Publishing: emon/emonpi/t5 35.5
2018-03-21 17:18:17,286 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:17,289 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:17,292 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,69.8,34,35.5,0,1
2018-03-21 17:18:17,301 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 32 33 98 32 6 0 128 0 32 0 34 64 0 26 62 65 0 160 162 (-104)
2018-03-21 17:18:17,518 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 2 229 168 16 35 184 140 64 128 80 8 32 0 50 100 13 28 206 64 16 0 (-99)
2018-03-21 17:18:19,237 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 120 162 8 40 32 140 64 128 80 8 32 0 50 100 13 28 206 64 16 0 (-95)
2018-03-21 17:18:20,651 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 17 0 0 8 40 32 140 64 128 80 8 32 0 50 100 13 28 206 64 16 0 (-102)
2018-03-21 17:18:22,166 DEBUG RFM2Pi 11 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 184 2 84 1 98 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:22,169 DEBUG RFM2Pi 11 Timestamp : 1521652702.17
2018-03-21 17:18:22,170 DEBUG RFM2Pi 11 From Node : 5
2018-03-21 17:18:22,171 DEBUG RFM2Pi 11 Values : [0, 0, 0, 0, 58.300000000000004, 56, 69.60000000000001, 34, 35.4, 0, 1]
2018-03-21 17:18:22,171 DEBUG RFM2Pi 11 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:22,172 DEBUG RFM2Pi 11 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:22,273 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:22,275 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:22,277 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:22,279 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:22,281 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:18:22,283 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:22,285 DEBUG MQTT Publishing: emon/emonpi/t3 69.6
2018-03-21 17:18:22,287 DEBUG MQTT Publishing: emon/emonpi/t4 34
2018-03-21 17:18:22,289 DEBUG MQTT Publishing: emon/emonpi/t5 35.4
2018-03-21 17:18:22,291 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:22,293 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:22,295 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,69.6,34,35.4,0,1
2018-03-21 17:18:23,494 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 0 0 0 32 140 64 128 80 8 32 0 50 100 13 28 206 64 16 0 (-102)
2018-03-21 17:18:25,210 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 48 0 132 32 48 0 0 6 172 0 0 8 0 49 160 16 192 2 192 (-101)
2018-03-21 17:18:27,128 DEBUG RFM2Pi 12 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 71 2 48 2 182 2 84 1 98 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:27,132 DEBUG RFM2Pi 12 Timestamp : 1521652707.13
2018-03-21 17:18:27,133 DEBUG RFM2Pi 12 From Node : 5
2018-03-21 17:18:27,134 DEBUG RFM2Pi 12 Values : [0, 0, 0, 0, 58.300000000000004, 56, 69.4, 34, 35.4, 0, 1]
2018-03-21 17:18:27,135 DEBUG RFM2Pi 12 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:27,136 DEBUG RFM2Pi 12 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:27,322 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:27,325 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:27,327 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:27,329 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:27,331 DEBUG MQTT Publishing: emon/emonpi/t1 58.3
2018-03-21 17:18:27,332 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:27,334 DEBUG MQTT Publishing: emon/emonpi/t3 69.4
2018-03-21 17:18:27,336 DEBUG MQTT Publishing: emon/emonpi/t4 34
2018-03-21 17:18:27,338 DEBUG MQTT Publishing: emon/emonpi/t5 35.4
2018-03-21 17:18:27,340 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:27,341 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:27,343 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.3,56,69.4,34,35.4,0,1
2018-03-21 17:18:28,072 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 72 0 0 40 32 32 32 0 0 0 0 0 0 64 68 164 0 8 (-101)
2018-03-21 17:18:32,164 DEBUG RFM2Pi 13 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 72 2 48 2 180 2 84 1 98 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:32,168 DEBUG RFM2Pi 13 Timestamp : 1521652712.16
2018-03-21 17:18:32,169 DEBUG RFM2Pi 13 From Node : 5
2018-03-21 17:18:32,170 DEBUG RFM2Pi 13 Values : [0, 0, 0, 0, 58.400000000000006, 56, 69.2, 34, 35.4, 0, 1]
2018-03-21 17:18:32,171 DEBUG RFM2Pi 13 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:32,171 DEBUG RFM2Pi 13 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:32,258 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:32,260 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:32,262 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:32,264 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:32,267 DEBUG MQTT Publishing: emon/emonpi/t1 58.4
2018-03-21 17:18:32,269 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:32,270 DEBUG MQTT Publishing: emon/emonpi/t3 69.2
2018-03-21 17:18:32,272 DEBUG MQTT Publishing: emon/emonpi/t4 34
2018-03-21 17:18:32,276 DEBUG MQTT Publishing: emon/emonpi/t5 35.4
2018-03-21 17:18:32,280 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:32,284 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:32,287 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 32 72 0 0 40 32 32 32 0 0 0 0 0 0 64 68 164 0 8 (-104)
2018-03-21 17:18:32,289 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.4,56,69.2,34,35.4,0,1
