Hello @Fisico, could you try again now?, There has been a slight change in how the graph module looks, it should look like this:
Just the same… when I flag “average” and then click reload (twice), graphs disappear and CSV values go to “null”
Ok found the issue, it was a bug in the feed engine resulting from feeds with a data interval larger than 600s, fixed now - on emoncms.org.
Well done @TrystanLea. Now it works very fluently!!!
Does that mean the local installs weren’t effected or that it’s only currently fixed on emoncms.org?
I needed to double check, yes this was only an error affecting emoncms.org, it was a bug in the background calculation of averages, which is not used on standard emoncms installs as its done on the fly.
