Hi, today’s email report shows Monday to Sunday with my expected kWh consumption values, but then a second Monday on the end, with -12,331.6kWh. Same figures appear on the email report page on Emoncms.org:
Monday -12,331.6 kWh
You used 105496% less than the previous week
You used 19657% less than UK household average
Recorded figures at my end and on emoncms.org appear normal. I like the idea of generating 1.76 MWh a day (!), but I’m taking a guess that the Emoncms V11 upgrade has caused a glitch - anyone else seeing the same?
EDIT: Just tried my solar generation report and it’s showing an error:
Not enough days returned in data request Notice: Array to string conversion in /var/www/emoncms/index.php on line 522
Array
There’s certainly something not quite right as I also have the same issue.
I saw the anomaly in the email this morning and only just had the time to check the recorded data on both emoncms.org & my local emonpi instance has identical data points with the last day reported incorrectly and with a negative value.
