Bonsoir , j’ installer emoncms dans home assistant ,
les information remonte lors du démarrage d’home assistant mais ne se mettent pas a jours apres seulement lors d’un redémarrage
si quelqu un peu m’aider ce serai sympa
merci a tous
Translation
Good evening, I install emoncms in home assistant,
the information goes up when starting home assistant but does not update afterwards only when rebooting
If someone can help me it would be nice
thanks to all
Similar to the previously linked threads, perhaps you need to limit the feeds you are trying to call by setting include_only_feed_id for the feeds you want to create sensors for in HA.
Also might be useful to head to Settings > System Logs > Load Full Logs to see if any errors/problems are reported (not sure what the French transaltion will be for this navigation but hopefully Google translate gets it close enough!)
