Hi @FredM67 and @borpin - excuse my ongoing ignorance, but can the emonWiFi as is be used to export to an emonCMS instance, either local or cloud? I’ve only used it so far with HA, but it would also be useful for emonCMS. I assume it’s either an HTTPS transfer, or MQTT? Thanks in advance ![]()
Yes (is the short answer). OpenEnergyMonitor EmonTx Sensors - ESPHome - Smart Home Made Simple
- Locally by HTTP(S) and MQTT
- Externally such as
emoncms.orgvia HTTPS
It can update multiple endpoints at once (e.g. a local instance and emoncms.org) as well as HA.
Thanks Brian - I probably should have seen the large item in the documentation..!
