In my EmonTH I use rechargeable batteries - If I wanted to add a small solar panel to recharge them would it be as simple as
connecting the solar panel to the same connections as the batteries?
Would I need an additional diode to prevent the reverse charging (ie powering the solar panel.)?
Any ideas welcome!
My dream become true if we will think about replacement of LTC3525ESC6 and XC6206P with LTC3106. Then it can be easy to do:
- Powering from USB
- Powering from solar panel
- Backup powering from battery
- Charging battery from USB
- Charging battery from solar panel.
See Figure 14 http://cds.linear.com/docs/en/datasheet/3106f.pdf
@glyn.hudson wdyt?
emonTH can be easily powered by a small solar panel the power requirements are very low. You will need a LiPo rechargeable battery and a solar PV charge controller. Either build you own charge controller or buy one ready built from Adafruit e.g.
However, since the emonTH V2 can last for a few years on a couple of AA’s, maybe it’s not worth the extra cost…
Hi Glyn,
I’m using rechargeable batteries - but unlike “normal” batteries they seem to run down far quicker.
I don’t really like using the battery & then bin them - hence the rechargeable ones.
Not really a cost type thing more a waste of a battery type reservation. Given the nature of the emon project
throwing away batteries; given the resources used to make them seems to go against the flow.
I like Sergii’s idea - i have no idea on the cost implications though.
I do look at the little rechargeable garden lights with their solar panel and I can’t see any complexity in them.
just mentioning garden lights use nic/cad battery they have a long charge cycle but need to be completely discharged, to maintain charge time as these battery develop a charge memory. the longest commercial cheap lithium battery would be lifepo battery fully discharge is + 2000 cycle. ( twice that of normal lion) , but if you over size the battery by 100% so it only goes down to +50% of DOD the lifecycle should be is 5000 - 7000 cycles (13- 20 years)
Hi David,
Yes, you’d better to have an additional diode to prevent the reverse charging, or you should have one solar charge controller to connect the mini solar panel.
