Thanks @borpin ; is there anything in this log file (from the emonSD-30Jul18 instance) that suggests an issue?
Not sure what the “unreliable content” is, or whether it is a problem.
Would a log file from the emonSD-24Jul20 instance be more helpful?
2020-10-03 09:17:40,926 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 33 0 32 4 32 0 16 0 32 0 36 32 0 36 32 0 128 0 (-104)
2020-10-03 09:17:41,065 DEBUG MQTT Publishing: emon/emonpi/power1 27
2020-10-03 09:17:41,067 DEBUG MQTT Publishing: emon/emonpi/power2 9
2020-10-03 09:17:41,069 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 36
2020-10-03 09:17:41,071 DEBUG MQTT Publishing: emon/emonpi/vrms 234.64
2020-10-03 09:17:41,072 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:17:41,074 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:17:41,076 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:17:41,078 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:17:41,080 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:17:41,082 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:17:41,084 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:17:41,086 INFO MQTT Publishing: emonhub/rx/5/values 27,9,36,234.64,16.1,0,0,0,0,0,0
2020-10-03 09:17:41,542 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-104)
2020-10-03 09:17:41,946 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 29 0 0 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-104)
2020-10-03 09:17:45,732 DEBUG RFM2Pi 510 NEW FRAME : OK 5 25 0 8 0 33 0 117 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:17:45,736 DEBUG RFM2Pi 510 Timestamp : 1601716665.73
2020-10-03 09:17:45,736 DEBUG RFM2Pi 510 From Node : 5
2020-10-03 09:17:45,737 DEBUG RFM2Pi 510 Values : [25, 8, 33, 234.13, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:17:45,738 DEBUG RFM2Pi 510 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:17:45,738 DEBUG RFM2Pi 510 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:17:45,830 DEBUG MQTT Publishing: emon/emonpi/power1 25
2020-10-03 09:17:45,832 DEBUG MQTT Publishing: emon/emonpi/power2 8
2020-10-03 09:17:45,834 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 33
2020-10-03 09:17:45,836 DEBUG MQTT Publishing: emon/emonpi/vrms 234.13
2020-10-03 09:17:45,838 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:17:45,840 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:17:45,843 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:17:45,847 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:17:45,851 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 24 40 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-103)
2020-10-03 09:17:45,851 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:17:45,853 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:17:45,855 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:17:45,857 INFO MQTT Publishing: emonhub/rx/5/values 25,8,33,234.13,16.1,0,0,0,0,0,0
2020-10-03 09:17:46,356 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-102)
2020-10-03 09:17:47,863 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 32 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-101)
2020-10-03 09:17:50,792 DEBUG RFM2Pi 511 NEW FRAME : OK 5 24 0 5 0 29 0 107 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:17:50,796 DEBUG RFM2Pi 511 Timestamp : 1601716670.79
2020-10-03 09:17:50,797 DEBUG RFM2Pi 511 From Node : 5
2020-10-03 09:17:50,797 DEBUG RFM2Pi 511 Values : [24, 5, 29, 234.03, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:17:50,798 DEBUG RFM2Pi 511 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:17:50,799 DEBUG RFM2Pi 511 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:17:51,077 DEBUG MQTT Publishing: emon/emonpi/power1 24
2020-10-03 09:17:51,079 DEBUG MQTT Publishing: emon/emonpi/power2 5
2020-10-03 09:17:51,081 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 29
2020-10-03 09:17:51,082 DEBUG MQTT Publishing: emon/emonpi/vrms 234.03
2020-10-03 09:17:51,084 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:17:51,086 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:17:51,088 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:17:51,090 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:17:51,092 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:17:51,094 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:17:51,096 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:17:51,098 INFO MQTT Publishing: emonhub/rx/5/values 24,5,29,234.03,16.1,0,0,0,0,0,0
