Hi, I have the full emon heat monitoring system after my heat pump install in October. I have had no problem at all with the system but after shutting the heat pump down and monitoring system to clean/check the strainer it has come back online and is giving a false reading of 2810 watts when the heat pump is off? I have checked my electricity use with my zappi and Solar inverter and this is a false reading as I was not using anywhere near this amount of electricity. I have reset the emon system and had the heat pump on all night and it is still giving this false reading when in use(see snip below)
Can anyone give any advice guidance as to what I need to do to remedy this, thanks , Chris.
