Hello,
I’ve looked at emonCMS user guide — OpenEnergyMonitor 0.0.1 documentation and I don’t see documentation for the fields supported by the system (input/feed API)?
Can arbitrary fields be added?
– Wink
Hello,
– Wink
Emoncms will accept any numerical input. If formatted correctly it will appear on the Inputs page. There is a concept of ‘Nodes’ here - goes way back to when it just accepted data from the OEM equipment - each one was a node. Now is is just a subdivision of the data (so all my ‘sensor’ data from HomeAssistant comes in under a node sensor).
You then create Feeds from those Inputs - effectively sampling the input data for storage, usually at a fixed interval, into a TimeSeries database (actually a flat file).
These feeds can then be edited to set things like the Units (Celsius, kWh etc).
For other aspects of the API, when installed there is a help link at the top right (and no this hasn’t made it to the docs).
HTH
Txs, nice that the system is so extensible!
– Wink