2020-10-03 09:17:53,141 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 8 36 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-102)
2020-10-03 09:17:53,448 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 1 0 0 0 0 0 0 32 0 8 0 24 5 0 4 0 4 32 0 32 34 (-103)
2020-10-03 09:17:54,401 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 24 0 32 12 40 0 137 55 1 0 16 32 4 36 161 56 64 68 32 8 148 (-99)
2020-10-03 09:17:55,732 DEBUG RFM2Pi 512 NEW FRAME : OK 5 26 0 10 0 36 0 104 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:17:55,736 DEBUG RFM2Pi 512 Timestamp : 1601716675.73
2020-10-03 09:17:55,737 DEBUG RFM2Pi 512 From Node : 5
2020-10-03 09:17:55,738 DEBUG RFM2Pi 512 Values : [26, 10, 36, 234, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:17:55,739 DEBUG RFM2Pi 512 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:17:55,739 DEBUG RFM2Pi 512 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:17:55,843 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 36 20 12 40 0 137 55 1 0 16 32 4 36 161 56 64 68 32 8 148 (-101)
2020-10-03 09:17:56,035 DEBUG MQTT Publishing: emon/emonpi/power1 26
2020-10-03 09:17:56,037 DEBUG MQTT Publishing: emon/emonpi/power2 10
2020-10-03 09:17:56,038 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 36
2020-10-03 09:17:56,039 DEBUG MQTT Publishing: emon/emonpi/vrms 234
2020-10-03 09:17:56,040 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:17:56,041 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:17:56,043 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:17:56,044 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:17:56,045 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:17:56,046 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:17:56,047 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:17:56,049 INFO MQTT Publishing: emonhub/rx/5/values 26,10,36,234,16.1,0,0,0,0,0,0
2020-10-03 09:17:56,656 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 40 2 0 9 0 0 36 0 4 96 0 32 0 0 8 0 32 8 148 (-102)
2020-10-03 09:17:57,470 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 12 64 32 2 0 9 0 0 36 0 4 96 0 32 0 0 8 0 32 8 148 (-104)
2020-10-03 09:17:58,580 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 16 0 16 0 32 0 0 36 0 4 96 0 32 0 0 8 0 32 8 148 (-104)
2020-10-03 09:18:00,739 DEBUG RFM2Pi 513 NEW FRAME : OK 5 25 0 8 0 33 0 110 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:00,743 DEBUG RFM2Pi 513 Timestamp : 1601716680.74
2020-10-03 09:18:00,744 DEBUG RFM2Pi 513 From Node : 5
2020-10-03 09:18:00,744 DEBUG RFM2Pi 513 Values : [25, 8, 33, 234.06, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:00,745 DEBUG RFM2Pi 513 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:00,746 DEBUG RFM2Pi 513 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:00,986 DEBUG MQTT Publishing: emon/emonpi/power1 25
2020-10-03 09:18:00,987 DEBUG MQTT Publishing: emon/emonpi/power2 8
2020-10-03 09:18:00,989 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 33
2020-10-03 09:18:00,991 DEBUG MQTT Publishing: emon/emonpi/vrms 234.06
2020-10-03 09:18:00,992 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:18:00,994 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:00,995 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:00,997 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:00,998 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:01,000 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:01,001 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:01,003 INFO MQTT Publishing: emonhub/rx/5/values 25,8,33,234.06,16.1,0,0,0,0,0,0
2020-10-03 09:18:02,327 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 13 176 16 0 32 0 0 36 0 4 96 0 32 0 0 8 0 32 8 148 (-104)
2020-10-03 09:18:03,637 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 0 16 0 32 0 0 36 0 4 96 0 32 0 0 8 0 32 8 148 (-102)
2020-10-03 09:18:03,835 DEBUG emoncmsorg Buffer size: 6
2020-10-03 09:18:03,837 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1601716655.805684,5,27,13,40,234.23000000000002,16.1,0,0,0,0,0,0],[1601716660.812417,5,27,9,36,234.64000000000001,16.1,0,0,0,0,0,0],[1601716665.73168,5,25,8,33,234.13,16.1,0,0,0,0,0,0],[1601716670.792023,5,24,5,29,234.03,16.1,0,0,0,0,0,0],[1601716675.73173,5,26,10,36,234,16.1,0,0,0,0,0,0],[1601716680.739125,5,25,8,33,234.06,16.1,0,0,0,0,0,0]]&sentat=1601716683
