Thanks for the latest update of emonCMS. The new tariff selection is handy but could a user set tariff be added ?. I’m currently on Loyal Octopus 16M fixed and would like to compare that to Agile but there’s no option for that
Also updated the home assistant addon.
Dont know if many of you are using, but anyway, I mention it. Most of the update is that you can now update the modules from the admin UI, whereas you could not before
now :
before :
Hi Alex, I don’t use HA just a standalone Docker. Previously I could put in my own tariff value via the config spanner now they are all are ‘fixed’ with their respective tariff values.
I just noticed as well the setup inputs no longer shows the inputs just spinning for ever, feeds etc works ok.
OK, I dont know how the tariff works, I live in France ![]()
which one do you call the agile app ?
costcomparison ?
Hi Alex, I used to live in the northern Dordogne, I guess you’re more familiar with TEMPO etc ![]()
The Agile app I’m referring to is under apps & Octopus Agile used for comparing tariffs. I used to append the tariff with my own values to compare Octopus Agile to a fixed price.
