I got a used EmonTx and RFM69Pi V3 paired with a Raspberry Pi 1 a very long time ago. I have a project I could use this for, so I stuck the RFM69Pi V3 on a Pi3 and installed the latest stable image
I can get to everything, but I can’t seem to get any readings
I followed the Raspberry Pi 3 Compatibility steps, however in “Imputs” I see nothing. Is this where I should be looking?
I don’t have the CT’s on anything, but I do have the temp sensor connected
In the EmonHub log, I see this. Does this mean its connected?
2021-07-05 17:45:30,035 DEBUG RFM2Pi acknowledged command: i - set node ID (standard node ids are 1…30)
2021-07-05 17:45:30,138 DEBUG RFM2Pi acknowledged command: b - set MHz band (4 = 433, 8 = 868, 9 = 915)
2021-07-05 17:45:30,242 DEBUG RFM2Pi acknowledged command: o - change frequency offset within the band (default 1600)
2021-07-05 17:45:30,451 DEBUG RFM2Pi acknowledged command: g - set network group (RFM12 only allows 212, 0 = any)
2021-07-05 17:45:30,554 DEBUG RFM2Pi acknowledged command: c - set collect mode (advanced, normally 0)
2021-07-05 17:45:30,770 DEBUG RFM2Pi acknowledged command: …, a - send data packet to node , request ack
2021-07-05 17:45:30,873 DEBUG RFM2Pi acknowledged command: …, s - send data packet to node , no ack
2021-07-05 17:45:30,976 DEBUG RFM2Pi acknowledged command: q - set quiet mode (1 = don’t report bad packets)
2021-07-05 17:45:31,081 DEBUG RFM2Pi acknowledged command: x - set reporting format (0: decimal, 1: hex, 2: hex+ascii)
2021-07-05 17:45:31,393 DEBUG RFM2Pi acknowledged command: ,,, f - FS20 command (868 MHz)
2021-07-05 17:45:31,498 DEBUG RFM2Pi acknowledged command: ,, k - KAKU command (433 MHz)
2021-07-05 17:45:31,703 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1