2020-10-03 09:18:03,846 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 0 16 0 32 0 0 36 0 4 96 0 32 0 0 8 0 32 8 148 (-104)
2020-10-03 09:18:03,922 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
2020-10-03 09:18:05,793 DEBUG RFM2Pi 514 NEW FRAME : OK 5 27 0 13 0 40 0 109 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:05,797 DEBUG RFM2Pi 514 Timestamp : 1601716685.79
2020-10-03 09:18:05,798 DEBUG RFM2Pi 514 From Node : 5
2020-10-03 09:18:05,799 DEBUG RFM2Pi 514 Values : [27, 13, 40, 234.05, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:05,799 DEBUG RFM2Pi 514 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:05,800 DEBUG RFM2Pi 514 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:06,051 DEBUG MQTT Publishing: emon/emonpi/power1 27
2020-10-03 09:18:06,053 DEBUG MQTT Publishing: emon/emonpi/power2 13
2020-10-03 09:18:06,055 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 40
2020-10-03 09:18:06,057 DEBUG MQTT Publishing: emon/emonpi/vrms 234.05
2020-10-03 09:18:06,058 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:18:06,060 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:06,062 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:06,063 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:06,065 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:06,067 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:06,068 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:06,070 INFO MQTT Publishing: emonhub/rx/5/values 27,13,40,234.05,16.1,0,0,0,0,0,0
2020-10-03 09:18:06,625 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 7 0 0 32 128 128 19 0 32 0 0 0 0 0 2 2 0 32 0 32 0 (-100)
2020-10-03 09:18:06,728 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 16 32 32 128 128 19 0 32 0 0 0 0 0 2 2 0 32 0 32 0 (-104)
2020-10-03 09:18:10,732 DEBUG RFM2Pi 515 NEW FRAME : OK 5 26 0 9 0 35 0 130 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:10,736 DEBUG RFM2Pi 515 Timestamp : 1601716690.73
2020-10-03 09:18:10,737 DEBUG RFM2Pi 515 From Node : 5
2020-10-03 09:18:10,737 DEBUG RFM2Pi 515 Values : [26, 9, 35, 234.26, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:10,738 DEBUG RFM2Pi 515 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:10,739 DEBUG RFM2Pi 515 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:10,846 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 20 18 0 0 32 64 40 48 32 34 0 21 128 32 32 160 112 16 32 80 36 (-102)
2020-10-03 09:18:10,853 DEBUG MQTT Publishing: emon/emonpi/power1 26
2020-10-03 09:18:10,855 DEBUG MQTT Publishing: emon/emonpi/power2 9
2020-10-03 09:18:10,857 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 35
2020-10-03 09:18:10,859 DEBUG MQTT Publishing: emon/emonpi/vrms 234.26
2020-10-03 09:18:10,861 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:18:10,863 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:10,865 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:10,867 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:10,869 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:10,870 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:10,872 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:10,874 INFO MQTT Publishing: emonhub/rx/5/values 26,9,35,234.26,16.1,0,0,0,0,0,0
2020-10-03 09:18:12,259 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 4 33 0 5 160 24 52 34 32 4 195 23 170 64 33 48 162 126 97 48 16 (-96)
2020-10-03 09:18:15,778 DEBUG RFM2Pi 516 NEW FRAME : OK 5 25 0 6 0 31 0 128 91 162 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:15,782 DEBUG RFM2Pi 516 Timestamp : 1601716695.78
2020-10-03 09:18:15,783 DEBUG RFM2Pi 516 From Node : 5
2020-10-03 09:18:15,784 DEBUG RFM2Pi 516 Values : [25, 6, 31, 234.24, 16.2, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:15,803 DEBUG RFM2Pi 516 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:15,825 DEBUG RFM2Pi 516 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:15,837 DEBUG MQTT Publishing: emon/emonpi/power1 25
2020-10-03 09:18:15,839 DEBUG MQTT Publishing: emon/emonpi/power2 6
2020-10-03 09:18:15,841 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 31
2020-10-03 09:18:15,843 DEBUG MQTT Publishing: emon/emonpi/vrms 234.24
2020-10-03 09:18:15,853 DEBUG MQTT Publishing: emon/emonpi/t1 16.2
