I have completed the manual install and it is ‘running’ at the moment I am just trying to get the mod rewrite working so that I can get past the register user for login
I own a Raspberry Pi Model Zero W Rev 1.1 - 512MB (Sony UK), it runs smoothly on it, it has always been. I’ve installed it with emonSD-21Jul21, updated to 11.3.0. I periodically update the main system with apt get-update and upgrade, for security reasons, along the emoncms
there is no way for a 64bit system to run on Rpi0: 64bit runs only on Rpi02
My comment about the 64 bit is that the new Rpi0 W2 is a 64 bit system not 32
I got it sort of running using the manual build but with errors like there are no log files etc. Perhaps I will try an old SD image like the one that ivancaregnato used and see if I get better results
@borpin How were you connected - dial up?
If you do the update and upgrade after you’ve prepped the SD card, it doesn’t take anywhere near that long.
Or maybe you are on an even older Zero, or a slow SD card?
Simon
Hopefully David, @borpin and @TrystanLea will be able to sort out the issues with the scripts and we’ll soon be sorted.
I’ve run though the steps to create the extra partition that @borpin posted last night and these seem to work ok. So just the scripts to fix.
Simon
Yes a 1.3 non W
It is the same process. Updating the firmware takes quite a long time.
In answer to the OP - No!
I’ve got as far as installing emoncms, but then hit multiple problems @TrystanLea
The latest version of Bullseye has a number of changes to different packages that breaks things in all sorts of places. If an exisiting system is apt upgrade
it will break
Lots of the things have been pushed to master
repos, but not all. I also made the mistake of not pulling in the master
EmonScripts branch
Latest issue is that during install, we break a working Wi-Fi setup as created by the RPi Imager. Not fixed that yet.
Summary (not all specific to the PiZ)
- PHP 8.1 is broken for the PiZ 1.3 - works with PHP8.0
- Takes forever on an old PiZ to install
- Logrotate broken - needs testing to check permissions - it is more picky than it used to be.
- emonhub log not created. Probably should be added to the service as an
ExStartPre
directive - demandshaper is a cpu hog
- emonPiLCD was accidentally installed
- permissions on log files incorrect, but that might have been fixed with the
master
EmonScripts branch. - log2Ram config file
00_olddir
is broken, needs and extra line at end (PR in repo) - latest
git
breaks the components page (PR in repo) -
journald
writing files to/var/log
(as you know)
I think we should drop support for the PiZero for the EmonSD, but adjust scripts so it can be installed manually and provide some advice on how to do it. It might also affect the Pi2 as well.
It takes an ^&*ing long time to install (PiZ 1.3), so testing setups takes hours of waiting
@TrystanLea completely stuck as I cannot work out why the Wi-Fi setup will not work. It worked out of the box, but the install scripts have done something to muck it up.
Brian, did you say your PiZ was not a W, so has a WiFi dongle? If so could this be the causing you problems?
I have a 1.3 W so can try to do the install, although I’ve bricked an SD card with all the different combinations of things I’ve tried!! It would be great if someone who has a PiZ 2W could give things a try, as someone said on another thread, these are newer CPUs, so things should work?
Let me know if I can test anything for you. Point me to the right location to download any revised scripts.
Simon
Possibly (yes a 1.3 without Wi-Fi but with a dongle), it worked out of the box with the OS flash, but the install scripts have screwed it up and I don’t know what they do exactly so cannot work out what the issue is. The hostapd
and dhcp
srvers will not start on reboot after install.
If you look at the master Branch. My partial mistake was not pulling this branch in - just pulled stable in
I raised as a query and was pointed to this answer. libpcre3 fails on armhf · Issue #927 · oerdnj/deb.sury.org · GitHub
It is down to the architecture and how the packages are packaged.
Final answer - No, you cannot install PHP8.1 on an arm6 based chipset using this repo, currently. I suspect because RPi Foundation like to be sure their OS woks on all Pis they will fix it when they move to PHP8.1 as the stock PHP on RPiOS.
[edit]
For now, edit the php.sh
file and change 8.1 for 8.0 and it will install (bar other issues).
I installed the 2021 sd onto Pi zW1 with only one small issue that was easily resolved.
Pi Zero W1 easily installs Bullseye with Lamp and full working wifi. Is it really going to be impossible to get the emon system to work on it using an SD image? Would it be easier to make a Pi Zero SD image?
Which architecture is the W? 6 or 7?
Yes, that isn’t the issue. Installing PHP8.1 is the issue as that is not the stock PHP offering.
Probably too much work for a small user base.
Not sure what you are asking. The hardware is a Pi Zero W ver 1.1
“Probably too much work for a small user base.”
Perhaps there should be 2 sd images… one for 32 bit Pi’s and the other for the 64 bit
This is an arm6 chip rather than an arm7.
If you want to help create it, feel free. Creating an image is not a 10 minute job, and there are other priorities.
OEM only supports 32bit OS on any device. Too many differences in the underlying packages. Again though, if you want to contribute, feel free. It is an Open project for just that reason.
The difference isn’t in the W, it’s in the 1 or 2.
So originally it was a PiZ 1 - this had no wifi.
Then came the PiZ 1 W which had the antennae on the board. Should be no difference to the first version with a dongle.
Then came the PiZ 2W which is the newer architecture.
Simon
Or simply use PHP 8.0 until the foundation sort out the issues there?
Simon
Thanks @borpin running that test build and all your notes on what went wrong.
Sounds like in absence of a fix for the 8.1 issue using 8.0 may not be a bad idea for the next emonSD release?
I’ve just merged your pull requests, I will do a stable release
