Edit Emoncms navigation bar
I have a Debian server with ip 192.168.4.2 on which run emoncms and another web app.
I would need to make a change to the navigation bar of emoncms.
I would add an additional link next to Extra pointing to http://192.168.4.2/otherwebapp
The code should be like this :
<li class=" menu-right"><a href="http://192.168.4.2/otherwebapp">
    <div style="display: inline">
    <i class="icon-home icon-white" title="Home"></i>
    <span class="menu-text">Home</span>
</a>
</li>
And this is the result:
How and where do I put the code for this configuration ?
Thank you so much.
A.
I believe in this file menu_view.php here would be the best place:
https://github.com/emoncms/emoncms/blob/master/Theme/basic/menu_view.php
I’ve not tested this
I removed the comment from the code you posted and modified for my needs.
Almost perfect!
Here it is:
// Example how to add a fixed menu item:
    $menu['right'][] = array(
    'name'=>'Home',
    'icon'=>'icon-home icon-white',
    'path'=>"redirect_home.php",
    'session'=>"write",
    'order' => 60,
    'divider' => true);
The only problem is that the default path is already 192.168.4.2/emoncms.
So I added a redirect.php in emoncms folder pointing at 192.168.4.2/home.
For the moment it works fine.
Thanks so much!
A.