2020-10-03 09:18:15,855 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:15,858 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:15,860 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:15,862 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:15,863 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:15,865 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:15,866 INFO MQTT Publishing: emonhub/rx/5/values 25,6,31,234.24,16.2,0,0,0,0,0,0
2020-10-03 09:18:17,480 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 32 0 0 0 0 34 32 4 195 23 170 64 33 48 162 126 97 48 16 (-102)
2020-10-03 09:18:20,824 DEBUG RFM2Pi 517 NEW FRAME : OK 5 25 0 8 0 33 0 113 91 162 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:20,828 DEBUG RFM2Pi 517 Timestamp : 1601716700.82
2020-10-03 09:18:20,828 DEBUG RFM2Pi 517 From Node : 5
2020-10-03 09:18:20,829 DEBUG RFM2Pi 517 Values : [25, 8, 33, 234.09, 16.2, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:20,830 DEBUG RFM2Pi 517 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:20,831 DEBUG RFM2Pi 517 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:20,937 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 3 64 0 0 0 0 0 32 0 16 0 0 32 0 32 16 0 0 0 22 (-106)
2020-10-03 09:18:20,950 DEBUG MQTT Publishing: emon/emonpi/power1 25
2020-10-03 09:18:20,952 DEBUG MQTT Publishing: emon/emonpi/power2 8
2020-10-03 09:18:20,953 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 33
2020-10-03 09:18:20,955 DEBUG MQTT Publishing: emon/emonpi/vrms 234.09
2020-10-03 09:18:20,957 DEBUG MQTT Publishing: emon/emonpi/t1 16.2
2020-10-03 09:18:20,958 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:20,960 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:20,961 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:20,963 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:20,964 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:20,966 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:20,968 INFO MQTT Publishing: emonhub/rx/5/values 25,8,33,234.09,16.2,0,0,0,0,0,0
2020-10-03 09:18:23,061 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 32 0 0 0 0 0 32 0 16 0 0 32 0 32 16 0 0 0 22 (-102)
2020-10-03 09:18:23,368 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 32 0 0 0 0 0 32 0 16 0 0 32 0 32 16 0 0 0 22 (-105)
2020-10-03 09:18:24,179 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 128 64 0 9 96 0 16 169 9 64 24 80 0 0 0 17 0 40 0 16 (-102)
2020-10-03 09:18:25,791 DEBUG RFM2Pi 518 NEW FRAME : OK 5 26 0 8 0 34 0 109 91 162 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:25,795 DEBUG RFM2Pi 518 Timestamp : 1601716705.79
2020-10-03 09:18:25,796 DEBUG RFM2Pi 518 From Node : 5
2020-10-03 09:18:25,796 DEBUG RFM2Pi 518 Values : [26, 8, 34, 234.05, 16.2, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:25,797 DEBUG RFM2Pi 518 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:25,798 DEBUG RFM2Pi 518 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:25,981 DEBUG MQTT Publishing: emon/emonpi/power1 26
2020-10-03 09:18:25,983 DEBUG MQTT Publishing: emon/emonpi/power2 8
2020-10-03 09:18:25,985 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 34
2020-10-03 09:18:25,986 DEBUG MQTT Publishing: emon/emonpi/vrms 234.05
2020-10-03 09:18:25,988 DEBUG MQTT Publishing: emon/emonpi/t1 16.2
2020-10-03 09:18:25,990 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:25,991 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:25,993 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:25,994 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:25,996 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:25,997 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:25,999 INFO MQTT Publishing: emonhub/rx/5/values 26,8,34,234.05,16.2,0,0,0,0,0,0
2020-10-03 09:18:26,704 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 0 9 96 0 16 169 9 64 24 80 0 0 0 17 0 40 0 16 (-102)
2020-10-03 09:18:27,513 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 0 32 64 32 8 32 0 0 49 32 0 0 0 32 72 32 4 34 (-105)
2020-10-03 09:18:30,831 DEBUG RFM2Pi 519 NEW FRAME : OK 5 24 0 4 0 28 0 108 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:30,835 DEBUG RFM2Pi 519 Timestamp : 1601716710.83
2020-10-03 09:18:30,835 DEBUG RFM2Pi 519 From Node : 5
2020-10-03 09:18:30,836 DEBUG RFM2Pi 519 Values : [24, 4, 28, 234.04, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:30,837 DEBUG RFM2Pi 519 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:30,837 DEBUG RFM2Pi 519 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:30,916 DEBUG MQTT Publishing: emon/emonpi/power1 24