2018-03-21 17:18:32,602 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 32 72 0 0 40 32 32 32 0 0 0 0 0 0 64 68 164 0 8 (-103)
2018-03-21 17:18:33,214 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 8 32 18 33 64 16 32 16 38 32 36 19 128 6 38 192 0 16 0 32 (-104)
2018-03-21 17:18:33,718 DEBUG emoncmsorg Buffer size: 6
2018-03-21 17:18:37,141 DEBUG RFM2Pi 14 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 72 2 48 2 178 2 83 1 97 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:37,145 DEBUG RFM2Pi 14 Timestamp : 1521652717.14
2018-03-21 17:18:37,146 DEBUG RFM2Pi 14 From Node : 5
2018-03-21 17:18:37,147 DEBUG RFM2Pi 14 Values : [0, 0, 0, 0, 58.400000000000006, 56, 69, 33.9, 35.300000000000004, 0, 1]
2018-03-21 17:18:37,147 DEBUG RFM2Pi 14 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:37,148 DEBUG RFM2Pi 14 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:37,341 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:37,343 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:37,345 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:37,347 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:37,349 DEBUG MQTT Publishing: emon/emonpi/t1 58.4
2018-03-21 17:18:37,351 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:37,353 DEBUG MQTT Publishing: emon/emonpi/t3 69
2018-03-21 17:18:37,356 DEBUG MQTT Publishing: emon/emonpi/t4 33.9
2018-03-21 17:18:37,358 DEBUG MQTT Publishing: emon/emonpi/t5 35.3
2018-03-21 17:18:37,360 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:37,362 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:37,364 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.4,56,69,33.9,35.3,0,1
2018-03-21 17:18:38,266 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 5 32 0 22 165 0 47 194 25 0 32 0 37 8 1 0 42 192 1 128 0 (-103)
2018-03-21 17:18:42,116 DEBUG RFM2Pi 15 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 72 2 48 2 176 2 83 1 97 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:42,120 DEBUG RFM2Pi 15 Timestamp : 1521652722.12
2018-03-21 17:18:42,121 DEBUG RFM2Pi 15 From Node : 5
2018-03-21 17:18:42,122 DEBUG RFM2Pi 15 Values : [0, 0, 0, 0, 58.400000000000006, 56, 68.8, 33.9, 35.300000000000004, 0, 1]
2018-03-21 17:18:42,123 DEBUG RFM2Pi 15 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:42,123 DEBUG RFM2Pi 15 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:42,316 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:42,319 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:42,321 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:42,323 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:42,324 DEBUG MQTT Publishing: emon/emonpi/t1 58.4
2018-03-21 17:18:42,327 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:42,330 DEBUG MQTT Publishing: emon/emonpi/t3 68.8
2018-03-21 17:18:42,332 DEBUG MQTT Publishing: emon/emonpi/t4 33.9
2018-03-21 17:18:42,334 DEBUG MQTT Publishing: emon/emonpi/t5 35.3
2018-03-21 17:18:42,336 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:42,338 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:42,340 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.4,56,68.8,33.9,35.3,0,1
2018-03-21 17:18:42,436 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 1 0 29 96 3 0 8 64 32 0 32 0 32 32 16 2 13 200 0 32 (-100)
2018-03-21 17:18:43,345 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 3 48 32 32 48 32 96 0 0 32 1 32 0 16 10 96 128 48 0 32 (-103)
2018-03-21 17:18:46,166 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 2 32 32 32 32 32 0 32 6 0 0 0 32 49 5 168 0 0 32 32 0 (-101)
2018-03-21 17:18:47,178 DEBUG RFM2Pi 16 NEW FRAME : OK 5 0 0 0 0 0 0 0 0 72 2 48 2 174 2 83 1 97 1 0 0 1 0 0 0 (-0)
2018-03-21 17:18:47,182 DEBUG RFM2Pi 16 Timestamp : 1521652727.18
2018-03-21 17:18:47,183 DEBUG RFM2Pi 16 From Node : 5
2018-03-21 17:18:47,183 DEBUG RFM2Pi 16 Values : [0, 0, 0, 0, 58.400000000000006, 56, 68.60000000000001, 33.9, 35.300000000000004, 0, 1]
2018-03-21 17:18:47,184 DEBUG RFM2Pi 16 Sent to channel(start)' : ToEmonCMS
2018-03-21 17:18:47,185 DEBUG RFM2Pi 16 Sent to channel(end)' : ToEmonCMS
2018-03-21 17:18:47,366 DEBUG MQTT Publishing: emon/emonpi/power1 0
2018-03-21 17:18:47,369 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-03-21 17:18:47,371 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 0
2018-03-21 17:18:47,372 DEBUG MQTT Publishing: emon/emonpi/vrms 0
2018-03-21 17:18:47,374 DEBUG MQTT Publishing: emon/emonpi/t1 58.4
2018-03-21 17:18:47,376 DEBUG MQTT Publishing: emon/emonpi/t2 56
2018-03-21 17:18:47,378 DEBUG MQTT Publishing: emon/emonpi/t3 68.6
2018-03-21 17:18:47,380 DEBUG MQTT Publishing: emon/emonpi/t4 33.9
2018-03-21 17:18:47,382 DEBUG MQTT Publishing: emon/emonpi/t5 35.3
2018-03-21 17:18:47,383 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-21 17:18:47,386 DEBUG MQTT Publishing: emon/emonpi/pulsecount 1
2018-03-21 17:18:47,388 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,58.4,56,68.6,33.9,35.3,0,1
2018-03-21 17:18:47,595 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 23 32 5 0 33 128 0 32 4 32 0 0 0 32 64 1 2 46 0 0 36 (-102)
2018-03-21 17:18:48,102 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 32 32 0 32 32 0 0 32 0 0 0 32 0 149 0 0 32 32 32 (-104)
2018-03-21 17:18:48,512 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 40 0 32 0 32 32 0 0 32 0 0 0 32 0 149 0 0 32 32 32 (-102)
2018-03-21 17:49:59,807 DEBUG emoncmsorg Buffer size: 3
