I’ve lost all communications with my 2020 emonbase and wonder whether I have a corrupt SD card. I can see that it’s powered up. I’m not desperate to hang on to the data so if the likelihood is a card fault, I’ll just replace it. Any suggestions?
If it’s on a Raspberry Pi, plug it’s HDMI into a screen plus USB keyboard/mouse and see if it gets anywhere?
I’m no Pi expert, in m y experience the real error is usually either at the beginning or the end of the dump.
I googled 0x00007f00 and you’re not the first to get it, This link pointed to a missing library so maybe you are on the right track with the corrupted SD.
I’d try a new SD card with the up to date build, that will probably work. If it does then you can try using a USB gadget to load the old card and you may be able to import your old data, depending on how corrupt it was. Definitely try this before setting up a load of new input etc.
Thanks for your help; you’re much more of an expert than me. Sounds like a plan. I’ve ordered the card.
Perfect outcome. New SD card works fine and old data imported sccessfully. Many thanks for your help.@christian