2020-10-03 09:18:30,918 DEBUG MQTT Publishing: emon/emonpi/power2 4
2020-10-03 09:18:30,920 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 28
2020-10-03 09:18:30,922 DEBUG MQTT Publishing: emon/emonpi/vrms 234.04
2020-10-03 09:18:30,923 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:18:30,925 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:30,927 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:30,929 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:30,930 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:30,932 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:30,933 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:30,935 INFO MQTT Publishing: emonhub/rx/5/values 24,4,28,234.04,16.1,0,0,0,0,0,0
2020-10-03 09:18:33,946 DEBUG emoncmsorg Buffer size: 6
2020-10-03 09:18:33,948 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1601716685.793392,5,27,13,40,234.05,16.1,0,0,0,0,0,0],[1601716690.731822,5,26,9,35,234.26,16.1,0,0,0,0,0,0],[1601716695.777717,5,25,6,31,234.24,16.2,0,0,0,0,0,0],[1601716700.823649,5,25,8,33,234.09,16.2,0,0,0,0,0,0],[1601716705.790873,5,26,8,34,234.05,16.2,0,0,0,0,0,0],[1601716710.830652,5,24,4,28,234.04,16.1,0,0,0,0,0,0]]&sentat=1601716713
2020-10-03 09:18:34,034 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
2020-10-03 09:18:35,771 DEBUG RFM2Pi 520 NEW FRAME : OK 5 28 0 6 0 34 0 130 91 162 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:35,775 DEBUG RFM2Pi 520 Timestamp : 1601716715.77
2020-10-03 09:18:35,775 DEBUG RFM2Pi 520 From Node : 5
2020-10-03 09:18:35,776 DEBUG RFM2Pi 520 Values : [28, 6, 34, 234.26, 16.2, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:35,777 DEBUG RFM2Pi 520 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:35,777 DEBUG RFM2Pi 520 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:35,884 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 34 0 32 128 0 8 32 0 0 32 0 0 16 0 8 32 128 0 0 (-102)
2020-10-03 09:18:35,931 DEBUG MQTT Publishing: emon/emonpi/power1 28
2020-10-03 09:18:35,933 DEBUG MQTT Publishing: emon/emonpi/power2 6
2020-10-03 09:18:35,935 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 34
2020-10-03 09:18:35,936 DEBUG MQTT Publishing: emon/emonpi/vrms 234.26
2020-10-03 09:18:35,938 DEBUG MQTT Publishing: emon/emonpi/t1 16.2
2020-10-03 09:18:35,941 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:35,943 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:35,945 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:35,947 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:35,948 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:35,950 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:35,951 INFO MQTT Publishing: emonhub/rx/5/values 28,6,34,234.26,16.2,0,0,0,0,0,0
2020-10-03 09:18:36,092 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 8 56 0 32 128 0 8 32 0 0 32 0 0 16 0 8 32 128 0 0 (-102)
2020-10-03 09:18:36,299 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 1 32 32 0 32 192 0 0 10 34 0 32 0 0 16 0 8 32 128 0 0 (-104)
2020-10-03 09:18:40,785 DEBUG RFM2Pi 521 NEW FRAME : OK 5 26 0 3 0 29 0 128 91 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2020-10-03 09:18:40,789 DEBUG RFM2Pi 521 Timestamp : 1601716720.78
2020-10-03 09:18:40,789 DEBUG RFM2Pi 521 From Node : 5
2020-10-03 09:18:40,790 DEBUG RFM2Pi 521 Values : [26, 3, 29, 234.24, 16.1, 0, 0, 0, 0, 0, 0]
2020-10-03 09:18:40,791 DEBUG RFM2Pi 521 Sent to channel(start)' : ToEmonCMS
2020-10-03 09:18:40,791 DEBUG RFM2Pi 521 Sent to channel(end)' : ToEmonCMS
2020-10-03 09:18:40,972 DEBUG MQTT Publishing: emon/emonpi/power1 26
2020-10-03 09:18:40,974 DEBUG MQTT Publishing: emon/emonpi/power2 3
2020-10-03 09:18:40,976 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 29
2020-10-03 09:18:40,977 DEBUG MQTT Publishing: emon/emonpi/vrms 234.24
2020-10-03 09:18:40,979 DEBUG MQTT Publishing: emon/emonpi/t1 16.1
2020-10-03 09:18:40,981 DEBUG MQTT Publishing: emon/emonpi/t2 0
2020-10-03 09:18:40,982 DEBUG MQTT Publishing: emon/emonpi/t3 0
2020-10-03 09:18:40,984 DEBUG MQTT Publishing: emon/emonpi/t4 0
2020-10-03 09:18:40,986 DEBUG MQTT Publishing: emon/emonpi/t5 0
2020-10-03 09:18:40,987 DEBUG MQTT Publishing: emon/emonpi/t6 0
2020-10-03 09:18:40,989 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2020-10-03 09:18:40,991 INFO MQTT Publishing: emonhub/rx/5/values 26,3,29,234.24,16.1,0,0,0,0,0,0
